I do have the remote with a new battery on it. I have two units, one works fine with the remote but the other one does not...any suggestions?
  • marconti01 Jun 30, 2009
    Thank you very much for helping me with my AC problem....Yes, the AC works but not with the remote. I know the remote is good because it works with the other unit, as you said might be the processor but I don't know how to change or replace it.
    Scholar:
  • 70 Answers
Check power to second unit and if it works in manual then there is a micro processor problem in second unit if this remote once worked it.Also try killing main power to second unit as it could be a lockout problem. If it work and shuts down again then there is a primary cause.
Posted on Jun 30, 2009
  • Kendall Clendenen
    Kendall Clendenen Jul 01, 2009
    Sorry. but you will need to contact manufacturer for more info at this point. Find someone that works on this make as it is an OEM item.
I have a Mitsubishi air conditioner model SRK50ZDA-S. The remote display seems to be working fine as I can change all of the settings as normal, but the wall unit doesn't respond to it. I can turn the wall...
The remote batteries could be defective or installed incorrectly. Try removing the batteries, pressing all buttons to eliminate the possibility of a stuck one, reinstalling batteries and testing operation. If no operation, the remote may have failed or there could be failure at the wall unit.
Jan 07, 2015 | Mitsubishi Heating & Cooling
BOSE LIFESTYLE TV SENSOR PROBLEM
Usually on any equipment with a remote---if you hold remote real close and it works you have either a dirty lens for the receiver or a defective infrared receiver in the unit-----odd that moving things would cause this.
If it is only the on/off function having a issue--that would rule out both of the possible solutions I suggested.
Be sure batteries are new/good and no indirect light is hitting front of unit where receiver is located.
May 18, 2012 | Audio Players & Recorders
My remote wont work it says set 1
You can try this simple idea; to re-code the remote to your unit, press and hold 1 and ENTER/OK buttons together for 5 - 10 seconds, then release. This should restore the remote command to match the unit, and thus the remote should work. Failing that, replace the batteries in the remote with new ones, and repeat the above suggested procedure.
If the remote is triggering 'SET 1' on the unit's display, this simply means the remote code is different to the unit, and hence the remote requires a reset to restore control to it whenever the batteries are replaced. Easy enough to fix, doesn't take very long, and should not cost anything except some new batteries if required.
Apr 28, 2011 | Panasonic DMRES15 DVD Recorder
Panasonic DMR-EX88 recorder was working fine but remote has stopped working so cant get to the hard drive (can still play a disk by pressing play on the unit). Remote started working intermittently, now...
Either the remote itself is exhibiting strange behaviour, or the unit's IRD controller circuit (and/or the IRD itself) is faulty. Perhaps when you changed the batteries, the remote needs to be 're-commanded' (that means entering a remote code by pressing and holding 2 buttons together for 10 seconds - example - 1 + ENTER/OK) - this should be done whenever the batteries are replaced. If this does not restore the remote to full control, then the IRD (and/or its controller circuit) is the most likely suspect; or, worst case scenario; your remote is defective. I hope it isn't the latter.
I suggest you submit the unit to an authorised service centre for a quote (since this is not a disc drive replacement/alignment it shouldn't be too expensive) then you can decide for yourself afterwards as to what further action to take. Up to you, it is not unfixable. You can always ask Panasonic directly for straight answers and get a second opinion at the same time.
I hope you do not need a new remote at this stage.
Apr 01, 2011 | Panasonic DMRES20D DVD Recorder
The Remote Control is not working. I've changed the batteries and get all the functions to light up but it does not connect with the main unit. I have put the main unit into "force" mode amd that...
There is problem of transmission signal.whether indoor receiving sensor or passing signal in remote.
You can check with same type remote to operate the unit. If unit works your remote problem, if not your receiving sensor in PCB problem. That can be repaired. Helpful?
Dec 28, 2010 | LG LS-K1830HL Heat Cool Mini Split Air...
B93-366 Indoor Unit Ours is mounted on the wall in a new room addition (3 years ago). Has worked fine. Used it with remote control a few days ago. It worked fine. Turned it off with remote control. next...
You will have to remove the front panel and check the fuse to make sure that it did not pop. Also check your breaker switch to make sure that your breaker did not pop. Those can be your really only two issues
Please rate
Jun 01, 2010 | Heating & Cooling
Fujitsu air con unit. Remote wont work. has new batteries
Check the micro processor control whether it is in manual mode or not. If not check the sensor whether it is functioning or not. If everything is fine then remote control has to be changed.
Aug 15, 2009 | Heating & Cooling
Chamberlain Whisper drive remote control unit not working
THE NEW REMOTE MAY NOT BE THE CORRECT SYSTEM FOR THE UNIT YOU HAVE.
THE ONE THAT DOESN'T WORK MOST LIKELY NEEDS A NEW BATTERY.
NOTE IT MUST BE REPROGRAMED AFTER CHANGING THE BATTERY
HOPE THIS HELPS
May 14, 2009 | Chamberlain 950CB Remote Control
REMOTE CONTROL DOESNT WORK
Some of the remotes that originally came with those units did not work or last very long. The manufacturer then later offered another remote to replace the first units. It looks like the model number you provided is a serial number, not the actual model number. I suggest that you contact Master Parts at 800-446-1446 with your model number (you should be able to find it directly on your unit with the serial number you provided) and they should have that replacement available for purchase. You also can find them on-line at www.masterparts.net. I hope this helps you!
Oct 18, 2008 | Vanguard International Blue Flame - Medium...
Remote
u can purchase a universal remote from ebayer "genuinecopies" for £7.49 + P&P £1.49
Oct 28, 2007 | Cyberhome DVD Recorder - DVR1600
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
