Question about Samsung PS42P2S 42 in. Plasma Television
Noise on speaker directly connected to samsung PSX2P2SBX
The noise is very loud and only at startup for a while 1 min or so. After it disapear totaly. There is no noise on other output, only on directly connected speakers.
Is there any way to find a replacment media device (tuner) ?
  • bigmike3345 May 11, 2010
    could you please tell me where i can get parts you descibed on fixya for the sound problem on a samsung PSX2P2SBX (1uf, 50 volt surface mounted elec caps and chip.also where abouts are they on the pcb.hope you can help me. many thanks Mike
  • 4 Answers
On the sound pcb attached to main pcb in the seperate box are two 1uf, 50 volt surface mounted elec caps. These go leaky, and sometimes take the chip with them. You will need the right gear to do this job. £12 .00 for parts including chip.
G.A.
Posted on Aug 04, 2009
I purchased active speaker to avoid the internal amplifier.
Posted on Jun 30, 2009
Loud speaker static from 2002 Mitsubishi Eclipse when the car is off. It drained that battery. I tried pulling the radio fuse but it was still making the noise. I had to disconnect the battery to g
The fuse might be built into the cable to the lighterand/or radio. It's called "fusable link", this type of fuse looks like a cable. Or another type of fusable link might be in the fuse box under the hood near the firewall.
Feb 01, 2015 | 2002 Mitsubishi Eclipse
10 years and first problem to repair. When you turn on and select DVD or any other selection a very loud cracking noise comes through right speaker only. So loud (with volume tuned off too) that I fear...
I think your receiver is damaged.
Try this.
Mark the speaker wires on the back of the receiver. label the speaker connected to the left channel "Left" and the speaker connected the the right channel "Right"
Also pay attention to the polarity (positive an negative) making some type of marking on your speaker wire so you can reconnect them correctly.
Disconnect both left and right speakers.
Connect the speaker wire that is labeled "Right" to the receiver's left speaker connections only then turn your receiver on.
IF the loud noise comes back, this speaker is damaged. I am guessing that the speaker is fine.
Now connect the speaker that was labeled "Left" to the receiver's right speaker connections and turn the receiver on.
IF the loud noise comes back like it did before but now playing through the "good" speaker there is a problem with your receiver.
If so, your receiver is 10 years old. Isn't it time for an upgrade? Try ebay for good used equipment deals.
May 01, 2014 | Onkyo TX-DS787 Receiver
I have a loud popping and crackling noise from the speakers; it occurs after the tv has been on for 20-30 mins, and won't stop. After I power it off it will still continue for about 5 mins. Do the...
You have a bad audio output IC in the main board, you have a couple options as long as you don't use the sound from the TV...one is order a new main but if it was me I would take the back off and follow the wires that go to the speakers and unhook that plug.
Nov 15, 2017 | Samsung HLS4676S Television
Tuner Keeps Turning Off when a Loud Noise is Played
It's a receiver, not a tuner.
Clearly something is overloading it or forcing it into self protection.
What else is drawing power from the same souce as the receiver, or from its convenience outlet. There IS a limit to how much current it will support.
Try checking the speaker connections and their impedance to make sure it's not unacceptably low.
Apr 02, 2010 | Audio Players & Recorders
Samsung 4663w rear projection tv loud buzzing
Hai,
Buzzing can be caused by a bad ballast, colorwheel, or cooling fan... Nothing else makes a noise, unless it's comming from you speaker.
Hope it Helped U!
Aug 04, 2009 | Samsung Televison & Video
Noise coming from speaker with controls
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} hi!! we have read your problem..every problem has a solution.since you havent used your speakers for a long time disconnect it and clean it with a cleaning solution.make sure the electrical contact(connection) is tight enough since loose connections will cause such sounds.hope your problem is tackled..have a nice day
May 22, 2009 | Logitech X-230 Computer Speakers
Loud ticking noise on startup
I would have you oil pressure checked. The oil pump or bearings could be going out. The lifter noise on this car usually will go away faster then 5 minutes. I think the noise is lasting a little to long.
Mar 15, 2009 | 1995 Buick Riviera
Startup trouble
this is cause by deffective power supply.
Jun 26, 2008 | Samsung SyncMaster 540N 15" LCD Monitor
Connecting Creative Labs Gigaworks S750 to Onkyo SR605 A/V Receiver
take those speakers to an electric shop and ask him for some special sockets.....
Jan 08, 2008 | Creative Labs Gigaworks S750 Computer...
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same problem...it was deemed unrepairable and I was advised to return it to Circuit City...now a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
Samsung PS42P2S 42 in. Plasma Television Logo
89 people viewed this question
Jerry Greenberg
Jerry Greenberg
