Kensington Orbit Trackball Logo
A
Anonymous Posted on Jul 29, 2014
I want to set a button to enter - Kensington Orbit Trackball
Lawrence Oravetz
Level 3:
  • Kensington Master 10,558 Answers
  • Posted on Jun 27, 2017
Lawrence Oravetz
Kensington Master
Level 3:
Answers
10558
Questions
Helped
2696181
Points
29284
Check the mouse setup for your computer. You may be able to assign that function to one of the buttons.
CHANGE TIME SETTINGS ON CALCULATOR DR-210R
  1. Turn on the Calculator: Press the "ON" or "AC" button to turn on the calculator.
  2. Enter Time Set Mode: To access the time settings, you may need to press a specific button or key combination. Look for a button labeled "TIME SET," "TIME," "SET," or similar. Press this button to enter the time set mode.
  3. Set the Date and Time: Once you are in the time set mode, you can use the number keys and other function keys to enter the date and time information. Typically, you'll enter the date as month/day/year (e.g., MM/DD/YYYY) and the time as hours:minutes (e.g., HH:MM). Use the "AM/PM" or "24HR" key to toggle between the 12-hour and 24-hour time formats.
  4. Confirm Settings: After entering the date and time, press the "SET" or "ENTER" button to confirm your settings.
  5. Exit Time Set Mode: Press the "TIME SET," "TIME," "SET," or another designated button to exit the time set mode and return to regular calculator mode.
How do I change the power level?
This is from Page 16 in the users manual...
For simple, one-stage cooking, you only need to set the cooking time. The power level is automatically set to High.
If you want to set the power level to any other level, use the Power Level button.
1. Use the number buttons to set a cooking time. You can enter a time from one second to 99 minutes and 99 seconds. To select a time greater than one minute, enter the seconds too. (For example, to set a cooking time of 20 minutes, enter 2, 0, 0, 0.)
2. If you want to set the power level to a level other than High, press the Power Level button, and then use the number buttons to enter the power level.
3. Press the ENTER/START button to begin cooking. If you want to change the power level, press the STOP/ CLEAR button before you press the ENTER/START button, and then enter all the instructions again.
Enter key for brother mfc 8870
The 'OK' button is the enter button for data entry purposes.
When in settings pressing ok will accept any setting you have changed.
Fix volume control
1. Go into the Set Menu.
2. Press the AMP button on the remote.
3. Press the Menu/Set Menu button.
4. Use the Arrow Up Down button to select Manual Setup.
5. Press the Enter button to enter Manual Setup.
6. Use the Arrow Down button to select the number 3 Option Menu.
7. Press the Enter button to enter the Option Menu
8. Use the Arrow Down button to select D Multi Zone Set.
9. Press the Enter button to enter D Multi Zone Set.
10. Press the Arrow Down button to get to Zone 2 Amp
11. Press the Arrow button to the right to set the Zone 2 Amplifier to INT.
12. Press the Menu/Set Menu button repeatedly to exit the Set Menu.
I’m happy to help further over the phone at https://www.6ya.com/expert/glenn_3b3dd885737c06f6
How to factory rest memorex blu ray dvd player modle MVBD2520
Hello
Select the General menu. Select
RESTORE SETTINGS using the Navigation ( UP or DN) buttons (1),
, then press the ENTER button (2). Select YES using the
Navigation (Up / Dn) buttons 1 and press the ENTER button 2
again to restore the settings. Select NO to leave the settings
as they are.
1helpful
How do i reset parental control when we have forgotten password
You should be able to find it in your TV's manual.
If you lost your manual, here are some possible options:
  • Try pressing the recall button 5 times quickly within 30 seconds.
  • Hold the Volume button down and push the Number 1. Then go to the V-chip button and enter there your new password.
  • MENU button, press SET +/- button to select V-CHIP SET, press ENTER button. Enter password using channel selection. Enter same password confirmation, ENTER Press SET +/- button to select V-CHIP
  • First press menu button then select set or v-chip set obtain then press the enter button then enter the password in four digits. v-chip password will set then we using the direct channe
Your TV model would help a lot, but I hope you find your manual or one of these work.
1helpful
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
I change the color setting in my tv by accident and now i dont get green or red to show it shows brown how do i correct the setting
hello there,
Your TV has three automatic picture settings ("Dynamic", "Standard", "Movie") that are
You can activate a Picture Setting by making a selection from the menu.
1 Press the MENU button to display the menu.
Press the ENTER button to select Picture.
2 Press the ENTER button to select Mode.
Press the ? or ? button to select the Dynamic, Standard, or Movie picture setting, then
? Choose Dynamic for viewing the TV during the day or when there is bright light in the
room.
? Choose Standard for general TV watching mode.
? Choose Movie when watching movies.
Press the P.MODE button on the remote control to select one of the standard picture
settings.
3 Press the ? or ? button to select Contrast, Brightness, Sharpness, Color, or Tint,
4 Press the ? or ? button to decrease or increase the value of a particular item.
? You cannot adjust the Tint in DTV, Component or HDMI mode.
5 Press the ENTER button to return to Mode.
6 Press the ? or ? button to select Color Tone, then press the ENTER button.
7 Press the ? or ? button to select Cool2, Cool1, Normal, Warm1, or Warm2, then press
the ENTER button.
? When the picture mode is set to Dynamic or Standard, Warm1 and Warm2 cannot be
selected.
8 Press the ? or ? button to select Reset, then press the ENTER button.
? Each picture mode can be reset.
there ya go if you need anymore help let me know and don't forget to Rate
How do I change the Time?
To set the Time
1 Push the "Select" button on phone base. The phone will enter in setting mode.
2 Use up and down arrows to choose between "12h,and "24h," for 24-hour display. Press the "Enter" button when done.
3 Selet the hours value using the up or down arrow buttons and press "Enter."
4 Select the minutes still using up or down arrow buttons and press "Enter"
5 Choose "AM" or "PM" Using the up or down arrow and press "Enter."
To set the Date
1Enter in date setting mode by pressing the "Select" button twice.
2 Change the year using the up or down arrow button, then press "Enter."
3 Set the month using the up or down arrow button then press "Enter."
4 Use up or down arrow buttons to select date and press "Enter" to finish.
To extend the number of rings (selected models only):
1 Press the answer button on the base (answer off), this will give you up to 15 rings before the answering machine turns on and takes the message.
Turning alarm on and off
I'm afraid I don't have a manual, but I could walk you through the steps...
1. Press the clock/sleep/timer button twice.
2. Press enter button.
3. Turn dial to set hour for alarm to start.
4. Press enter button.
5. Turn dial to set minute for alarm to start.
6. Press enter button.
7. Turn dial to set hour for alarm auto-shut off.
8. Press enter button.
9. Turn dial to set minute for alarm auto-shut off.
10. Press enter button.
11. Turn dial to select either Radio or CD alarm setting.
12. Press enter button.
13. Turn dial to adjust volume of alarm.
14. Press enter button.
15. Press standby button. Alarm is set.
I hope this helps! Best of luck finding a manual if you still need one. :)
Top Kensington Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
