Question about Air Tools & Compressors
My Craftsman 4 Hp. 15 gallon horizonal air wont tun on
My Craftsman 4 Hp. 15 gallon horizonal air compressor won't kick on. I left it pluged in one day. The next day it would not kick on to refill the tank. Very confusing nothing looks wrong at all.
  • 234 Answers
There may be a thermal overload reset button on the back of the motor that was tripped. If you press it in it should reset it.
If this is not the problem, post a comment with more details including model number for more advanced troubleshooting.
Thanks,
Tim
Posted on Jul 03, 2009
I am changing the belt on a oil less 33 Gallon vertical 1.6 hp Craftsman Compressor and want to know if the bolt that holds the piston rod on is left hand or right hand threads?
This is standard thread, right to tighten and left to loosen.
Make sure to put a small amout of loctite on the threads when you put it back together.
Oct 12, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
A/C will only pump 30-40 lbs, but keeps running.
Maybe your unloader valve is stuck or damaged. This is found in the switch assembly and if it is faulty you should be able to hear a constant hissing noise from the switch .
Jun 05, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
I have a craftsman 1.5 hp/ 2 Gal. air compressor and everytime i go to turn it on it kicks out the breaker. model #921.152100 capacitor ????? plaese help aroberts616@aol.com
Hi there. Plug your compressor in as close to your circuit box as you can on a circuit that is dedicated to that outlet
What is happening is this. You have a 15 amp circuit and a 15 amp draw on your compressor. No wiggle room at all. If you need to get the air a long ways use air hose and never an extension cord. Joe
May 29, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air compressor won't go over 40 psi?
my ace air compressor which is 26 gallon 5 hp will not get over 60psi what is wrong with it please?
Feb 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Motor runs pressure stays around 25psi
if they are oilless compressors then the rings are worn
Jan 15, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Compressor shuts off before reaching max pressure
Yes,but if the max is 125 you don't want to increase it above 110 and set off the pressure relief valve.
Jul 21, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
I have a electric air compressor craftsman 3.5hp 15 gallon it wont start back up when air is low
The pressure switch controls the cut-in and cut-out points for the motor. Some switches have a differential adjustment besides the pressure adjustment. The differential controls the spread between cut-in & cut-out, (say in at 80 PSI, out at100 PSI)
Try looking for these if you didn't get a manual.
Good luck
Apr 26, 2009 | Craftsman Air Tools & Compressors
Air Tools & Compressors Logo
238 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
