Question about Jenn-Air JGD8130 Gas Cooktop
Jenn-Air JGD8130ADS We discovered that our new Jenn Air JGD8130 downdraft gas cooktop provides in our new kitchen is inadequate to properly boil pasta or fry fish. The burners of our 40 year old Hardwick gas range that is sitll operational in our old kitchen is much much hotter. The specs for this cooktop state that the two right burners are rated at 9,000 BTU each and the two left burners are rated at 7,500 BTU each. I confirmed that the burner orfices installed on the cooktop are for natrural gas and not propane since we are connected to a natural gas utility system. . I also noticed in the specs that the orfice for the 9,000 BTU burners have a diameter of 0.037 inches while the 7,500 BTU burners have a orfice diameters of 0.033 inches . Can I either purchase larger diameter orfices or have the existing orfices bored out at a machine shop to increase the BTU rating? In comparing the areas of these different orfice diameters I calcualate that I would need an orfice diameter of 0.044 inches (approx 3/64") to obtain a 12,000 BTU burner rating.
  • queen_ncm Apr 13, 2009
    Hi, I have the same question. i was wondering if you got your answer yet after 2 years.
2 Suggested Answers
SOURCE: Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Posted on Sep 08, 2008
Jenn-Air Cooktop JED8430BDS
That is an obvious burned wire, or burned thermal cutoff etc
Nov 09, 2013 | Jenn-Air JGD8130 Gas Cooktop
Stuck knob
if this is a oven you are lighting would be oven thermostat would contact surplyer as faulty goods dont try repair as will void garantee
Jul 29, 2012 | Jenn-Air JGD8130 Gas Cooktop
I used my grill for the first time, & the downdraft didn't work we'll, the house filled with smoke & eventually the downdraft shut off and I had to finish cooking in a pan. My Jenn-Air is...
The downdraft is electric so there must be something malfunctioning with it. It is a high volume downdraft fan that is to be vented to the outside. Could it be that something has clogged the vent hole up, not allowing the fan to evacuate the smoke?
While I am not a big fan of Jenn-Air, their fans are usually high quality if they are installed correctly, with the proper vent lines.
Jul 06, 2011 | Jenn-Air JGD8345 Gas Cooktop
Replacing an old jenn air electric cook top with new 30" down draft gas cooktop. Need to know how to secure the cooktop to the granite countertop.
You should just be able to set the cooktop in after you attach the downdraft, usually there are tabs on the downdraft that clamp on to the granite cutout. There is probably a closed-cell foam strip that runs under the lip of the cooktop, I would just make sure it seals to the granite properly (no gaps) and put a couple dabs of silicone in between the lip of the cooktop and the granite. Usually the cooktop is heavy enough that the silicone will keep it from moving around.
Mar 25, 2011 | Jenn-Air 30 in. Expressions CCGX2420 Gas...
Downdraft vent on jenn air cooktop
How do you get the inside area of the vent clean from the grease and oils where the filter is?? I have a rectangular box style downdraft that the vent goes into the floor, I pulled the filter, but the box is to slender to get an arm into to scrub the grease....... does the bottom come off, or is it a sealed unit? How do you get all the brease from the bottom if you cannot reach it?
Jul 09, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
make sure you have the correct orifices, make sure you have good gas pressure and make sure pressure regulator is ok.
also if the unit has been in service for a while check the orifice for build up a wire or needle will work to knock out any build up
Apr 23, 2008 | Jenn-Air JGD8130 Gas Cooktop
grab hold of the installed burner cartridge at he top of unit and pry up slightly, should lift up without much effort, if not try lifting front side. they jsut lift up and slide back in no screws hold them in place
Feb 21, 2008 | Jenn-Air JGD8130 Gas Cooktop
Jenn-Air JGD8130
Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
Jenn-Air JGD8130 Gas Cooktop Logo
502 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
