My power went out so when it came back on we had to go flip the switches on the fuse box but now my ac wont work, we even changed out the outlet to see if that was the problem but it still wont work
  • imalilaud Jun 30, 2009
    Nothing works not even the fan , i thought mabe it would have a reset button but i dont see one. i dont know. i might have to have someone come look at it.
    Scholar:
  • 37 Answers
I assume since you changed the outlet it is a window unit?
Does the fan work?
If so you either have a thermostat that won't engage the power to the compressor or you have a bad capacitor that starts the compressor. Most units have a start and a run capacitor, but they are often in the same can. Sometimes you can ground out the cap- with the unit UNPLUGGED!- by using a screwdriver and shorting each cap pin to ground-. Prepare yourself for a loud POP when you do this. Sometimes this works to get the cap working again- but just sometimes.
Since it quit working after the power went out maybe you had a surge that fried a component. Also, when you changed the outlet did you check that you were actually getting voltage? Depending on your unit it could be a number of things from the cord to a switch. Make sure you have the thermostat set for coldest and see if that does it. Sometimes it is just something simple like that and it happens to the best of us from time to time.
Posted on Jun 30, 2009
  • Annimater
    Annimater Jul 09, 2009
    Did you test the outlet for AC voltage_ either 120 or 240V? Either before or after you changed the plug?
    If you aren't getting juice to the plug or wires, then you probably have a circuit breaker that has broken the circuit and the ones you turned back on are not the bad ones. Check for a sub-panel, your circuit may not be in the box you flipped the switches on. Lots of times they look 'on' but have kicked off. Go over each breaker one by one flip them off and back on, check for voltage at your plug.
    It may be that the breaker for that circuit is bad. Hopefully you or someone has diagrammed your panel to show what circuits are on each breaker. I'd recommend it.
    If you have proper voltages then likely you have a problem with a switch, which may be analog or digital depending on the vintage of your unit.
    Check the cord for continuity and/or power. Test analog switches out of circuit for continuity or
    carefully check for ACvolts with a voltmeter to see if your switch is working. I wouldn't recommend this unless you are familiar and comfortable with testing hot high voltage circuits and reading your VOM scales. Never use more than one hand and put the other behind your back- don't touch the unit with your other hand use alligator clips to make the connections. Use rubber gloves and don't stand in a puddle.
    I hope the surge didn't fry the compressor in a brown-out situation. Surges are bad, but low power is even worse on electronics, expecially newer more sensitive digital equipment.
Wiring diagram for a 1988 sunline travel trailer.some of the light switches and outlets have no power going to them.what could be the problem?
Your trailer has two electrical systems, 12v and 120v. The 12v system has a battery and perhaps a converter/charger to power it. The 120v system must he hooked up to 'shore power.' Both systems have their own protection. The 12v system has a fuse panel, check for power at each fuse. 12v wall switches are often smaller and don't look like typical 120v switches like in a house.
The 120v system has a breaker box and circuit breakers. Reset each breaker by turning off then on again. In addition, the 120v outlets might have a GCFI outlet near a sink. It often is wired first in a breaker circuit, thus giving GCFI protection to other outlets in the circuit. Test the GCFI and make sure it clicks off and can be reset.
May 01, 2017 | RVs
Went bang tripped fuse now wont turn on
Did you flip the switch in the switch box back on?
Dec 26, 2013 | Kitchen Ranges
Two of the electrical outlets in our kitchen have no power. I checked to make sure the connections were tight and they were, still no power. Then I replaced both of them with new receptacles (ones that...
Each outlet receives power from previous outlet box or switch box in a long chain of parallel wiring back to ceiling box, or junction box, and then back to circuit breaker.
Use process-of-elimination to find problem.
Locate all boxes on same circuit breaker. Locate box before the two dead boxes... it can be in ceiling light, or switch box, or outlet box. Then test those wires. Look for loose quick connect where wires are pushed into hole on back of device, or loose white wires twisted together and shoved to back of box.
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/How-to-wire-switches.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 03, 2013 | Leviton 10 Brown Switch Outlet...
We had ablack out the outside fuse box ,the fuse was flipped upside down and now none of our outlets in our kitchen work,none of the lights,or the stove work can you help with some advice
check the Fuse also make sure ALL the Fuses are to one side of the Fuse Box if the power is not working in the kitchen outlets that means one of them is flipped if this doesn't work let me know.
Jan 23, 2011 | Televison & Video
I was sitting at my computer, with my space heater running, and suddenly both of them went out. Assuming that I had drawn too much power, I went to the fuse box to flip the switch back. Much to my...
The service to your basement needs to be upgraded if you are going to run the heater and other electrical units. I would guess that you have a 15 amp line and need to upgrade it up to at least a 20 amp and with a 12 gauge grounded line. In the short term you may be able to get by using a heater that draws fewer amps.
This definitely sounds like your need to consult an electrician.
Feb 21, 2010 | Kitchen Appliances - Others
The Wii console went off. Is there a fuse that can be changed?
It's not a fuse issue, the AC adapter needs to be reset (I'll how explain below). First, a little background on the issue.
Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
This is a common problem with the Wii. As I said, I'm very surprised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Nov 14, 2009 | Nintendo Wii Console
Kenmore dishwasher... filled up with water and its lights went off.. no buttons work acts like no power. check the house fuse box - ok ... check the 2 door switch - ok .. checked the thermal fuse - ok ...
Did you check power to the unit? Double check the common and grounds. When servicing I will disconect(unplug from wall) power to the unit. Is it pluged in? Use another outlet(the outlet under the sink may be wired thru a switch for a disposer)even if you need an extension cord. Hope this helps.
Nov 12, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Front AC Blower quit working. Rear AC blower
The first thing I would do is check to see if a fuse is blown or bad relay. Then I would unplug the blower motor with a test light make sure you are getting power to the blower located on the far passenger side of the vehicle under the dash if it has power and good ground then suspect vaulty motor. If you are not getting power at the plug then you might have a bad switch or resister. If it does have a blown fuse remember they usually blow for a reason like faulty wiring or even a in the motor itself. I would also recommend that you change the ac cabin filters behind the glove box if they have not been changed most people neglect them on that vehicle because they are a little more difficult to change, after removing the glove box there is a metal bracket in the way of opening the cabin filter compartment. They wont cause a blower motor to not work, however they do restrict airflow to the evaporator and they protect you from pollen, dust, and even exhaust gases. Hope this helps.
Jul 08, 2009 | 2006 Honda Odyssey
Stopped turning on, charge light appears when plugged in...
try removing the battery and plug in AC power only and power up, sounds like you may have shorted the battery
regards
Nov 24, 2008 | Gateway CX2610 Notebook
Ac power
There are a couple of fuses in that power supply. But if it is a 412 or an F12 most likely you have developed cracks in the solder connections of that particular LVPS.
I would recommend replacing the LVPS.
Roughly a 250 dollar price on that power supply.
Sep 15, 2007 | Xerox FaxCentre F12 Laser Printer
Heating & Cooling Logo
251 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
