Question about Car Audio & Video
It has two powers and two groud I went out side groud and out side power is that write.
  • 30 Answers
You need to specify what you are talking about and maybe i can help you but as of now i have no clue. are you talking about bridging an amp to make it run mono or single channel if that is the case you typically use the left channel positive and the right channel negative but on most bridgeable amps it is marked somehow whether it is something like the pos and neg are circled or there is a line drawn on it showing the 2 connecting but regardless it is typically the left pos and right neg. if this is not your question please clarify and i will try helping.
Posted on Jul 03, 2009
  • cchatterson Jul 03, 2009
    you need to specify what you are talking about and maybe i can help you but as of now i have no clue. are you talking about bridging an amp to make it run mono or single channel if that is the case you typically use the left channel positive and the right channel negative but on most bridgeable amps it is marked somehow whether it is something like the pos and neg are circled or there is a line drawn on it showing the 2 connecting but regardless it is typically the left pos and right neg. if this is not your question please clarify and i will try helping.
Inside cab fan not working
Not sure what year,make or model this is but it may be the fan resistor or the fan, try testing for power at the motor (fan). use a testlight and if theres power to motor then make sure the groud is good and if it does then fan is bad, if theres no power or groung then it sounds like the resistor. good day.
Jun 19, 2011 | Dodge Ram 1500 Cars & Trucks
My stereo from my jetta gli wont turn on ???/ fuse is fine i already checked it
first make sure your wires are connected properly.
red is ignition power
orange is constant power
black is groud
all 3 wires need to be connected for it to work.
also check the fuse thats built into the back of the radio prob behind the wire harness
Jan 29, 2011 | Car Audio & Video
Have 1982 chevrolet 1500 high seria truck have replaced starter alternator battery, alternator still not carging
CHECK YOUR GROUD WIRE FROM ONE SIDE TO THE OTHER. MAKE SURE IT HAS GOOD GROUND. COMENT BACK TO LET ME KNOW IF IT WORKED
Nov 08, 2010 | Chevrolet Chevy Cars & Trucks
My stereo in my 1997 grand am does not work and i was told it is the ground, how do i fix this?
saying it is the ground wire is only a guess, if they did not pull it apart and test it it could be anything, they are just guessing since it has a plug on the back it could be a groud or a power cable, when you turn it on if it has a power antena the antene should go up. If it does not then it may be the power side regardless you have to remove the radio to get to it.
Apr 16, 2010 | 1997 Pontiac Grand Prix
I have a 2005 Dodge Magnum and the tail lights
1, bad fuse. 2 both bulbs are bad. 3 bad groud wire. 4 check power to the bulb in trunk. bulb is not in the socket .
Jun 16, 2009 | 2005 Dodge Magnum
1995 jeep grand cherokee laredo 4x4 all power windows not working
had same problem with 94. in the door jam there is a rubber boot that holds all the wires for your power windows and locks and stuff. remove the boot and check each of the wires in that harness to make sure they are not broke. that's what was wrong with mine on both doors. the wires break with repeated door openings.
Jan 27, 2009 | 1995 Jeep Grand Cherokee
2004 Ford Escape Electrical problem
Wen you put back the battery on i think that you mist a groud wire that was on your groud cable or a power wire +try this and good luck
Apr 15, 2017 | 2004 Ford Escape
What's the problem.
hello... i will try to help you.this seems to be a power suply malfunction.make some measurements of the tension between groud and secondary tensions of the power suply(one or more of them could be lower),possible cause :one or more electrolytic capacitors damaged
Jul 10, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
