Question about Advent Netbook
Advent 7113, memory parity error, 1gb (2x512 modules) cant find them to remove - have tried adding another 512module but still getting the BSoD any advice on removing the old modules or even where they are, not visible under plate on bottom of lap top
  • Gordon Jones
    Gordon Jones Jun 30, 2009
    Great, never thought of looking under the keyboard !
    Thanks for the help, 100% Useful info
    Problem Solver:
  • 15 Answers
Hey,
Check this link. This would give you exact idea about where hthe memory modules are located and how to replace them:
http://www.uktsupport.co.uk/advent/laptop/7113.htm
Astitwa
Posted on Jun 30, 2009
Dell Optiplex 330,won't boot memory parity error, tried new bios battery, new ram stick, still won't boot,actually had two at same time the other I ran a advanced diagnostic test said hard driv
I found this
Customer's Optiplex 330 did the same thing today; no beep codes (due to lack of on board speaker). Solid/orange light on front of case indicates board or cpu. I isolated every component not soldered down (RAM, HDD, Optical, etc). Considering all the fans and lights on the MoBo were functioning, and no physical damage to the CPU was apparent, and the BSOD presented the "memory parity error; system halted" (meaning it's memory, graphics memory, or cpu and we've eliminated possibly CPU and RAM) my conclusion is that the problem resides in Graphics memory failure. Considering the error message is very vague and generally insists "motherboard", the gpu in an optiplex 330 is integrated ON the board, lumping it all together.
and general memory parity fail information
memory parity error fix Google Search
Nov 22, 2017 | IBM ThinkCentre Computers & Internet
Memory parity 2000
Hi Kelly, we are dealing with memory problem, if you have available memory try swapping it, the other way is to remove any card attached in *********** board that may cause some conflict with the system, Isolate 1 by 1 the hardware installed from your hardware.
1. remove the memory module, clean the tip of the memory, the one connecting to the slot with rubber eraser or any rubber. If possible swap with good one if you have to isolate memory defects.
2. remove/clean any cards(video cards and others) in your expansion slots.
3. Boot your PC without connecting the hard/CD/FDD drives to speed up checking.
4. Once start up is okay without memory parity error appearing, one by one install the Harddisk, CD and FFD.
Jun 21, 2011 | IBM ThinkCentre S51 Intel Desktop PC -...
Dell Inspiron 6000, Windows XP. Page Fault Error. Laptop died with BSOD indicating Page Fault error. Won't start in normal (BSOD) or any of the safe modes (hangs while loading drivers). Any ideas?
This appears the be a RAM memory read error. Try removing one of the memory modules, and run the system see if the error still occurs. Then try the other module. If issue is only associated with 1 module, replace that one.
Memory can be purchased here: www.crucial.com
Jan 05, 2010 | Dell Computers & Internet
Blue screen and the charger works sometimes
blue screen aka bsod. when you get this bsod it will show you stop error code. you need to get the code to identify the exact issue you're having. If the bsod occures after the dell logo issue might be the video card or memory. if the bsod occures after windows logo then if might be caused by a corrupted windows updates or windows system file corruption. if the bsod occured after dell logo then check your memory if you have 2 ram modules try to remove 1 ram first then try booting your system using only 1 ram, try to swap and isolate reseat and teach eash slot on each ram module. if bsod occures after windows logo then try to run a test for your hard drive Fn+Power. If no errors it might be windows file corruption which needs to be restored or re-installing OS.
Oct 02, 2009 | Dell Latitude D510 Notebook
When i turn on my dell laptop it says mmi problem contact service provider? wht to do
That is a memory (parity) error.
It could be defective memory.
Try this:
Power OFF laptop
Open the memory access door
Remove all memory modules and put them back in, re-seat them well. This should work.
If you still get the error, remove all but one memory module and try the laptop again.
Power OFF and swap memory modules and try laptop again.
Which module failed? Replace it.
Oct 02, 2009 | Dell Latitude D600 Notebook
After upgrading to 2Gb RAM i get irql_not_less_or_equal
This link will help you ...
http://technet.microsoft.com/en-us/library/cc957609.aspx
Let me know if you need further assistance.
Thanks
Kevin
Apr 27, 2009 | Computers & Internet
PC beep 5-2-2-1 code on startup, no posting
I THINK IT IS MEMORY UPGRADE, ALSO MAYBE A PARITY ERROR, SOME MEMORY DO NOT NEED PARITY ON THE CHIP SET, AND IF IT HAS PARITY ON THE CHIP THAN YOU GET ERRORS,
REMOVE THE NEW MEMORY AND SEE IF THE MACHINE WILL WORK IF SO THAN THERE IS SOMETHING WRONG WITH THE NEW MEMORY,
RAM TYPE: EDO, PARITY AND NON PARITY MEMORY, FPM MEMORY, THE CACHING MEMORY NEEDTO TO HAVE L1 OR L2 OR EVEN L3 CACHING CAPABILITIES,NMI ERRORS .
not:::: EAch manifacture may have a different voltage in the curcuitry and it may have the wrong voltage but i think that way out there and not to even consider it.....
does the manufact even allow that much ram upgrade???
rod
Feb 03, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
775i65G does not work when two 1GB DDR400 are installed.
I would venture to say one of the memory modules you have is bad..
Jan 25, 2009 | Asrock 775i65G Motherboard
Upgrade from 512MB to 1GB
The specs on the memory are correct, so you purchased the correct type of memory for this motherboard. If your getting no video when you power on with the 1gb stick, I would be willing to bet the 1gb stick is bad. Can you return it and try another stick?
Mar 15, 2008 | ASUS P4B266 Motherboard
Advent Netbook Logo
159 people viewed this question
Top Advent Computers & Internet Experts
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
