Question about Garmin GPSMAP 295 GPS Receiver
Will not run for more than a few moments off battery power
Mine runs perfectly from the external cig. power as well. The promlem for me is that im in a flying club with 5 planes, and half the cig lighters work and the other half do not. What i think im going to do is get a female adapter for the cig lighter and a battery case for 6 AAs and just wire the case to the adapter, to mimic external power. The problem is the two golden contacts on the back of the betery pack, when one gets pushed in too far, it no longer makes a connection to the gps. inop. ill post back after i try the external power with a battery
  • brandonmo407 Aug 14, 2009
    the external power pack i built works perfectly. The battery harness i bought holds 8 AA batteries, and the female 12 volt connector works fine. I soldiered all the connections,and fit it all in a small box. I recently used it on a 3 hour flight to port aransas, no flaws what so ever. All the parts you need can be bought at redio shack for under ten dollars. i estimate the battery pack will last about ten hours before the batteries need to changed. Any questions id be glad to post more, or send pictures to your email or whatnot.
    Problem Solver:
  • 6 Answers
Watch out for that - if you use regular batteries, they probably won't like that. They're not designed for recharging. The GPSMap 295 can batteries and external power at the same time because it has circuitry that switches between the two - power is not being sent through the batteries.
This guy - http://www.fixya.com/support/t2487552-garmin_gpsmap_295_will_not_run_from - opened his up and found a loose screw. I have the same problem with mine which I'm about to try. This may help you as well.
Posted on Aug 14, 2009
Caldina
in the fuse box.
on many cars there is no fuse, only a circuit breaker.
the breaker is far better in cold weather (and huge ice drag)
USA answers only !!!!
im on alldata.com , so can you, look.
and here is what i see on your schematic.
the CIG radio fuse. does this, 15amps
so dont run cig and windows at same time or pop goes the weasel.
if cig and radio work, its not the fuse.
log in and look.
Dec 12, 2013 | 1996 Toyota Camry
Pulsar el4: unit only delivers power to connected devices when running from batteries. When external AC is connected, unit cuts power output.
replace capacitor c014 with a new 47 uf one, this fixed mine - for pulsar el4 and ES4 - see messageboard here https://groups.google.com/forum/#!topic/fr.sci.electronique/Jq_WQMpl8QI
Jun 11, 2013 | MGE UPS Pulsar EL4 (83004) UPS System
How to get drivers for cig external dvd drive
how do I get drivers for my CIG external drive DVD?- using an HP11 tried VLC & other free players but all say cannot open disc.
Feb 10, 2013 | ASUS P5K-V - Motherboard - ATX - iG33 -...
HP Pavillion dv9000 screen problems
u better remove ur ram and reinsert in slot if you have two rams in mother board please take out one ram from one slot and check if it same take out another ram from slot and check it
Oct 12, 2017 | HP Pavilion dv9000z Notebook
NO BATTERY POWER,ONLY EXTERNAL SOURCE
check contacts inside the battery compartment are perfectly clean and install NEW batteries (alkaline good quality). If remains the same problesm, needs to be repaired at Garmin´s shop
Mar 17, 2010 | Garmin GPSMAP 295 GPS Receiver
First time charging up of archos 5,it has now been charging for about 14-15 hours. but the green light did'nt blink yet. it says after fully charge, the green light blinking. what can be the promlem about...
@wilkerwkocer
On an Archos, battery is fully charge when the CHG LED light is flashing, while that light is ON all the time, the unit is still charging.
Now, in order to charge your Archos you must leave it on Suspended mode, by holding the Power button for about 4-5 seconds until it says "Suspending", DO NOT leave it on completely "Shutdown" mode, or your battery will never charge, and you are also risking the life of your battery by doing so.
So in other words:
1) On a PC via USB it should take around 8 hours to charge, while connected to an Archos mini dock, battery dock, or DVR Station, it should take around 3 hours to fully charge.
2) Leave your unit completely "Shutdown" (hold the Power button and wait 10 secs. or so until it says "Shutting down" and let it go off.
3) Connect it to your power source, either USB on computer, or external charging device as mentioned above, it will come back on, the two LED lights CHG and Power will come on, leave it like that, and after a few minutes the unit will go into Standby/Suspended mode by itself, and there is when you are charging your battery the right way.
3) Wait 8 hours if connected to your PC, or 3 hours if connected to an external power supply (as described above). If still after being in suspended mode (not completely off) your CHG light isn't blinking after the 8 hours on PC, 3 hours on external power supply, then suspect your battery is defective.
In that case, if the unit is still under warranty contact Archos, if it is out of warranty. If it isn't under warranty, you can buy a replacement battery on eBay and either replace it yourself, or find someone with the technical skill to do it for you.
I hope this helped you.
Mar 11, 2010 | Archos Internet Media Tablet MP3 Player
Cig power/3.5 jack problem
You have to be using the wrong cable, my friends cable comes with 4 tips , i believe the 3 tips give you this problem
May 27, 2009 | SanDisk Sansa e260 MP3 Player
Battery power trouble
I have discovered an intermittent problem on my 10 year old 295 when powered by batteries.
It appears that the chrome plating is de-laminating from the battery contacts that are either side of the back panel attachment hole. At first glance it looks perfect but if you run a fingernail or other small item across the face of the contact you will see and hear a movement as if there a a loose layer of foil over it. This is causing all manner of faults including 'external power lost, shut-down in 30 seconds' when the external power was not even connected at all!
Jan 03, 2009 | Garmin GPSMAP 295 GPS Receiver
Gateway 400sd4
You should try plugging in an external CRT or LCD monitor. Most laptops will automatically enable this port when you connect a monitor and reboot, but you may need to hit some combination of keys on the laptop if you don't see anything.
You should try this to see if the laptop is running properly other than the internal LCD or VGA hardware.
Dec 16, 2007 | Gateway 400SD4 Notebook
Garmin GPSMAP 295 GPS Receiver Logo
82 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
