Reset password-reinitialize the mail box
SOURCE: 4621 SW IP phone by
THe 4621 was used on the IP Office as well as the One-X Quick Edition.
Which do you have?
SOURCE: Re-set the password for voice mail
What a lucky guess :-) Glad to hear that helped.
The lady should also tell you how many used and available mailboxes you have. I believe they came in 10 20 and 40 box sized and 2 4 or 6 ports.
Carl
SOURCE: someone left employ and we have no idea what voice
Which voicemail system do you have? You will need to have the admin reset that mailboxes password, which requires that you get into the admin part of the voicemail system.
SOURCE: Avaya Partner Phone System 518-457-701...
All Parther voice mail or messaging systems have a master login and password. It usually is 99 or 999 and the password. From that mailbox, you can reset the extensions and administer the system. Your system admin guide for the particular messaging system will have complete instructions and the default password for the administer. If you've lost the "master" password, you'll need to contact your Avaya dealer who can reset it through Avaya.
Carl
SOURCE: someone quit and we need to reset the password on
Hi well Ok, in this case the BEST thing to do is to return it to "As from The factory" this will then reset it all and make it like a new phone, and is best done this way. So what you need to do is to perform a a factory reset. You will need to get the codes and program them in, this is quite detailed and this info is only available in the relevant manual, links below...
Please find a manual download links below, please use this manual to be able to perform what you need to do.
http://www.mbl.edu/it/telephone_servies/pdf/8400.pdf
http://www.retrevo.com/support/Avaya-8410D-Telephones-manual/id/2877ci772/t/2/
http://www.tek-tips.com/faqs.cfm?fid=6285
above is a command glossary too.
However IF you mean Voicemail password, then that can only be removed by contacting the service provider and getting them to do it, as it has nothing to do with a phone, as such.
