Question about Nokia 6620
My Nokia 6620 is not powering on.It has in the battery and everything but it jus isnt coming on.The only time it comes on is when i plug in the charger.
I had the same problem, i thought that was the end of the phone. What you should do is get a Torx 5 or T5 screw driver, open the take out the screws that would expose the front of the phone, press down on the ear speaker and the power button at the same time and it should come on. Now everytime ur phone discharges or cuts off you have to repeat the process to turn it on. And i think its because something in the phone gets slack and the switch on the board moves away from the switch on the top of the phone.
Posted on Oct 05, 2009
    President:
  • 1,884 Answers
Your battery seems to be absolute dead. Try a new or someone elses battery. It runs on charger means that the battery is not storing any charge and the phone gets it directly from the charger.
Posted on Jul 26, 2009
No Power
Your laptop's power jack may be broken, which is why your laptop doesn't charge your battery at all, which is why it won't turn on now. I would take a look to make sure that the power supply is good, the battery is good, and then see if the power LED is even coming on when you plug the laptop to a power source.
Apr 10, 2013 | Gateway Computers & Internet
Will not charge--will come on plugged into pc tower,but will not charge
it's charging when plugged into your pc, if it doesn't hold power well you may have a defective battery, plug it in and let it sit for 6-7 hours and see how long the battery holds out. if it doesn't work you have a bad battery.
Feb 15, 2011 | Sony Walkman NWZ-S616F MP3 Player
I jus want to reset my eclipse avn6620 how do i reset it?
To reset your eclipse avn 6620, first you need to see to it that it has been charged for at least 2 hours, then you press and hold the power on/off button, holding it for at least 15 to 20 seconds should restart the gps, then it will be reseted that way.
Hope this helps.
Dec 22, 2010 | GPS
I have nokia 6620 model and it is working only with airtel
Your Nokia is now completely locked to the network of Airtel. You have to take it to the service provider to unlock it. Thank you Sir, Have a nice day.
Sep 19, 2009 | Nokia 6620
Wii console isnt working
Have you tired resetting the AC adapter? If not, then try this:
  1. Unplug/remove all accessories from the system (including game discs, SD Cards, memory cards, Nintendo GameCube controllers, hookup cables, the AC Adapter, and Sensor Bar) from the outlet and Wii.
  2. Let the system rest for about 90 seconds. While you're waiting, check to see that controller cords, AC Adapter, and Stereo AV cables/Component Video cables are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
  3. After the 90 seconds, Plug the AC Adapter into the system and directly into a wall outlet, not a surge protector or power strip. Check to see if the power light on the Power button comes on.
Jul 02, 2009 | Nintendo Wii Console
Optiflex GX260 does not power up
any beep codes?? if there isnt any beep codes your power suply probly isnt producing enough power to boot the system you can check for a burnt or hot smell coming from the power supply if you smell burnt pop corn then you need to replace the power supply they make a power supply tester but if your only needing it once not worth 20 dollars to buy it if the power supply is replaced and it still isnt working the mother board is toast
Jun 05, 2009 | Dell OptiPlex GX260 PC Desktop
Hard reset nokia 6620
Turn off the phone
Press 3, * and the green call key together whilst turning on the phone.
It will ask if you wish to reset to factory defaults (this will erase ALL data from the phone), just follow the onscreen prompts.
The default security key is 12345, hope this works for you.
Mar 20, 2009 | Nokia 6620
Nokia 3600 wont start!
put the charger in your phone, look at the screen is it showing charging indication, if yes disassemble your handset and change power button, if not check power ic and pf ic.
Feb 16, 2009 | Nokia 3600 slide Cellular Phone
Nokia 6620 Logo
62 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
