Printers
Problem for Printers
Generic problem for all Printers
Brother HL5250DN Printer duplex problem
By sharpTF1 on Nov 08, 2007
The exit rollers at the top of the printer, after the fuser, are turning the wrong way when starting printing. causing paper to stop at these rollers.
any ideas?
Comments:
Nov 08, 2007
- Thanks for info.
But all the parts appear to be intacct.
The fault occurs during a print run. when the paper reaches the top rollers the paper jams. 've observed these rollers during operation and they are turning against the paper flow, therefore causing the paper to stop at these rollers.
Nov 11, 2007
- Soulvisitor,
Thanks for the info.
The paper is being picked up - goes thru the drum to be printed on, goes thru the fuser to be fixed, then bingo it jams at the rollers that feed it out into the out tray. (just under the lid)
Sharpman
Same Problem
May 21, 2009
-   Can anyone tell me what "mod" Soulvisitor is talking about? The reply seems incomplete?
I have an serial number "C5" (March/05) unit of MFC-8840D and it has this problem too.
Thanks
-   kocoman
Jan 29, 2009
-   My paper also jams because the exit rollers turn the wrong way,
Can anybody help?-   con01
Jan 25, 2008
-   I have the exact same problem when trying to duplex on my HP P2015dn. I can print single sided fine but when trying to duplex i get the jam after the paper tries to go in and print the second time through. Not truly sure if it is a jam however it almost seems as if the rollers dont catch the paper on the second pass.-   Guest
Best Solution
posted on Nov 22, 2007
Very Helpful)
Guest
Rank: Apprentice  Computers & Networking  Expert
Rating: 0%, 0 votes
I have had the same exact problem; make absolutely sure that the exit chute is seating properly. With the exit chute open (as if to clear a paper jam) actuate the white spring loaded clips that hold the exit chute, mine were not traveling to their full extension and by moving them a few times this resolved and the exit chute was held more firmly and the rollers spin the right direction.
Solution #2
posted on Nov 08, 2007
Helpful)
Soulvisitor
Rank: Guru  Computers & Networking  Expert
Rating: 88%, 2422 votes
I have never seen that happen on one of these.
check to be sure that they go backward at the end of printing, they may reverse on startup
I think maybe you are missing the door that sits inside the rear door (called outer shute assy). When you open rear door there should be another before fuser.
How old is this machine, because there is a fuser and outer shute and cover mod, that goes in to early product run of this model. Machines affected are from the Initial production up to and including Serial No.'s K6J702822 (last 9 digits of S/N), this mod is to help with paper curling at exit causing jams.
Comments:
Nov 08, 2007
- heres a bit of brother info, the first two digits of the LAST NINE of the serial number indicate build date, so a K6J702822 ending serial no. means it was built K6 = Nov 06
Nov 08, 2007
- sn is ?????????????????????
Nov 09, 2007
- Hang on so it happens during a print run, so it happens not every print, is this the case?, cause if it works on a single print , then those rollers going reverse could not be the problem. It could be that the printer is not picking up paper causing print run to stop. I will think of these rollers being able to turn backwards soon when I have one of these on my desk next and report back..
Was this helpful?
Yes
No
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
brother color wireless mfc laser
Answer
hp laser printers with zerox ,scanner, printing
Answer
my clp 300 wont feed the paper and no jams or small pieces in the unit
Answer
i dont have the disk &i dont have my 7350 installed on my new laptop
Answer
how i can change the language on Konica Minilta 2490MF
Describe your Printers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
