SOURCE: 2005 jeep grand cherokee radio
It's in the engine compartment IOD#2. It's a black module with two fuses in it. Take that module off and replace the 20 AMP one.
SOURCE: i need a fuse diagram for 1995 jeep grand cherokee
Check this information, can help you:
- Engine Fuse and Relay Bank
Fig. 1 Engine Fuse and Relay Bank
Fig 2 Detail of fuse/relay
- ZJ-Secc-8W-Wiring-Diagrams
Also, you can check the page 7 and next about Fuse Description.
Good luck, and remember rated this help.
SOURCE: Where is the fuse box on a 1994 Jeep Grand
Should be above and in front of drivers left foot. If not, check kick panel on passenger side and glove box. There is a second panel near the battery that is considered the "power distribution center" that holds larger fuses and relays.
SOURCE: I was looking for the fuse box in my 2006 jeep
Interior Fuses The fuse panel is on the lower instrument panel just to 1 30 Amp Green Audio Amp (B+) 2 15 Amp Blue Sunroof (B+) 3 10 Amp Red Htd Mirror (EBL) 4 20 Amp Yellow Rr Pwr Out (B+) 5 10 Amp Red Rr HVAC (R/O) 6 10 Amp Red OCM (B+) 7 20 Amp Yellow Door Locks (B+) 8 15 Amp Blue Steer Col Lock (B+) 9 20 Amp Yellow Pwr Outlet (B+) 10 10 Amp Red Ign Run Only Out (R/O) 11 Spare 12 10 Amp Red Mem. Sw, Courtesy Lamp (B+) 13 Spare 14 20 Amp Yellow Cigar Ltr (R/A) 16 10 Amp Red SCM, Cluster OBD (B+) 17 15 Amp Blue Flipper Glass (B+) 19 10 Amp Red OCM (R/S) 20 10 Amp Red WCM, Cluster (R/S) 21 15 Amp Blue Autowipe (Accy Delay) 22 15 Amp Blue Rear Wiper (B+) 24 10 Amp Red PDC, FCM, A580 (R/S) 25 10 Amp Red ABS, Trans. Case Switch (R/S) CB1 20 Amp Cycle -Wipers (B+) CB2 20 Amp Non - Cycle Seats (B+)
the left of the steering column.
15 10 Amp Red Tire Press Mon (R/O)
CB3 20 Amp Non - Cycle Windows (Delay)
