Question about Samsung SCH-a670
No power the phone was going on then off very quickly. It will not power at all anymore. Is this a battery problem or the phone itself. I want the pictues hat are currently on it. Is it possible to get those?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
It could be a battery issue. but i strongly suggest that you go to your service provider store to use and test a different battery on your phone to isolate the issue. if battery is the main issue, then you might need to replace it and buy a new one. then you can transfer the pictures from your phone to your PC for example.
Posted on Jul 02, 2009
Blackberry bold 9300 no power
Could either be a faulty battery, power supply or phone. If you've got a local phone shop nearby take it in and see if they could give it a quick test
Nov 11, 2013 | RIM BlackBerry Bold 9000 Smartphone
N72_5 Nokia it switch off itself after several minutes
Hello There! You'll have to try buying a new replacement battery for your mobile phone. There's most likely a battery failure which is causing your phone to go on and off numerously.
I wish I helped you! Let me know if you need anymore help! Don't forget to rate! :)
Jan 14, 2011 | Nokia N72 Cellular Phone
Turns off on its own
If Your phone turns off on its own, then it means there is something cutting off the power supply while it is at work. Most likely the battery is sagging inside the unit hereby causing the power to fail at some interval. I will advice You prop or pad the battery, before You do that, i suggest you open the battery cover, remove the battery, then you use a dry piece of cloth to clean the metallic sheets that is inside the phone(terminals) then you scratch off the surface of the metals on the battery with a screwdriver, do not scratch it too hard. Then you cut and fold a little paper to pad the battery to sit well inside its compartment. Then you power on the phone. This time take not of it, it will not power off itself anymore.
Jan 13, 2011 | Samsung Captivate Cell Phone
I have an HTC HD, from 2 days ago, when i connected it to power as normal for charge, the light on top of power botton turned on and never gets off after that?!!! it makes the battery flat so quick! what...
Hello :
It seems that the battery is dead [ can't be recharged anymore ] even if you see a light when you plug the charger in the outlet . I recommend you to replace the battery .
good luck .
please rate !
Apr 03, 2010 | HTC Touch HD Smartphone
My k800 sony ericssion batery goes down very fast when i use it, what should i do?
problem can be solved.Does the get hot?, if not that means it is the battery of the phone.
The cell of the battery is too weak and is dead and can power the fun anymore and needs to be changed.
Replace the battery and make sure you charge it until it shows 100 percent before you start using it otherwise the battery cell will run down so quickly.
Take care.
Mar 19, 2010 | Sony Ericsson K800i Cellular Phone
My nokia 6230i gets power off itself despite my changing Battery? it also runs out of charge very quickly, why?
Sudden discharging of battery indicates that it is time to replace it.If again the problem exists re- install your phones software..
Jun 27, 2009 | Nokia 6230i Cellular Phone
Phone will not take charge
I have the same problem with my phone i really don't know what is going on~!!!
Sep 03, 2008 | RIM BlackBerry Pearl 8100
Phone is discharging battery
I assume you mean the phone is discharging it quickly, probably not capabale of holding a long charge anymore, you can get batteries here - Panasonic KX-TG2422 battery
Oct 30, 2007 | Panasonic KX-TG2422W Cordless Phone...
Samsung SCH-a670 Logo
94 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
