Question about Delta & Single Handle Shower Faucet
Leaky shower doesnt shut off. keeps driping - Delta & Single Handle Shower Faucet
    Sergeant:
    Champion:
  • 235 Answers
Shut your water off at the meter and replace the cartridge.
Posted on Jul 05, 2009
Shower dripping
The shower drips because one of the water shut off valves is leaking. The video linked below will show you how to make this repair much better than typed words can. See
How To Fix or Replace Leaky Shower Valve Stem Seal
If replacing the seal does not cure the problem, then the entire valve stem needs to be replaced.
Mar 13, 2015 | Home
Shower faucet
Hopefully you had the correct type of cartridge for your faucet.
I would suggest watching this YouTube video to make sure the cartridge was inserted and fixed correctly. The travel of the cartridge may not be aligned correctly. Hard to think of anything else that could still cause the drip.
How to repair replace leaky moen cartridge on single lever tub shower...
Aug 17, 2014 | Moen Home
Leaky shower head
You need a replacement cartridge or faucet washer on that shower control
Jan 08, 2018 | Moen Home
Leaky danze shower faucet
you need to go to lowes or your nearest plumbing supply store and get a new cartridge and replace...you may also just be able to replace springs and seats if its like a delta...i believe danze is made by delta...ask them for help and they will advise you on parts...good luck...remember to shut water off to home before doing this repair...
Oct 17, 2012 | Danze D500511BN Brushed Nickel Melrose??...
Water is constantly driping from the dispenser area
Water dripping from a water dispenser is caused by a leaky water inlet valve which is on the back where the water supply is connected. It needs to be replaced.
Aug 24, 2011 | Whirlpool Refrigerators
The water was of in my area for most of today now its back my triton shower wont work its turns on but the the water is only driping out
Hi, the reason for no water is you have picked up dirt and sediment in the lines when they turn you back on.You will find aerater on faucets to unscrew and clean the screens, try taking the end of the shower head off to clean out the sediment. This is the reason for no pressure. You may have to wrench the head completely off to clean it. Good Luck,
Shastalaker7
Ps, After removing it, let the water run to clean the pipes and flush the water heater.
Nov 14, 2009 | Home
Leaky shower flawcet
where the leaks coming from?if the leak come inside the shower head the problem is in the valve, if the leak is in the connection of the shower head and pipe check the o-ring or u can put teflon arround the thread of the pipe b4 connecting the head shower
Aug 21, 2009 | Plumbing
Water flowing through power shower on or off
Sounds like you either have a very leaky washer or the shower cartridge is stuck. You may have to turn off the water to the house since many shower valves do not have separate isolation valves.
Jul 31, 2009 | Home
Leaky handshower hansgrohe croma c100
Grab a wrench and give it at least a quarter-turn. Hand tight isn't enough with a shower, even with teflon tape.
Mar 28, 2009 | Hansgrohe 04070930 Croma C 100 3-Jet...
Leaky shower knob
Absolutely the same as the shower excluding the obvious difference in supply cut offs.Thanks for using Fix Ya.
Mar 02, 2009 | Moen & One Handle Tub & Shower Faucet
Delta & Single Handle Shower Faucet  Logo
332 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
