Question about LG DLE2532W Electric Dryer
Their are 4 idler wheels in which the drum spins 2 are seized how do i get parts
    Sergeant:
    Champion:
  • 235 Answers
Go to Repair Clinic and have your model number ready.
Posted on Jun 30, 2009
Dryer Not spinning. Replaced a bunch of stuff. Spins for about a min and locks up
You may have not replaced the bearings or some other part correctly? did you check the rollers? are they positioned and turning correctly? is there still a screeching sound? I would suggest removing the cabinet, jumper the door switch and run it without the belt and drum connected? check to see if the motor is even turning or seizing? is there a humming sound? a winding sound? your motor may be bad?
Feb 15, 2015 | Frigidaire GLGQ2152ES Gas Dryer
Washer won't work in spin cycle grinding noise
Idler bearing on rear of washer drum,you have to remove the back panel and you should see the idler,more than likely it is rubbing and not allowing the drum to turn freely.Replace bearing or idler wheel.
Jan 18, 2014 | Estate Washing Machines
Zenith is4041 record/ cassette player
There is a clip in the center of the turntable's spindle. Remove it and the turntable platter should lift up. That model of turntable is driven by a rubber surfaced idler wheel that is tightly held between the motor shaft and the inside of the turntable's rim by a spring.
Most likely problem(s):
1. The motor is seized. (Even a seized motor will hum, from the 60Hz vibration of its windings.) You should be able to spin it freely between your thumb and index finger, with no resistance. If not, you must totally disassemble it (easy job), clean out the bearing journals with alcohol, lubricate, and reassemble. If you decide just to oil it without cleaning out the bearings, it will quickly seize again.
2. The idler wheel is seized on its shaft. Same solution as 1.
3. The rubber surface of the idler wheel has become hard with age. Best solution for this is to replace it, if you can find one. Alternatively, there are various liquid chemicals around that can renew the surface of the rubber.
4. The pivot mechanism that allows the wheel to assume its proper position is seized. Same solution.
5. Any combination of the above, including all of them! :-)
While you're in there, look at the geared wheel that engages the teeth on the inside center of the turntable's platter. It will have a little "kicker" mechanism that is moved by the turntable's tone arm (part that holds the cartridge) as the tone arm nears the end of the record. This little mechanism is notorious for seizing, and should also be cleaned out and lubricated.
Cheers!
Aug 16, 2013 | Zenith Televison & Video
MY FRIGIDAIRE WASHER ACTS LIKE THERE IS A BRAKE KEEPING IT FROM SPINNING UNTIL I GIVE IT A LITTLE SPIN AND THEN IT TAKES OFF?
Sounds as though your idler wheel on the back of the drum is seized ,you will need to remover the back panel and ,ore than likely replace it.
Oct 14, 2012 | Washing Machines
Need to know if I can get parts and what part #'s available for Whirlpool/ Roper electric Dryer lme4600w2. For blower wheel,blower wheel belt, idler pulley, & drum belt.
Hi Alisa Wilkerson...
Try one or both of these on-line websites...they also have phone support (free)
1... http://www.appliancepartspros.com/ (1-877-477-7278)
2... http://www.partselect.com/ (1-888-895-1535)
Good luck, I am sure they will be able to help
Bud
Sep 21, 2012 | Whirlpool Dryers
What makes a belt squeak?
Belts squeak for the same reason tires do when they spin. They are slipping. Something isn't turning as fast as the belt wants it to. On ford it's usually ether the idler sprocket or the tensioner. If you remove the belt and try spinning all of the pulleys by hand.( note the crank wont spin freely) you will usually be able to tell witch ones slipping.
May 14, 2011 | 1999 Ford Taurus
Screws on my Sears track drive snowblower unthread themselves.
Back wheels have a gear that connects to the drive chain. on each side. those spin.
The front ones which are Idlers do not spin as the idler wheel as a bushing in it that allows free motion on the shaft without resistance. Use a nylock nut with Locktight for starters. The try that.
Hope this helps. -Jeff anchorage small engine repair.
Feb 02, 2009 | Craftsman 16" High Garden Tractor Snow and...
Dryer makes loud squeaking noise when spinning
there are two possibilities for this question. 1) there is an idler roller that give the belt the correct tension . unplug dryer and remove idler roller see if it spins freely if not replace it @0 there are two drum rollers in back of machine thatdrum rides on remove drum it's self explanitory how to remove drum and very easy also. you can roll these wheels and check for free movement visually check them ,one or both should be worn out or the bearing in the wheel has failed before putting old or new wheels back sand the wheel shafts to get any gunk off them and that's about the only thing that can make a dryer squeek
Jan 25, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Dual 1228 turntable platter not spinning, the motor will not turn
If the motor is not spinnig then it is probably seized. These motors are very robust and rarely need replacement parts. Remove both the top and bottom bearings, clean shaft and bearings with solvent and then fill bearings with light machine oil. The bearings have a sponge inside which will soak up lots of oil for years of trouble free use. Once reassembled, tap the bottom bearing while the motor is spinnig and the bearings will centre themselves. If the idler and it's mechanism is working ok as well then you should feel lots of torque from the from the platter when it is spinning.
Dec 19, 2008 | Audio Players & Recorders
Maytag MDG3000AWW drum moving slowly
If the belt looks worn you should replace it. But it sounds like the idler pulley has gone out of position or possibly broken. The idler pulley adds tension to the belt and keeps it from spinning on the drum surface. Check the path of the belt on the bottom of the dryer. That is where the idler pulley is.
Feb 01, 2008 | Dryers
LG DLE2532W Electric Dryer Logo
78 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
