Question about Sony Walkman NW-A808 MP3 Player
Won't recharge, won't reset
It won't recharge, and it freezes when i reset it. It hasn't been dropped on the ground or in water. Whats going on?
  • ilandgyrl21 Jul 01, 2009
    It wasn't dropped in water or dropped at all for that matter, it just quit working. When i try to reset it, it froze halfway twice and now won't reset at all.
  • 508 Answers
Soak unit it rubbing alcohol if dropped in water(water has deposits when dry that short stuuf out alcohol cleans and leaves no residue)let soak for a few hours(make sure battery is out)then shake out excess alcohol and let dry for a day in warm dry area.clean contacts on battery with alcohol ans qtips and reinstall battery then try to charge-same thing happened to me tried this and worked fine hopefully didnt short chips!!!!!Best of Luck to you!!!use 90% rubbing alcohol!!!let me know if worked!!!
Posted on Jun 30, 2009
My gages won,t reset when I go to start my truck.when that happens it won,t start when thay reset it starts whats my problem to look at
Some instrument clusters may be able to self-test, it will turn warning lamps on and off, plus, sweep the gages, w/o outside input, meaning buss or serial data. If it passes that test, it is considered to be ok.
Yes, checking voltage and ground for instrument cluster is always a good idea, when problem is ongoing. At least, one voltage feed to instrument cluster should go hot with key on, could be problem in that area?
Are there any applicable trouble codes?
I can't look up much info w/o year--make--model?
Apr 23, 2016 | Cars & Trucks
My battery for my mp3 won't last long
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 16, 2012 | Coby Audio Players & Recorders
Battery will not hold charge
If the rechargable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 14, 2012 | Sony Nwz-w262 Water Resistant Mp3 Player...
How to reset battery
You cannot reset a battery to restore it back to its normal capacity.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 25, 2012 | Lenovo G555 Laptop
My aspire 5100 wont hold charge without charger
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 05, 2012 | Acer Aspire 5100 Notebook
My Go gear vibe 4gb MP3 battery is flat and won't recharge.
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 03, 2012 | Philips GOGEAR SA6045 MP3 Player
I have a sony cybershot dsc w120 camera and it turns on and maybe lets me take 1 or 2 pictures before shutting off (sometimes with the lens still out). It hasn't been dropped or exposed to water, so I
Things to check first for a camera that won't turn on, or works intermittently are the battery contact points, ensuring that they're clean, and making good contact with the battery. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 23, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
I haven't used my calculator in some time. Now when I go to use it, it won't turn on. I've pressed on and clear and reset. Nothing. It is solared powered and its not like I just change the...
If it is solar powered and hasn't been used in some time, the battery may have died, permanently. If there is no battery to replace then it is broken forever. Sorry.When batteries are left without juice for a long period of time they die, and cannot be recharged.
Sep 14, 2011 | Office Equipment & Supplies
My dell laptop doesnot work proberly if we power on a dell laptop. adopter let should be off then remove from the lap power will be on. whats the problem
Aug 16, 2011 | Computers & Internet
Sony Walkman  NW-A808 MP3 Player Logo
227 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
