Mistral MTLW7 E2 error during cycle. It does wash and pumps out water but does not spin.
  • luckypenn904 Jun 30, 2009
    Hi chanddra,
    Not happy "jan" If you are the expert then I would have expected you to reseach this problem and find exactly what is causing it. May I make the suggestion that you ask the manufacturer of this product? Is it the controller card?, motor? I at least know it is not the lid switch.
    Stay with this one as I'm not paying for lame advise!
    Thanks friend.
  • 258 Answers
Hi there luckypenn904 "unhappy jan", if your washer won't spin the lid switch, timer, drive belt, transmission, or agitate/spin solenoid could be the cause here, Sometimes if the load is too heavy, the washer won't spin. Take some of the clothes out and try the spin cycle again with a lighter load.
also.........with these newer models it could be as simple as reseting the programming of the microprocesser in the control panel..........try this switch off the washer at power button and at the wall for 5 minutes.......now after 5 minutes turn on at the wall but dont press power on button on the washer.....first turn the dial to drain/spin option and then press the on switch on your washer and start but make sure you have clothes in there to give it some weight, clothes you want to dry, if it now spins then fine it just needed a reset....otherwise take it to your local repair centre or claim service under your warranty through your warranty plan ok because it will be one of the above components are not right ok.......good luck
Posted on Jun 30, 2009
  • 615 Answers
Sorry friend
Sorry I can't tell you why this is happening, but we just got exactly the same washing machine model, and it is doing exactly the same Sorry I can't tell you why this is happening, but we just got exactly the same washing machine model, and it is doing exactly the same thing for us! So I'd say it's a common problem with the model...thing for us! So I'd say it's a common problem with the model...
E2 Code - Samsung SW50ASP Washing machine
Water drainage issue. Water is not draining from appliance.
·Check drainage pump filter for blockages (e.g. lint, coins hair, clips)
·Check drain hose and waste connection for kinks and blockages.
Then select a spin cycle to drain
the remaining water in the appliance.
·If problem persists please call CustomerCareline. *
Helpline Contact Samsung UK
Dec 08, 2016 | Samsung Washing Machines
Why doesn't it spin when water is being pumped out during spin cycle and doesn't agitate during wash cycle?
after water is pumped out spinning takes place or there is no water inside the drum
Feb 11, 2016 | Washing Machines
The problem with xqb90-701 machine comes up with e2 code will noy rinse ,empty or spin
I don't know what the codes are for this washer but it sounds like it has to do with the pump not coming on and pumping out the water. most of these front loaders have a clean out for the pump filter you should find it between the pump and where the drain hooks up to the tub. many times they get clogged with stuff. I worked on a whirlpool the other day that had a large sock stuck in it.
May 09, 2014 | Washing Machines
Xqb90 701clps
check for a clogged pump. follow the drain line connections to locate it. spin and rinse will not happen until after a majority of the soapy water has been removed
Nov 20, 2013 | Washing Machines
Fault code E2 on midea AW52-9906 washing machine
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Aug 08, 2011 | Washing Machines
Maytag Neptune TL clothes still dripping wet after full cycle
Pump out time of 40 seconds sounds good.
No ND error code and you spin up to 850RPM which is max for the machine.
You have no standing water in the wash basket.... I'm scratching my head.
Could you do a Spin Only cycle with that same wet wash load and set the SPIN for Max Extract. After you start the Spin Only cycle put the machine in Service Mode and watch the RPM range. This cycle sets the display to 12 minutes. Let’s see if the wash load remains wet and what max RPM is reached.
""Maybe the pump is not turning on during the spin cycle?"" You have no standing water in the wash basket correct? I feel the pump is turning on or you would have standing water in the wash basket and the pressure switch would have never indicated an empty condition (Low Level pressure switch contacts) to the Control Board. The Control Board would have stopped the wash cycle with a ND for no drain error code.
The pump in the spin cycle will turn on a number of times see if you hear turn on in a Spin Only cycle
I just ran a Spin Only light wash load with about 5 gallons of water in the wash basket. Timer went to 12 min. I toggled into Service Mode to watch wash basket RPM. At about the 5 Min mark (toggle in and out of Service Mode) the wash basket reached 850RPM then a few minutes later it stepped down to 830RPM to end of Spin Only Cycle. You don’t have a water valve stuck open or you would flood/over flow of the machine. Did you here the drain pump turn on several times during the Spin Only cycle?
Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
E2 error on homemaker washing machine. I have tried eveything including reducing load down to one item. It goes through the wash cycle OK, but will not drain, then eventually flashes the E2 error on its...
I have an E2 error on the display of a homemaker washing machine model no HMWM8000. It will not pump out. The PCB does not have any visibly damaged components, which part is faulty, and how do i test a water level sensor.
Sep 13, 2009 | Washing Machines
MISTRAL MTLW7..2 too many probs!
e4 error on my mistral MTLW7 washing machine want spin
Mar 27, 2008 | Washing Machines
I have a mistral MTLW7 washer and it is having trouble with the spin cycle, it comes up with an error code on the display screen, and will not spin again, as all of the clothes are over one side. The...
Im no expert but i have found the hight of the water outlet is kinda critical to correct function on mine.
The manual states outlet to be no less than 700mm and no more than 1200mm and i have mine now at 900 mm and its all working fine.
Originanly was hooked in under sink and exerienced similar problems
Hope this helps ya out
Dingo~
Washing Machines Logo
132 people viewed this question
Top Washing Machines Experts
