Question about Microsoft Office Professional 2007 Full Version for PC
Removal of genuine software from pc
I am trying to remove wga fro window task manager but it wont end
  • 46 Answers
Microsoft is smart they wont let you close the window without you activating the software first! if you need a crack click here
Posted on Jun 30, 2009
Remove software counterfeiting on my screen
This is one of the most common problem windows users face... This occurs when you are using an illegal copy of windows or if your product key is already in use on different pc. Well this is very easy to solve. first go to c\windows\system32\wga keep that wga selected... then go to task manager and there you ll find wga.exe(something like that)
end task it.. immeideatly delete that wga.exe file in system32.. Thats it...
Dec 06, 2010 | Computers & Internet
You may be a victim of softwwre counterfeiting
Microsoft has started bugging the users of non genuine copies of Windows. If you are also running a non genuine or pirated copy of Windows then there is a full chance of you getting this notification one day or the other.
These notifications start coming back again after some time and do not feel good. Though I never encourage piracy but here is how you can remove this problem:
1. Before doing anything serious try restoring your system. If the problem is occurring after the Windows Update then System Restore will surely help.
2. But if it does not then do try this, launch Windows Task Manager.
3. Locate the process "wgatray.exe" and end it.
4. Log in into the Safe Mode and delete the file WgaTray.exe from c:\Windows\System32
5. Also delete the WgaTray.exe from c:\Windows\System32\dllcache
6. Type regedit in Run to open Registry Editor, navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify key.
7. Delete the folder WgaLogon and all of its contents.
8. Restart the PC normally.
Update:
Download this WGA remover tool called RemoveWGA.exe, just download it and run.
Oct 21, 2010 | Microsoft Windows XP Professional for PC
How to uninstall the software counter feiting
To get rid of the WGA notification that intends to remind you that your Windows is not validated, you can buy a validly licensed copy of genuine Microsoft Windows.
Update: Bypass WGA Validation and Disable WGA Notifications Warning Message
First Method :
Launch Windows Task Manager.
End wgatray.exe process in Task Manager.
Restart Windows XP in Safe Mode.
Delete WgaTray.exe from c:\Windows\System32.
Delete WgaTray.exe from c:\Windows\System32\dllcache.
Launch RegEdit.
Browse to the following location:
Delete the folder ‘WgaLogon’ and all its contents
Reboot Windows XP.
Note: With this method, you may be prompted to install WGA Notifications again which can still be unselected.
Second Method :
Note: Again, you may be prompted again to install WGA Notification, so it must be bypassed.
Third Method :
By disabling and renaming the files “WgaLogon.dll” and “WgaTray.exe” in C:\WINDOWS\system32 folder by using the program Unlocker seems to get rid of all the nags/popups.
Fourth Method :
Clear the contents or create a new empty data.dat for WGA, and make data.dat Read-Only and Hidden as detailed here.
The following step basically is the same with the above data.dat method, only different is that you no need to create any file in the WGA data folder:
Launch Windows Explorer and go to C:\Documents and Settings\All Users\Application Data\Windows Genuine Advantage\data
Go to Tools -> Folder Option -> View.
Select (click) Show Hidden Files and Folders option.
Unselect (uncheck) Hide Protected Operating System Files option.
Click OK.
Delete everything in the data folder Or other wise use all methods it will work out.
OR
click on this link http://magicaljellybean.com/keyfinder/old.shtml
go here .. and download keyfinder v 1.51.zip
download that and open
and go to option change windows key
then enter this key
V2C47-MK7JD-3R89F-D2KXW-VPK3J
now
your windows key is now genuine and u’ll not get any such pop ups…..
If still your problem is not solved then search google for the windows genuine advantage validation removal tool and download it and install……That will surely remove the problem…..
Please rate me if this solution works for you
Thanks......Have a great time
Jun 15, 2010 | Intel Pentum 4 3.2Ghz System (SYP32) PC...
How remove micrisoft genuine
  1. Log on to the computer by using an account that has administrative permissions.
  2. Make sure that the WGA Notifications version that exists on the computer is a pilot version In this case, you can uninstall versions 527-532 only (Note: the steps should disable other version of WGA Notifications too). To find the WGA Notifications version, follow these steps:
    1. Click Start, and then click Control Panel.
    2. Double-click Add or uninstall Programs, locate and then click Windows Genuine Advantage Notifications, and then click Click here for support information.
    3. In the Support Info dialog box, verify the version number, and then click Close.
  3. Rename the following files by changing the extension to .old: Rename %Windir%\system32\WgaLogon.dll to %Windir%\system32\WgaLogon.old
    Rename %Windir%\system32\WgaTray.exe to %Windir%\system32\WgaTray.old
  4. Restart the computer.
Then,
  1. Lauch Windows Task Manager.
  2. End wgatray.exe process in Task Manager.
  3. Restart Windows XP in Safe Mode.
  4. Delete WgaTray.exe from c:\Windows\System32.
  5. Delete WgaTray.exe from c:\Windows\System32\dllcache.
  6. Lauch RegEdit.
  7. Browse to the following location:
  8. Delete the folder ‘WgaLogon’ and all its contents
  9. Reboot Windows XP.
This should resolve the issue... Lemme know what happened...
May 04, 2010 | Microsoft Windows XP Professional for PC
Help plsss
Just insert the original seriel key
  1. Download Windows Product Key Update Tool (KeyUpdateTool.exe) from Microsoft.
  3. Enter the product key found on your COA where requested, and then click Next to begin the update. toolscreen2_en.jpg
  4. Once the update is complete, click Finish to restart your computer. When your computer restarts, your computer’s product key will match the COA product key. If this tool fails to change your product key to match your COA, contact Microsoft Support. toolscreen3_en.jpg
  5. After updating your product key you will be required to activate Windows. Once Windows is activated, you can verify that your copy of Windows is genuine by going to http://www.Microsoft.com/genuine and clicking Validate Window
Feb 05, 2010 | Microsoft Windows XP Professional for PC
My desktop is black and how can i remove victim of software counterfeiting easy?
