Question about HP LaserJet 1150 Printer
I have changed the printer cartridge three times. The first two cartridges produces totally black copies; the third one has black horizontal thick lines across the page??? H E L P !
  • 615 Answers
It is may be Problem with printer Fuser.
1.Confirm there is no paper pieces in backside fuser unit.if yes remove the printer cover take out the fuser unit and remove the paper pieces.
2.if there is no paper pieces you must replace
fuser unit Teflon or entire fuser unit. ordinary teflon costs about Rs300.(6 dollars)
Posted on Jun 30, 2009
The "on-off" light is flashing steadly... while
The flashing light could either indicate a cartridge problem or the printer carrier has stalled.
Test the cartridges one by one and do the printer hardware test (refer to the relevant document for your printer) to establish which one is defective. The defective cartridge needs to be changed. To do the hardware test, follow the steps below:
  1. Switch the printer off.
  2. Put one sheet of paper into the paper feeder.
  3. Press and hold the power button and the paper feed button for three seconds until the power light comes on.
  4. Release both buttons. After three seconds, the printer will start to print. You should obtain a page containing a series of horizontal color lines, and a thick black line below these. All the lines should be solid.
  5. When the test is complete, switch off the printer. NOTE: If you do not turn off the printer, it will keep on printing this page.
To check if you have a cartridge carrier stall, follow steps below:
  1. First unplug the printer.
  2. Move the cartridges to the left by hand. In order to do this, you need to grip the top of the carrier belt (a black/grey belt with cog-like teeth) and pull it towards the right-hand side of the printer.
  3. Once the cartridges have been moved across, you can clip them out.
  4. Try to print without the cartridges in the carrier.
  5. If you no longer have a carrier stall, put the cartridges back into the carrier and clip them into place.
Try to print a document to check if printer is working properly now.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sources: - Lights Flashing on the Printer - How to Perform the Hardware Test on the Lexmark X74/X75
Jun 25, 2011 | Lexmark X75 All-In-One InkJet Printer
It will print everything except black and is brand
First, try another black cartridge. Second, make sure the cartridge is an original hp -- not a refilled/recycled cartridge. Third, click on START, then Printers and Faxes. Find the printer icon and right-click. Click on Properties, then on Maintenance. Check to see if the ink counter/inklevel for black is showing full. If not, reset it. Also, see if your driver is set to print Composite Black (all three colors will combine to make a simulated black when the black cartridge is empty.. If so, change that too.
Apr 25, 2010 | HP OfficeJet J4580 All-In-One Laser...
Printer smears l h side of envelope Not in printed area
The problem you are experiencing is caused by the way the text is formatted in most word processing documents. By default envelopes are printed not in black, but a dark gray. This confuses the printer and causes it to use the color cartridge to process gray instead of using the black cartridge. You can fix this problem with one of 2 ways.
Please select the "Black" only option following the steps given below:
1. Click on "Start," "Control Panel" and click on "Printers and Faxes."
2. Right click on the "Lexmark printer icon" and select "Properties."
3. Select "Printing Preferences," click on the "Quality/Copies" tab and choose "Print Color images in Black and White."
4. Select "OK."
You can also change the color of your text to a true black in your word processor. This will require you to resort to the word processor's documentation and help files.
Both of these settings will cause your printer to use the black cartridge instead of the color. If either one of these solutions solves your problem, it means your color cartridge needs to be cleaned or replaced. If you feel that the color cartridge should not be out of ink please try the following:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Aug 20, 2009 | Office Equipment & Supplies
Black smudge on middle of each copy
defective toner cartridge. Replace it.
Please rate solution :)
May 26, 2009 | Office Equipment & Supplies
Canon Pixma IP3500 prints B&W with white streaks
as i can suggest you that it can be the problem of head clogged internally where you insert your black cartridge .and the other main cause is while you give a head cleaning command to get the cartridge cleaned it sucks or pulls  the ink from the cartridge in such a huge quantity that 3-4 cleanings make the cartridge totally empty .due to this the ink gets very low and the printouts come with streaks.many a times setting the print mode in best makes the copy perfect.but the printing gets too slow in that best mode.
Feb 26, 2009 | Canon PIXMA iP3500 Printer
Printing onto clear film for screen printing film positives from R2400
midwest screen and supply will have the printers and the films for screen printing, it's the company i go through and i've had no problems in the past 14 years of ordering from them
Apr 18, 2008 | Epson Office Equipment & Supplies
Refurbished Canon PC 160
Yes...it's definitely the toner cartridge.
Erice
Oct 29, 2007 | Office Equipment & Supplies
HP LaserJet 1150 Printer Logo
208 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
