Question about Ace Hardware OAK BROOK SINGLE CONTROL TUB AND SHOWER CARTRIDGE
Does the plastic piece stay inside of the spout when attaching it to the converter? we are attaching it with galvanized piping, then do you just put the 1/2 '' water line inside that plastic piece? won't the water pressure when turned on shoot that spout out?
  • 297 Answers
There is an allen key or a screw in the slot under the spout on the plastic piece.this is what keeps the spout from shooting off the pipe.
Posted on Jul 24, 2009
Water leaks continuously out the over flow from the geyser hot water system
You could have excessive inlet water pressure , or bad valve .
Feb 24, 2013 | Water Heaters
Replaced delta valve with moem. when water to toub is turned on at high pressure water comes out of the shower head. Valve is installed correctly. Took cartridge out of valve and blew back through shower...
The pipe going from the main valve to the tub spout(not the sprayer above)needs to be a full 1/2" pipe if you used a pex 1/2" to the tub spout-the inside is usually smaller and causes it to back pressure and make water release thru the sprayer above-needs to be installed with a full 1/2" ID PIPE-AND DONT USE GALVANIZED
Sep 29, 2017 | Moen Posi-Temp Single HandleTub And Shower...
There is loose wall mount tub filler. How can I tight it?
Most tub spout are pretty covers for the generic ugly pipes that deliver the water from the wall water plumbing into the tub area. Speaking for this water pipe it's either going to be copper or galvanized iron pipe. The pipe that you see sticking out of the wall is rather short. It ends just inside the wall usually at a 90 degree elbow which in turn is connected to a pipe and other things inside the wall cavity. If this short pipe stub is loose so you can move it in and out of the wall hole some, the reason is that the plumbing pipes inside the wall are not tied down to the wall studs properly.
If the backside of the wall can be opened by cutting out a section of sheetrock in the same location as where the spout pipe is located, you can expose the inside wall plumbing and tie in the wall pipes securely to the wall framing. Afterwards, you need to seal up the sheetrock hole you created.
In some cases this is not possible. When that is the case, your fix is spotty at best. You can use a caulking that becomes rock hard when cured around the pipe nipple as it comes through the wall hole. Hopefully the hard caulking will provide enough tightness tying the pipe to the wall material to help stop the movement. Install the caulking so it is underneath the pretty tub spout when you reinstall it over the generic pipe. Make sure you do not have this caulking involved with the pretty spout so if you need to remove it again, it won't be locked in by the hardening caulk.
Nimsgame
Feb 15, 2011 | Cifial Wall Mount Tub Filler Spout CIFIAL...
I want to put another water line onto an existing 3/4 galv. pipe. To put a "T" in the middle will I have to weld it or is there left and right threads so you can tighten the middle pipe turning in one...
The problem you are faced with is that galvanized pipe is put together as a "progressive" process. The easiest action you can take is to cut the galvanized pipe where you want the T and back out both pieces of pipe from their respective joints. Reassemble and use a union coupling to finish the connections. An alternative would be to replace the section of the line where you want the T to be with copper pipe, using a dielectric union at both ends where you connect back into the galv. pipe. You have to solder the connections, but it might be easier.
Sep 12, 2010 | Plumbing
Tub spout is calcified onto pipe and will not twist. i don't want to ruin pipes , how do i get it off?
First make sure you have a thread type spout. Look on the underside of spout for a set screw. If one is not found then you have a threaded spout. If you have set screws then it is a friction spout loosen set screw and twist/pull spout. A couple things you can try to loosen the calcium build up. Use a calcium buildup cleaner (may or may not be able to reach area) you can also try rapping on spout with rubber mallet calcium is hard and this might break it up (cause fractures in the calcium) then take a no mark wrench (simuliar to what you take oil filters off with) and turn spout counter clockwise. It may be hard but it should come off. If the spout pipe is galvanized it may come off inside the wall before it comes off of the spout. No worries just keep turning until off. Once off you can work on the spout end then reinstall. Make sure when you reinstall you place teflon on the thread ends. Hope this helps, thanks for using FIXYA. Good luck and have a great day. Jeff
Apr 07, 2010 | Price Pfister 01-311 Shower Head, Tub...
How to install tub spout for delta model 174924 shower assembly
Normally, tub spouts are screwed onto 1/2" NPT galvanized pipe. I was unable to pull the spec for your particular tub filler, but I haven't found one yet that doesn't. I don't know why the builder didn't rough it in this way, but it will have to be fixed because there isn't any way to use anything but a threaded fixture (your other options are really only compression or soldered/sweated and you don't have the space behind the tub filler to do either of these). There should be a fitting in the wall (attached to a stud) that converts from the 1/2" copper pipe to 1/2" NPT galvanized. This piece needs to be added behind the wall so that you can attach your tub filler.
About the gap, it's generally a good idea to leave space around the pipe anyway so that minor temperature or humidity changes in the wall don't put stress on your plumbing and cause it to crack over time. That's one of the reasons why tub fillers are flared at the back (so that it covers the gap).
