Question about Kenmore Washing Machines
My calypso is saying ''LD'' I dont know what to do for it.
  • 370 Answers
Ld means long drain. Theres a problem with your pump. The pump for these washers are around 100 bucks. This is a very common with the calypso washers.
Posted on Jun 30, 2009
What does "Ld" mean?
Ld
Long Drain
Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Check for obstructions.
www.appliancehelponline.com
Mar 22, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Get alarm code ld
CI code comes on just seconds after I start the machine. The machine itself is leveled on all sides.
Dec 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso fails to remove excess water from washed clothings
There are two separate motors, one for the tub and one for the pump. They are both controlled by the motor controller board. Since you say the water drains, the pump appears to be working but since you say the clothes are wet, the spin probably didn't happen. I would suspect the drive motor or the wiring for that motor. There are procedures on the web for testing the wiring and motor windings. Good luck. There is also a pdf diagnostics/test document available. http://www.affordableappliance.com/Download%20Folder/Calypso%20Washer%20Service%20Manual.pdf
Good Luck!
Aug 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer - LD Code - clothes still wet
harborstuff,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. I would bet that the bath mats left a bunch of stuff stuck in the recirculation pump hose, or pump itself, and the water cannot be drained fast enough. Check the intake and exit hoses of the recirc pump. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. Hope this helps.
(Definitely get under there and check to make sure the pump hoses are not clogged. At $129 it's an expensive fix for a $10 bath mat that clogged up the hose with fuzz. 'know what I'm sayin'' :o) )
-samson39
BTW, I have the maintenance manual & have experience at replacing the recirc. pump, control board, motor board, touchpad, & lid switch so far.
Jul 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
May 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
What does LD and OB mean on my washer
I'm not sure what the codes mean but here is a site that may help with your problem..not sure but do try it if you like..
http://www.repairclinic.com/RepairHelp/RepairHelp.aspx
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Ld error code won`t drain.or do anything starts for 10 sec and stops
Owner manual - Code Ld -says the drain hose is kinked or clogged.
Check that the hose didn't get kinked when pushed back to the wall. It's a common problem. The problem is NOT the wall drain as water would be coming out onto the floor if that was the issue.
Jan 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
What does ld mean on my washer?
op is probably ob, off balance, the ld is long discharge, most likely the pump is bad or full of junk, the origional pumps were updated to a better design so as not to get stopped up.
Aug 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
What does ld mean?
ld mean long, drain. the machine was unable to drain out water in a given amount of time, calypso is imfamous for collecting lint in the pump assy, id open that up and have a look
May 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
