Question about Sony STR-DE825 Receiver
A "protector" warning appears when turning on.
When powered on, a warning comes on indicating "Protector" and it will not function.
  • 52 Answers
There could be a short in one of the connections or your power supply could be fried also ive seen some models with internal fuses that have blown
Posted on Jul 02, 2009
My Buick 2004 rendevous,my door ajar light stays on and it dings, and the locks, lock and unlock a the while when driving
Probably the switch input to the BCM is bad . door ajar switch .
The BCM is also capable of commanding other vehicle systems to control functions that are not directly wired to and/or controlled by the BCM. The BCM accomplishes this task by sending specific messages on the class 2 serial data link. The vehicle system capable of performing such function will respond to the BCM message.
The BCM controls/monitors the following functions:
• Audible warnings
• Indicators control
• Interior lighting
• Exterior lighting
• Power/automatic door locks
• Keyless entry
• Content theft deterrent
• Personalization
• Serial Power Modes
• Electrical Power Management
Audible Warning
The body control module (BCM) provides the following audible control functions. Some audible control functions may be controlled by other systems through the class 2 serial data link:
• Headlamp on reminder
• Key in ignition reminder
• Personalization mode
• Delay locking indication
• Keyless entry programming/diagnostic mode indication
Indicator Control
The body control module (BCM) provides the following indicator control functions through the class 2 serial data circuits. Some indicator control functions may be controlled by other systems through the class 2 serial data link:
• Door ajar
• Liftglass/endgate ajar
• Park brake
• High beam
• Park lamp malfunction
• Service vehicle soon
• Security LED
• Battery
Door Locks Go Crazy 1
Door Locks Go Crazy 2
Door Locks Go Crazy 3
Dec 05, 2017 | Buick Cars & Trucks
Tip
Surge Protection
Here is a few tips to look for in a good surge protector:
1. Response time should be less than 1 nanosecond.
2. Energy absorption/dissipation should be at a rating of 600 joules or more.
3. Clamping voltage should be 330 V to 400 V. Generally, a clamping voltage more than 400 V is too high.
4. Get one with a an indicator light that tells you if the protection components are functioning. All MOVs (Metal oxide varistors (MOV) are semiconductors that protect electronic components and systems from transient voltages) will burn out after repeated power surges, but the protector will still function as a power strip. Without an indicator light, you have no way of knowing if your protector is still functioning properly.
5. Get one that has self test function. A button you push to test it.
on Oct 07, 2010 | Computers & Internet
Fuses ok,light in dash tested and works. But check engine light does not come on when you turn on the ignition. What else should I check? This is a ford ranger XLT 4x4 4.0L V6-245cid engine (pushrod)
The instrument cluster (10849) carries out a display proveout to verify that all warning/indicator lamps and monitored systems are functioning correctly. When the ignition switch (11572) is in the ON position with the engine (6007) off, the following indicators will illuminate:
  • CHECK ENGINE/malfunction indicator lamp (MIL).
  • CHECK GAGE warning indicator.
  • Charge system warning indicator.
  • Anti-lock brake warning indicator (ABS).
  • Safety belt warning indicator (60second proveout).
  • Air bag indicator.
  • An indicator is inoperative - CHECK ENGINE/malfunction indicator lamp (MIL)
  • Bulb.
  • Circuitry.
  • Instrument cluster printed circuit.
  • Powertrain control module (PCM) (12A650).
  • GO to Pinpoint Test N .
Feb 15, 2016 | Cars & Trucks
How to solve sony dav -dz340k Push Power Protector
my dav-340k was working perfectly then after sometimes it lost sound output,even with the full volume no sound at all n no any warning n nor indication. what could be the problem?
Nov 02, 2012 | Sony Dav-dz340k 5.1 Channel DVD Home...
My lg tv won't turn on after a lightening storm
Your surge protector did not function properly, contact the manufacturer of the power strip.
Jul 05, 2012 | LG 55 55LW5600 3D LCD TV
Model 2461 - "check
Power light indicators on flashing red as warning that battery is almost depleted of functionality. ascertain that devices with extension cables deriving power from elsewhere are plugged in to reattain power to acheive regular functionality. For example, devices with red light indication as power warning would also flash yellow or green when in full power charge from another source. refer with devices user guide or manual for refering, diagnostics.
Jul 20, 2011 | Vtech VT 2461 Cordless Phone
When i turn on my tv the little red light blinks. THen the sound comes on but no picture. After a couple of seconds the red light starts blinking again and the standby light comes on and then nothing.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 16, 2011 | Sony KP-51HW40 51" Rear Projection...
Red standby button comes on after power comes on. It blinks 13 times, pauses few seconds, then 13 more blinks
May 25, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Hi,I have a 2000 Yamaha R1, This red light with a picture of a tap comes on every now and then in the morning when the bike is cold but goes away when the bike is heated, what could this be? The right oil...
Mate, what you are describing an Engine trouble warning light.
This warning light comes on or flashes when an electrical circuit monitoring the engine is defective. When this occurs, have a Yamaha dealer check the self-diagnosis system.
What it does is to tell you something is wrong in your various electrical circuits.
If any of those circuits are defective, the engine trouble warning light will come on, and then the multi-function display will indicate a two-digit error code (e.g., 11, 12, 13).
If the multi-function display indicates such an error code, note the code number, and then have a Yamaha dealer check the motorcycle.
As all those require a specialized testing tool I would recommend you to take it to a dealer unless you know what you're looking for.
Good luck and don't 4get to rate the advise. Cheers
Dec 09, 2010 | 2001 Yamaha YZF-R1
Problem with power cord/AC adaptor...maybe?
I would just go buy another battery charger pack. They are like 75 dollars to buy. Sounds like yours might have a short in it!
Mar 26, 2009 | HP Compaq nx6110 Notebook
Sony STR-DE825 Receiver Logo
400 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