Sep 21, 2009 | Home
The rough plate goes on inside or outside of green board? Also can u use pex for the downspout for tub it seems to restrict flow and sends water to the shower...
I do not recommend pex for the downspout as pex is flexible and the tub spout needs to screw on or attach to a solid pipe. I recommend copper but you can use galvanized piping. As far as the rough-in plate it goes through the greenboard as you will have a whole the size of the plate and depending on the finish you are attaching to the greenboard.... there is information on the plate as to the depth that needs to protrude from the greenboard to facilitate the trim. If you have any questions just ask. THX
Aug 06, 2009 | Moen & One Handle Tub & Shower Faucet
American Standard Cadet model 3275 - Plastic piece inside of pipe
Yes, there is a non-replaceable plastic restrictor device screwed into the tub spout outlet of the faucet body. It's purpose is to force the flow down to the spout for when the spout diverter is not closed. It keep water from rcoming out of the shower head when the tub spout is also discharging.
This is all fine and dandy where the water supply is clean without sediment. A co-worker of mine had one of these and old galvanized piping. After 3 years, it clogged up. She got a 'deal' from a handyman plumber to replace with an identical faucet. She will have the problem again. If she had spent the money to fix it right, she would have had a single handle mixing valve put in. If it clogs, you can just pull the cartidge from the body, clean it and put it back in. Now she will have to cut into the wall again, get the plumber to replace the 2 handled unit and patch the wall again.
Or, she could have the plumber drill out/remove the restrictor but then she might get water out of both outlets at the same time....."pay me know or pay me later"....repalcing the mixing valve with a scald prevention single handle valve (with remodel plate) is the BEST long term solution.
Fred Grable
Chicago
(Engineer and Ex-Master Plumber)
Mar 22, 2009 | American Standard Colony 3275.505 099...
Shower spout
There is a threaded stem that passes through the spout and attaches to the white plastic diveter valve. If you are starting from scratch (everything apart), you can put it back together in this order:
1) Place the white plastic diverter inside the spout. the circular side with the black round washer should face the the wall side of the shower (mating up against the threads for the water pipe).
2) The stem can now be inserted from the top and into the notched section of the white plastic diverter valve. The threaded end of the stem shoud be outside of the spout (from the top side).
3) A round black washer fits over the threads. It should sit right where the threads end. Dont push it all the way on to the unthreaded portion of the stem.
4) Screw the threaded knob onto the threads.
Should be ready to install now. Including the spout itself, there are 5 parts and are configured in this order from top to bottom.
1) Female threaded knob (the knob for operating the spout)
2) Threaded stem (threads on top)
3) Round black washer
4) Spout
5) Whit plastic diverter valve.
Mine leaks when I turn on the shower, thus reducing shower pressure. I looks like a poor design to me. The stem is not a tight fit in the spout and this allows the diverter to "wobble". The washer on the diverter valve does not seat tightly and allows water to leak out the tub spout when showering. I would replace the spout.
Jan 30, 2009 | Price Pfister 01-311 Shower Head, Tub...
Leaks at the hot water spout during coffee brew
I had the same problem. I ended up taking the coffee machine apart and found that the reason coffee trickles out around the hot water spout is that the two coffee nozzles were partially plugged. Since I Had parts of the coffee machine apart I was able to clean it easily. It may also be possible to clean the assembly using a pick of some sort and clean out the holes of the two normal coffee spouts. Inside it is just a open cavity so gentle poking around and using some steaming hot water may do the trick.
If you want to take the machine apart you need to do the following: 1) take of the warmer plate on the top - 2 storz screws but an allen key works as well 2) take off the top plate of the machine - another 4 or 5 screws - make sure you empty the beans first otherwise you will have a mess 3) remove one screw from the right hand side of the removable coffee ground tray. Once this screw is removed the front panel is free to swing open except for the pipes connecting the front 4) unclip the steam assembly - there are a couple of plastic catches on the top. this will free the steam assembly from the front panel and also free a pipe connections. The steam dispenser pipe will also come free from the steam assembly. 5) remove the coffee pipes from the up and down sliding coffee dispenser. This is a small whitish color clip with 2 pipes connecting into it. The white clip has a little plastic catch on the top that frees it. The front panel should now swing open freely. 6) remove the sliding coffee dispenser from the front door. There are 4 plastic catches, 2 on either side. the whole front sliding coffee displenser now comes free 7) Take the sliding dispenser apart by release the 4 plastic catches on the front curved planel. 8) Inside the sliding dispenser is a white plastic piece that connected to the piping released in step 5. There is a small plastic catch that needs to be pressed while pulling fairly hard on the plastic piece and bending the whole piece. 9) You will now see the plugged spouts. It goes back together really easily.
Aug 13, 2008 | Jura Capresso Impressa S8 Coffee Maker,...
Ace Hardware OAK BROOK SINGLE CONTROL TUB AND SHOWER CARTRIDGE Logo
100 people viewed this question
Top Ace Hardware Home Experts
guitar zan
Are you an Ace Hardware Home Expert? Answer questions, earn points and help others
