Question about Samsung SC-D353 Mini DV Digital Camcorder
My lcd won't display a picture. it is white with colored lines going across it. If i flip the screen it used to show the picture, but now will just show a blank screen. I'm thinking there is something wrong with the connector between the lcd and the internal piece in the camera. what part is this? I have a samsung digital camera model sc-d353 thanks
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
The connector between the LCD and internal parts of the camcorder is called RIBBON. based on what you said, you need to call Samsung hotline for repair of your camcorder
Posted on Jun 30, 2009
White line across screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
HP Dv7-1130us LCD screen displaying vertical blue line
the actuall screen LCD is bad.
in most cases.
supper common failure.. 2008 PC.
see page 31 , part 5 here. bingo, change that out.
there are 2 types used, only your full PC part number on
the service tag show this, post that and we go to the HP parts surfer and look it up.
http://h10032.www1.hp.com/ctg/Manual/c01918142
Sep 28, 2017 | HP Pavilion dv7-1130us laptop
Our lcd phillips tv screen turns completely white after about an hour of use
The TV, most probably, the display circuit or the display itself has developed dry solder/components leaking and the TV needs attention by a qualified service technician.
Jul 14, 2012 | Philips Televison & Video
Photos@vizio.com/Casenumber/2540322
My tv has white lines across all on the screen
Jun 05, 2012 | Vizio 42 in. LCD TV
My LG led has had several problems, it started out with the left half of the screen flipping as if viewed from a mirror with the right part of the screen normal. After that, it displayed vertical colored...
This problems are a very tipical of the coded pixels on the LCD screen panel passes through the board that call the T-CON decoder board to causing this problems.Vertical colors lines display on the LCD screen panel happen by itself.Yes.The T-CON decodering board it is dying and shorting out.This T-CON decodering board sit in the middle at the botton of the LCD screen panel.Replacing this T-CON decodering board will solved this problems,if does not the LCD screen panel itself it is shorting out,than the tv it is not worth fixing,because changing the whole LCD screen panel itself it is not practical and the cost will be the same as a new tv itself.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
May 31, 2011 | LG 32LE5300 Widescreen 32 in. HDTV
Outdoor pictures give white display on screen
Go to the menus and reset to default or factory settings. Make sure that the white setting in the picture adjustments in the menus are set to zero or you may have to adjust + or - to get the normal effect again.
Test the camera by taking pictures and saving to a sd card. Then put the card in a card reader/writer which is connected to the computer. Copy the pictures or files to the computer and view them to see if they are in good shape or if there is some problem with exposure or the way it looks.
If the computer pictures show that they are good, and they are not showing good on the camera LCD, then the LCD has a problem, and is possibly either cracked or has some other display problem.
These LCD screens are not that hard to change if you are good at working with small items and screws. If you do this, make sure you have a way to remember where you got each screw, as they can vary in size and kind.
Apr 15, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Mar 14, 2010 | Vizio VW42LF 42 in. LCD HDTV
Lines on screen
I was going to ask to define lines, but if you have lines (red, green or white) usually means the screen is dying.
Full lines across the screen (such as in the case of my wife's laptop) mean the screen is dead. In either case, replacing the LCD is in order.
Good luck
God Bless
-Carlos:
Jun 12, 2009 | HP Pavilion dv8000z Notebook
Heavy white lines accross the screen
change the ram and viedo card agian
Jun 07, 2008 | Computers & Internet
Samsung SC-D353 Mini DV Digital Camcorder Logo
788 people viewed this question
Top Samsung Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
