Question about Maytag CWE5800A Electric Double Oven
Any advice on fixing CWE5800ACE with F3 error code? Thank you.
    President:
  • 1,865 Answers
Whirlpool GR396LXGQ oven comes on by itself & goes into clean cycle, code reads E2 -F3-
Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 07, 2012 | Whirlpool Ovens
F3 error when turning on oven.
The F3 error code indicates a problem with the sensor circuit; this doesn't always mean that replacing the sensor will solve the problem. The harness to the sensor could be open or shorted. You will need to use a meter to check the sensor circuit wiring harness in order to come up with a final diagnosis. You will need to access the EOC electronic oven control & check the sensor circuit from there for a starting point. The value of the sensor should be 1090ohms + or - 5% @ 75 degrees.
Jun 11, 2011 | Kenmore Ovens
Oven has a f3 error
Hi angelice_wil,
The F3 fault code description is a shorted or open oven temperature sensor. The easiest way to correct this error is to check the sensor harness and harness connection between oven sensor and oven control. If you noticed that the wiring is all ok, replace the oven temperature sensor (RTD).
Hope it helps.
Thank you for using FixYa.
Apr 01, 2011 | Maytag 24" Built-In Single Gas Wall Oven -...
Amana Self-cleaning Oven flashes F2 and F3 and beeps. It doesn't get real hot. Although it does heat up not the appropriate temperature.
Hi, F2 error code on the Amana Oven means "Oven too hot" You have to replace Oven temperature sensor to fix it.
F3 error code means "Open or shorted oven temperature sensor". Yo also have to replace Oven temperature sensor to fix it.
Summarily, both code has to do with the temperature sensor which you need to replace...
Oct 23, 2010 | Amana Ovens
Error code shows E1 -F3- on a
F3 E1 IS THE OVEN SENSOR IT IS ON THE BACK WALL HELD IN BY TWO SCREWS IT LOOKS LIKE A ROD,MOST OF THE TIME YOU CAN PULL ITHE WIRES THROUGH OR YOU MAY HAVE TO DISCONECT FROM BEHIND
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 12, 2010 | Kenmore Ovens
Jenn-air SVD48600P oven will not work / F3 error . I recently replace the expense control / clock unit on my oven because it would not heat. This was advice from repair person. Once replaced the over...
Hi jmhostetler9,
This F3 that keeps flashing on your oven is caused by a shorted or open oven temperature sensor (RTD). To fix this problem check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model # ready when you call.
Hope this helps.
Dec 22, 2009 | Jenn-Air JJW8530C Expressions Collection...
F2 and F3 error messages on Tappan wall oven model 12-4980 10/03
These are the F2/F3 error codes for a Tappan oven
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
please take the time to give this solution a fix ya rating.
clarkco
Feb 09, 2009 | Tappan Ovens
My oven displays F3 and beeps
f3 error code is generally a bad oven sensor. not every code is universal, but most manufacturers use the f3 error code to indicate a sensor issue. it is an easy fix if you want to tackle the problem yourself. Joe
Nov 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Error codes
Hello raco1
Welcome
I need your model number to look up the fault code !!!!
You said , you see fault codes, FD F3 and E2 F3 is showing up on display pane
Looks like this may be your problem
F3 - E2 - Oven to hot -Replace oven temperature sensor
Waiting for your response.
When responding send me this whole communication . Not just your answer!
Thank you Huuum.
Oct 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Maytag CWE5800A Electric Double Oven Logo
290 people viewed this question
Top Maytag Ovens Experts
Oloyede Monsuru
Mack Baxter
Craig Butler
Craig Butler
Are you a Maytag Oven Expert? Answer questions, earn points and help others
