Question about HP LaserJet 3330 All-In-One Printer
Printer out of paper
My printer is writting printer out of paper. with papers inside. how can i correct this?
I discover a paper was jamed and hooked on the roller film which was not allowing the printer to take paper. so i removed the paper and change the bad roller film. now my printer iss working fine.
thanks
Posted on Jun 30, 2009
    Champion:
  • 220 Answers
Take paper out out tray,look where pickup roller is,is there a black flap like plastic.if yes them push to see if it goes up.there is a sensor at top.
Canon ir1022f
stop paper in drum unit check drum writted or blank if writted check transfer roller or tr.bias if not write check laser unit
Mar 31, 2014 | Office Equipment & Supplies
My printer print without no writting , paper just come out blank and it's new ank model hp d500
Hi, If you didn't used your inkjet printer for a long time the most common problem is that the nozzles of the print head are clogged with ink, so no ink can go down to the paper and that's why you see a blank sheet of paper. What you can do is Deep Head Cleaning from the printer properties menu a couple of times. If this does not help you will need to replace the print head
Sep 14, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Always says paper jammed but there is no paper jaming inside
  • Power off the printer for 30 seconds. If the issue persist, follow the steps below.
  • Open the printers front cover and make sure to check for any paper left inside the printer.
  • Verify that you are using media within specification for the printer in terms of size and weight and that the paper is being fed from the appropriate input source.
  • Make sure the paper trays are loaded correctly. Incorrect loading of the trays can result in poor paper feed performance
  • Mar 26, 2011 | Lexmark C510 Laser Printer
    Paper feeder stuck
    If the paper feeder stuck, do the following:
    1. Gently pull any jammed paper out from the output tray or sheet feeder.
    2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
    3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
    4. Load the paper correctly.
    5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    THE PRINTER STATUS SAYS IT IS OUT OF PAPER, BUT THERE IS PAPER IN THE TRAY. HOW DO YOU CORRECT THIS PROBLEM?
    The most likely scenario is that one of the paper travel sensors are "ON" There is one at the top of the printer where the paper exits. The other is below where the paper enters into the printer. Take a close look for torn shreds of paper that may remain in the printer. Look inside the front of the printer where the paper goes. Take the toner cartridge out of the printer, look in the hole, inspect closely for loose paper. I hope this information was helpful, should you have further problems perhaps seek an HP Certified Technician for repair.
    Jan 15, 2011 | HP LASERJET P1006 Printer
    Why does the paper light keep blinking even though paper is loaded correctly in the tray?
    Check the microswitch inside the printer paper tray. Turn off the printer first and unplug it. There is a sensor switch that may need cleaning from paper dust, or the microswitch that tells the printer there is paper there may be bent, good luck
    Jul 11, 2010 | Brother HL-2040 Laser Printer
    I have an error E2. I have tried to reset the
    E2 just says to insert paper and press OK, for some reason the paper is not feeding or the sensor inside is not seeing the paper. Check inside where the paper goes for any obstruction, sometimes ink pens, paper clips, jewelry, etc... fall inside the back and stop the paper from feeding. If your printer has 2 choices for paper make sure the paper is in the right tray and select the correct tray.
    Feb 08, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    Paper not going inside
    Try to place the paper correctly...if it not means its having problem with the head...carry to the nearby hp service center and clarify it
    Jul 05, 2009 | HP DeskJet 3550 InkJet Printer
    PAPER JAM IN MY LEMAX X4650
    Have you really checked the printer, there may be a small piece of paper jamed inside the printer, this is a common fault and common fix for most printers.
    Jun 03, 2009 | Lexmark X4650 InkJet Printer
    Priter Jams
    Sometimes this happens when the paper is too thin. Have you tried ordinary substance 20 paper? Also see if the guide for the paper is set correctly according to the size of the paper that you are using. this especially happens if the guide is not able to correctly set the paper straight before it is fed
    Aug 06, 2008 | Canon PIXMA iP90 Mobile Printer
    HP LaserJet 3330 All-In-One Printer Logo
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