Download this file:
When finished, right click the file and choose extract, finish the wizard and open the extracted folder
1. Copy ALL the files inside the "files need to be copied" and Paste it on C:\WINDOWS\System32
2. CLICK ---> start ----> run and type "instexnt install" (without quotations).
doing this, Your Windows Xp Copy Will appear genuine for LOOPHOLES Microsoft
4. restart your computer OR add the registry file "1.reg" to your registry .
You can Install Windows Media Player 11 for Windows XP (I guess you know what it is)
Windows Defender (Protects you from Spyware)
Microsoft Security Essentials (Protects you From Virus)
Microsoft Calculator Plus (Conversion Feature)
*********ALL FOR FREE!!!**************
And many many more! See how you can easily FOOL Microsoft!
** You can use the file "Wga.exe" to clear Microsoft Notifications.
By Gian Franco Briones Dy
free.to.rhyme@live.com
Jan 22, 2010 | Microsoft Windows XP Professional for PC
I can't end wgatray.exe by task manager nor delete it by using shift+delete havig said I 've already opened C:windowssystem32wgatray.exe.
wgatray.exe runs in the background to validate your Genuine Windows XP software against a list of serial numbers that are blacklisted by Microsoft.
If your system is running pirated XP, the wgatray process will show a pop-up warning - "This copy of Windows XP is not genuine" - this is no error or virus, its a reminder from Microsoft to go original.
Though you can temporarily disable Windows Genuine Advantage notifications by removing wgatray.exe or wgalogon, this is never recommended since you will not be able to download important security updates and patches from Microsoft Updates website.
If you are running a counterfeit or illegal version of Windows XP, rather than hunting for a wga workaround, just get the authentic GGK kit from Microsoft to convert your pirated XP into Genuine software by changing the XP product key - completely legit way to make Windows genuine and you need not reinstall your Windows XP.
The WGA patch is installed if the user has opted to automatically update Windows via the Windows Update Website or if a XP users manually downloads the latest Windows updates.
Dec 22, 2009 | Microsoft Office 2003 Basic Edition...
I have problem with my desktop.
Try to follow some of these methods:
First Method
  6. Lauch RegEdit.
Second Method
Another alternative suggested by dman is by using System Restore to restore the PC to a previous restore point that WGA Notifications hasn’t kicked in, and then carefully stop KB905474 from been applied to the system. To use System Restore, go to Start -> All Programs -> Accessories -> System Tools -> System Restore.
Third Method updated
This method involves using a cracked version of LegitCheckControl.dll to replace the original copy of LegitCheckControl.dll, and thus bypass the WGA validation and make Microsoft believes that your copy of Windows is genuine. To get rid of WGA Notifications warning messages, the patched version of WgaLogon.dll and WgaTray.exe to replace the existing files.
To apply the patch by replacing the files manually, try to end the respective processes in the Task Manager before deleting the existing files. Most likely is you will have to restart your PC in Safe Mode in order to replacing the original copy of LegitCheckControl.dll and related files. However, there has been automatic updater and even cracked WGA installer that automatically apply the patched version of WGA files.
Latest Update for WGA version 1.5.708.0 latest
Download cracked and patched version of LegitCheckControl.dll with thanks to Danny.
Latest Update for WGA version 1.5.554.0 latest
Download cracked and patched version of LegitCheckControl.dll, WgaLogon.dll and WgaTray.exe for v1.5.554.0 of Windows Genuine Advantage Validation Tool and WGA Notifications.
rate me if this works.
Mar 22, 2009 | Microsoft Windows XP Professional With...
Getting nonerasable warning from Microsoft!!!!!!!
You seem to be a victim to piracy from your local vendor. You can report him to Microsoft and receive a finder’s fee, which isn’t going to cover the cost of new Windows XP. So here are some alternatives.
With new release of WGA, some methods no longer works, and some has been updated. Several methods that has certain success on certain people, you may try until you success.
Official Method by Microsoft - more information here. http://www.mydigitallife.info/2006/06/28/official-ways-to-disable-or-manually-uninstall-the-microsoft-windows-genuine-advantage-notifications-from-microsoft/
or:
First Method
  6. Lauch RegEdit.
Second Method
Another alternative is by using System Restore to restore the PC to a previous restore point that WGA Notifications hasn’t kicked in, and then carefully stop KB905474 from been applied to the system. To use System Restore, go to Start -> All Programs -> Accessories -> System Tools -> System Restore.
Download http://www.mydigitallife.info/2006/09/27/remove-bypass-patch-and-disable-microsoft-windows-genuine-advantage-wga-validation-version-157080-with-legitcheckcontroldll-crack/
Download http://www.mydigitallife.info/2006/10/08/crack-and-patch-to-bypass-and-disable-wga-genuine-windows-validation-and-notifications-version-155540/ of Windows Genuine Advantage Validation Tool and WGA Notifications.
In the short of it, sometimes it worth to just get a legitimate copy so your problem will go away. Unfortunetely being the victim really sucks, because this will for every be a problem if you do any updating of MS software. If you look around (eBay etc) you may find some pretty good deals on Windows XP.
My best of luck to you.
Mark
Dec 31, 2008 | Microsoft Windows XP Professional for PC
Microsoft Office Professional 2007 Full Version for PC Logo
80 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
