Question about ASUS P5VDC-X Motherboard
Cannot upgrade more than 512 of ram...can help me?(p5vdcpvm/s)
  • gumbyohson
    gumbyohson May 11, 2010
    how do you mean "cannot". when you insert more that that does it not boot? or is there no physical slot for more?
  • 615 Answers
Dear friend,
this mother board does not support more than 512 RAM.for further info contact Your Dealer or Manufacturer
Posted on Jun 30, 2009
I tried to upgrade my acer aspire one A150 to a 2 GB stick of ram - didn't work so reinstalled the 512 stick I had (SHOULD be a total of 1 mb counting the 512 onboard.) It is NOW only recognizing 512. ...
Try swapping the ram sticks with each other and see if it still reports 512. If it does...then it sounds like you damaged one of the seats for the RAM somehow. Did you have any static shocks occur?
Mar 02, 2011 | Acer Computers & Internet
How can I upgrade/improve the capabilities of my Inspiron 1200
The best and quickest improvement is to add more RAM. Add another 512 Mb of RAM. If you already have a 512 Mb of RAM module then add another 512 Mb RAM module. If your laptop has 2X256 Mb RAM modules then you need to remove these and insert 2X512 Mb RAM modules.
The reason why you have 504 Mb RAM is that the video card has grabbed 8Mb of RAM off the main memory.
May 21, 2010 | Dell Inspiron 1200 Notebook
Hello again.I have an old home pc and I want to upgrade the cpu processor without changing motherboard.Wich is my best options?I want to know if I can to upgrade to PENTIUM 4 3.00 GHz.Also I want to put...
If new processor supports your old motherboard then you will upgrade system with your old motherboard.
If its not supported to new mother board then you have to buy new motherboard to upgrade your system.
Thanks.
Happy to help you.
Apr 30, 2010 | Intel CPU
My time 8375 laptop keeps freezing when playing games can i upgrade graphics card on this or is ram sufficent at 512 advise please thanks
at the time 512 ram is not sufficent you have to upgrade the ram as 1 or 2 gb and also graphic card and video drivers.
Dec 15, 2009 | Computers & Internet
Change ram from 512 to 1 gig bios cannot read added ram
The original 2 sticks of 256 Mb of RAM gives you a total of 512
Mb of RAM. Two 512 Mb of RAM gives you a total of 1 Gb of RAM.
With two sticks of 512 Mb of RAM are you sure you got a total of 192 Mb of RAM, this is a lot less than the original RAM total of 512 Mb?
Should this be 1920 Mb of RAM?
If this 192 Mb is correct then the RAM modules are either not compatible with the laptop or if the RAM modules are not from the same manufacturer then they may not work together.
Most laptops have video cards that use part of the main RAM for video RAM, that is why the available RAM is less than the installed RAM modules. The amount of RAM the video card grabs depends upon the type of video card and in some cases the amount of video RAM can controlled in the BIOS setting.
Nov 07, 2009 | Sony VAIO PCG-K25 Notebook
Want to upgrade ram pc2700 128mb to 512 mb , so i purchased a 512mb ddr1 400mz ram and put it in parallel port but my computer does not boot so i remove the 512 mb ram but problem was as it is now what...
first you check that your ram version.... i means it is compatible with your motherboard...if still prob remains then remove your all ram insert 128 mb ram then restart the system....... upgrade ram should fallow frequency of 512 mb RAM are same as 128 mb ram freqency........if mismatch is occured then it did nt wrked correctly...
Mar 30, 2009 | Computers & Internet
I want to upgrade my HP BA 600 Mother Board`s RAM Capacity
Most likely your MB is too old for this upgrade although there is a chance you could flash your bios (reprogram your computer's brain to accept the new memory providing hp has a flash for it).
here is a link for the latest bios flash for your computer, use at your own risk.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=32895&swItem=vc3903en&prodNameId=20305&swEnvOID=54&swLang=13&taskId=135&mode=4&idx=0
good luck.
Thank you,
agadycom
Nov 27, 2008 | HP Computers & Internet
RAM Upgrade
Yes, you can upgrade your Acer TravelMate 525TE to up to a maximum of 512 MB RAM. you can get compatiable SDRAM card.
Regards
Jul 05, 2008 | Computers & Internet
Upgradeable?!
RAM - 512 MB (installed) upgradable upto 2 GB (max)DDR 2 SDRAM ( 1 x 512 MB ) that means your laptop has only 1 slot for memory.. ____________________________________________________
Was this solution helpful .Show your appreciation by rating it.
dilipbagdi - Technical Associate
Jun 09, 2008 | HP Business Notebook 530
Memory upgrade
The memory should be DDR II Ram. To find how much ram you have simply click on Start then right click on "My Computer" and click properties. Chances are you have 512 ram. It will tell you in the lower right hand side along with your processer and windows version. Once you have found out how much ram you have, turn off your computer flip it upside down and pull out the battery. Then you should see a cover with one or two screws in it that measures about 3 inch by 4 inch. Remove the screws and take the cover off. This is where your memory goes. If there is 512 memory in your computer you will either have 1 512 memory stick or 2 256 sitcks. Remember that any time you upgrade memory it is best to take out the old memory and replace with either one stick of higher ram or two of equal ram. Never mis a 512 and a 256 or 512 and 1gig ect. Take the ram stick/sticks out and bring them down to the store with you just so as to get the correct memory. Also, remember when you replace the memory, if you are just upgrading to one 1gig stick to put it in the A DIMM slot. This is the primary ram slot.
Apr 29, 2008 | HP Pavilion dv6000z Notebook
ASUS P5VDC-X Motherboard Logo
94 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
