Question about HTC G1 Smartphone
SPL update fail
I have a similar problem, can`t access to the boot screem, any helkp will the nice!
already try: HOME + POWER, CAM + POWER and nothing. Thanks in advance!
  • 813 Answers
Did you try to update your ROM? The SPL and IPL are like the BIOS of phone and in case they get damaged, the phone will not start.
Posted on Jul 02, 2009
Power failed during MSI P67A-C43 B3 bios update
Download the latest BIOS update from your computer manufacturer's website onto a USB flash drive. Refer to your user manual to obtain the manufacturer's website address. If the downloaded BIOS file is a zip archive, unzip the contents onto your USB flash drive. Jumper settings may need to be reconfigured on some motherboards to enter BIOS recovery mode. Most Intel-based motherboards have a jumper setting or switch near the on-board CMOS battery. The procedure for setting the jumpers will vary depending on your motherboard make and model, so refer to the motherboard documentation for specific instructions. Power on the computer and press "F2" to access the Setup Mode menu. If you are unable to access the setup menu, you will not be able to proceed with this repair. Take your computer to a repair shop, as the motherboard may need to be replaced. Use the arrow key to select "Boot Priority" or a similarly named field. Press the "Enter" key. Scroll down until "First boot priority" or "First boot drive" is selected and press "Enter." Select the USB flash drive as the first boot priority device. Press the "F10" key to save this setting and exit from the setup menu. Connect the USB flash drive to an open USB port on your computer. Then let your computer fully reboot. The USB flash drive should be detected and the BIOS should update automatically. When the update is complete, you may be prompted to restart your computer, or it may reboot automatically. If you are able to use your computer without any further problems of overheating or failure to recognize drives, your failed BIOS update has been resolved.
Apr 05, 2013 | MSI P67A-C43 B3 Desktop Motherboard -...
Failed BIOS update
CMOS battery.
hope this helps
Sep 11, 2012 | ASUS (P5RC-LA) Motherboard
Hi, unable to boot mc9090. (warmboot & cold boot) as its hanging on screen "booting system"
I am having a similar issue, i have tried all the solutions on the site including re flashing and factory defaults. but all fails. i am thinging of reflowing the boards then reflashing. i suspect that the rom has become corrupt or that the registory settings are iffy.
Jul 17, 2011 | Zebra Symbol Technologies MC909X-G Series...
MY HTC G1 STRUCK ON G1 SCREEN
when you stuck on g1 big screen, you need:
1. download the right g1 radio
2. download danger spl. be carefull with this, search in wikipedia about it
3. download the latest rom
4. copy all file (in zip) to micro memory
5. enter fast boot (home + power about 20 second)
6. updated files radio first, reboot
7. updated dangerspl, reboot
8. updated rom
9. do hard reset / wipe (alt w) via fast boot
all done
Dec 03, 2010 | HTC G1
My i-mate k-jam is not getting updated to windows mobile 6.1 or above. any solution for getting updated to the latest version?
down grade it to 1.01 both spl & ipl
then unlok it with wizard toll
enable rapi
sync it with active sync but dont bridge any connections with it.
then get rom upgrade utility upgrade it to 2.26 both ipl &spl
there you go its working again
if the sync is not working then turn off the device & turn it on on holding the cam button
disply screen will be tri colour with usb option
thendown grade it to spl & ipl 1.01
there you go .
Sep 14, 2010 | i-mate K-jam Smartphone
Unbrick my g1
You can unbrick it via JTAG solution ORT ( Omnia Repair Tool ) can repair G1 Software and boot releated problems as you mentioned
Best Regards Oz
Jan 20, 2010 | HTC G1 Smartphone
Computer won't turn on already replaced power
Try unplugging the PC for at least 10 mins. If that fails... it could be the BIOS failing to Boot. Leaving it unplugged my discharge the System and it may Boot, once it does it maybe best to update the BIOS. If the continues it will force you to replace the BIOS or the Motherboard. If the System is older than 3 years, I would replace the Motherboard and reinstall to a new hard drive and recover your data. Or buy a new system and recover your data by using a USB external HD Container.
Dec 30, 2009 | HP Media Center PC M260n (DF200A#ABA) PC...
Phillips model 19pfls422d/27 power light turns blue screem seems to turn blue no image on screem
your mainboard has failed and will need to be replaced you can try Andrews Electronics or Partsearch.com
Dec 10, 2009 | Televison & Video
Update bios systemsoft mobilepro bios ver1.01 for sis - the laptop can't boot from cd xp
your bios is not updated properly. try again. make sure there is no power problem while updating. update bios from sis official site only.
but i dint understand wheather u already updated n the after updating its not working or u r planning to update. if u r planning to update then see that the ata cable is connected to motherboard. set first boot device as cd rom. then check if it fails go for bios update.
Apr 29, 2009 | Asrock K7S8XE+ SIS748 (K7S8XE+RAID)...
My web cam wont work
No, most likely some resident software is accessing the camera, or the camera needs updated drivers. try updating to the newest software and make sure the cam software isnt booting up before the MSN client
Feb 26, 2009 | Microsoft LifeCam VX-1000 Webcam
HTC G1 Smartphone Logo
275 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
