Question about Acer Aspire One AOA110-1588 Notebook
No task bar, internet and strange "window" after "live Update."
When I boot the machine, I do not see the task bar. I cannot access the internet or get "network connections" to initialize. I see a small(1"x3")"window"that has a 10 point "star" in the center of it. When I hover my mouse over it, a dialog box open that tells me: new item. this item has not yet been been configured. I have no idea what this is and I have tried left and right clicking it, no result. I used "Live Update" on saturday evening and powered off, all of this has been ongoing since I booted on sunday. What do I do?
  • shellscott42 Jun 30, 2009
    how do I access "roll back" in linpuslite? it is NOT a windows based os....
  • Tharinda
    Tharinda May 11, 2010
    Seems a virus... Just go here and check. If it doesn't work, download one of these online scanners and check. Bitdefender Kaspersky U have to do a disk cleanup also (By selecting properties of the partition), live update won't do any good. Just do a system restore by going to control panel or by typing this in your "Run" box in the start menu. C:\windows\system32\restore\rstrui.exe Type that in and press Enter. The you can do a system restore. (Select a day before that incident has happened). Or go to this link and follow the instructions under System Restore. Can U see the icons(Hope U can). Go to the task manager and check the Network Connection related Drives. Make sure no yellow ? marks are there. I recommend to do these 2 tasks in safemode. To go there, Restart the machine and press F8 until the menu is shown. Then go to safemode. Select No from the dialog box if you want to do a System Restore. In the Run box in the start menu, type msconfig and enter . Go to Startup tab and read it and check whether there are any viruses listed. Can u get task manager by pressing Ctrl Alt Del together?If you can't its 100% sure that your machine is infected. Ask for further help after trying these. If its helpful to you, please rate the answer. Thanks. Good Luck. :)
    President:
  • 1,865 Answers
Use roll back feature to revert pc settings prior to saturday
Posted on Jun 30, 2009
Won t let me use internet
Check your password is being input correctly.
Sep 17, 2013 | Sylvania Computers & Internet
Tip
How to use a mobile phone as modem.
Two methods are there to use your phone as modem
1)you can use your PC suit to use your phone as modem for You need
*USB cable or Bluetooth on your mobile
*PC suit software provide by phone manufacturer(ex:Nokia,Samsung,LG,Sony Ericsson).
To use your phone as modem
*install the PC suit softwareConnect your phone to PC via USB cable(I recommend you to use USB because it's faster)
*Open PC suit and select "Connect to internet"
*if its failed you can use manual setting by selecting "Connect to internet">Select access point>select the name of network operator from the access point list(if you did't get your network operators name in the list you need to contact your network operators customer care they provide the access point name you need enter this access point in the manual updation list now it works.
2)You can use Bluetooth technology to connect to internet (2 methods are there)
For this you need
*Bluetooth on your PC and phone
To connect(in windows OS)
*Click on Bluetooth symbol on task bar
*Select add device select from device which can be connected to your PC list(set your Bluetooth device to visible all mode)
*Add your device to your PC Add completion of the above...
*Again click on Bluetooth symbol on task bar
*Select "show all devices"
*now select your device(one click) at this time 4 options appears on top your devices list
*select connect using>access point
and 2nd method is
*Again click on bluetooth symbol on task bar
*Select "show all devices" *double click on your device
*select connect to internet from the dialog box which appears after selecting the your device
Above options are with respect to Window 7 and Windows related operating system.
Thank you...:)
ANY SUGGESTIONS?
on Jan 30, 2011 | Computers & Internet
No connections are available windows 7 but computer connected with network as well.
Boot the machine at first. If the problem still remains, make sure you have installed latest network card drivers from manufacturors site. You can also try to disable the network interface card, then enable it.
Aug 14, 2012 | Dell Precisions Workstations T1600...
How do I fix Fader Sys issues
first of all uninstall norton it uses up memory and connection speed & uses up alot of resources & hard drive space...so get rid of norton...
Mar 02, 2012 | Microsoft Windows XP Home Edition
E640 REBOOT
Hi John,
I see you mentioned you update IE9 then you now get a blank screen...
If I may ask the blank screen showed up after the update or did it show up after restarting the computer?
If your getting a Blank screen when you boot into windows after the IE9 update, try rebooting then boot into Safemode.
Restart you computer then as soon as you see the Boot screen of you computer keep on Tapping f8 to get a list select safemode, then once it boots into safemode windows will load up in safemode on the issue and you can navigate arround to fix things that went wrong.
click on the Start Button on the lower left of the task bar then, click on Programs, select accessories then select system tools, look for system restore then select the option select a different restore point, on the window you may see a list of restore points hoping your system restore was turned on in the very beginning, once you have selected a restore point keep on clicking next then a warning will show just click next again then it will restart your computer.
System restore allows you to restore to a date where you had windows working fine without any problems so if you can get a restore point before updating IE9 then it is possible that you may be able to fix you windows back the way it was.
I hope that this will help,
michaelvincentc
Dec 22, 2011 | E-Machines W Computers & Internet
How to access internet
hello there!
To connect to the internet follow the following steps:
  1. While in standby mode, press the OK button to connect to the internet
To disconnect from the internet:
  1. While in standby mode, press the Red end call button
  2. Press the left soft key for Yes to confirm Exiting the Web Browser
Please consult with your service provider for all other inquiries regarding the Mobile Web on the SGH-D900 handset.
Please make sure that you have a DATA PLAN from your provider or the set up for your GPRS settings.
For more information, The SGH-D900 uses PC Studio software for connectivity between your phone and a desktop computer. PC Studio is a Windows-based PC program used to easily manage personal data and multimedia files.
System Requirements:
The system requirements for Samsung PC Studio are as follows.
  • Windows 2000 or XP family
  • At least 300MB of free disk space
  • Interface devices such as USB, IrDA, and Bluetooth for the connection with the Phone
After installation, launch PC Studio 3.0. Be sure to have an active internet connection at the initial launch, as Live Update will automatically search for the most current version of the application and promptly install before use.
You can also update your Samsung PC Studio to the latest version manually.
Live Update can be performed as follows.
Run Samsung PC Studio. In the Launcher window, select the Tools > Live Update menu. (Make sure the PC is connected to the internet.)
  1. When the Welcome window appears, click the Start button.
  2. The available program update list appears. Click the Next button.
  3. Save all unsaved tasks and close all PC Studio applications. Click the OK button to proceed to the update process.
  4. When the update is done, click the Finish button to close Live Update. (In case the Live Update program itself has been updated, click the Start button to repeat steps 3 to 5 for updating other components.)
Hope it helps,
fossildude
Nov 09, 2010 | Samsung SGH-D900 Cellular Phone
Wont display the desk top
Try rebooting, tap F8 to get into the multi-boot options. Scroll down and choose "Last Known Good Configuration" windows should boot up normally. If you have made any hardware changes or if windows perfromed a corrupt update, that will require some additional help.
Jan 12, 2010 | ASUS Eee PC 701SD
No internet, task bar and strange "window" on my desktop...
Check and see if your wireless switch is off.
Plus linpus lite was made to run on Asian computers. Maybe your American computer can't run it.
Jun 30, 2009 | Acer Aspire One AOA110-1588 Notebook
WindowsXP
try and right-click on your task bar, then click on cascade windows. it is obvious that your PC has virus. you can either use the option of cascading or better -of just reinstall your windows and update ur anti-virus. good luck
May 20, 2008 | Microsoft Windows XP Professional With...
Acer Aspire One AOA110-1588 Notebook Logo
160 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
