Question about Jl Audio 500/1 Car Audio Amplifier
Low ohm light wont go off
Ive been running 3 amps in my explorer. 2 500/1's and a 300/4. the 500/1's run two 10w7's sperately. one of my 500/1's low ohm light came last week. so i checked all the wires for compromises and they were fine. so to test i unhooked that amp and put the other 500/1 where the low ohming amp was and it worked fine! i then plugged the low ohming 500/1 into my buddies wiring and the light came on again and wont turn off? can anybody help? ive thought of every type of test and nothing helps! the only thing i can think of is that the amp is in protection mode. please help! thanks
    Problem Solver:
  • 6 Answers
Pbabin is correct, that would cause resistance to be at or near 0 ohms and the amp would pull a lot of current (if it did not go into protection mode).
Posted on Feb 12, 2008
  • 631 Answers
It's likely that the output transistors failed in the amplifier and it will need to be repaired.
Posted on Nov 09, 2007
JL Audio 1000/1 v2 distortion problem
Make sure all your connections are tight , really tight . Check ground , make sure it's to clean shiney metal. Three subs are going to have a low ohm load if paralleled . These amps are not 1 ohm stable ,if below 1.5 ohm's you will have problems. They need to be series paralleled to raise the ohm load. These amps put out the same power from 4 to 1.5 ohms.
Mar 14, 2012 | Jl Audio Car Audio & Video
I looked up the correct way to wire my JL 13.5W7 1.5. Therefore it said to wire it in parrallel. I understand this will put it at .75 ohm. As I start to turn it up it sounds great, very loud but once the...
1000/1v2 Class D Monoblock Subwoofer Amplifier Specifications:
Rated Power:
1000 W RMS @ 1.5 ohm - 4 ohm (11V-14.5V)
THD at Rated Power:
<0.05% @ 4 ohm
S/N Ratio:
>95dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response:
5 Hz - 250 Hz (+0, -1dB)
Damping Factor:
>500 @ 4 ohm / 50 Hz
According to the chart your amp is only stable down to 1.5 Ohms, so running at .75 Ohms the noise you are hearing is the amp clipping (running more power than it can handle at low ohms)
I would suggest wiring it in series, or you could adjust the gain on the amp until the popping goes away.
Hope this helps.
Nov 10, 2010 | Jl Audio 13W7 Car Subwoofer
I have a 500/1 mono jl audio amp and two w3 10" woofers, every time my bass hits hard my low ohm light will flicker on and off but the light doesn't stay on to long it only flickers every time the bass...
not really a problem, your just running a the threshold of the amps comfort zone, a lil trick to raise your impedance a little bit its to run an additional 10 feet of wire before your sub, (longer the wire the more resistance) 10 feet should jump you up about .5 ohms. you wont hear the difference but your amp will fill it, and run a little better. 20 feet will give you right around 1 ohm. now if you dont mind loosing some power run the subs in series and then run them bridged. your amp will work harder, but run easier because its on a big open loop. but before all this take a multi meet and read out your voice coils to see what the ohm level is, then read out what it is at the speaker, then you will see 1. if the subs are okay, and 2. how much you need to raise your impedance for you amp to run comfortably.
Aug 09, 2010 | Jl Audio 500/1 Car Audio Amplifier
When i turn the volume up my jl 1000/1 amp turns off then turns back on when the volume is low what can i do to fix this?
2 things, either your pushing too much power into the imputs (if using high inputs) and clipping the signal, or your running the ohms too low (lower then the amp can handle safely) by running multiple speakers of too low an ohm each. For example if your amp is 4 ohm stable and your running 2 4 ohm speakers in parallel that makes 2ohms and the amp can't handle a load that low. You can consult your manual and it will give you illistrations of wiring and ohm loads
Oct 26, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Jl audio 300/4 low ohms light wont go off
If the low ohms light is on then you have your speakers wired to low. I need to know some more info like what type of speakers you have running on this amp and how many. Also was it working before and then it started doing this? Check the ohms with a volt meter if you know how, if not just get a volt/ohm meter and set it to the ohms setting and then take the positive(red probe) and touch it to the positive terminal on the speaker and then the negative(black probe) to the negative terminal and see what it reads. Make sure you check how low in ohms your amp is capable of handling. If you don't know just google the model of your amp and you will find a site that has a manual or just go to JL audios web site and you should find out there with no problem. Let me know what you find so I can assist you more if need be cause I also repair amplifires for a living and have many years experienc and I'm the cheapest amp repair business you will find any where. Good luck
Aug 15, 2009 | Jl Audio 300/4 Car Audio Amplifier
What to do
well i don't know your budget, but if that's not really and issue, right now at best buy, alpine type E, 10" subs, peak is 750w and rms is 250w, each is 129.99. Alpine type R, 10" subs, peak is 1500w and rms is 500w, each is 199.99. These are the best subs i found at best buy. You could sell your current subwoofers and purchase those, and you'd save space and still get the lows you want. Goodluck
Jun 27, 2009 | Jl Audio 12W7 Car Subwoofer
Pioneer 800w mono issue
It can be many things it possible the amp cannot handle the 4 ohm load and simply goes into power protection mode. Also make sure your using the correct gage wire to run power from your battery to the amp to thin and it wont have enough power to perform.
May 09, 2009 | Pioneer 800W Class-D Mono Amplifier With...
Help me...
If you had 4 single voice coil speakers you can create either of those 2 ohm or 4 ohm setups. If you run 2 of them in parallel you will get the 4 ohms. If you run 4 of them in parallel you will get the 2 ohms. In parallel I mean that you connect the positives together and run them to the positive on the amp and the connect the negatives together and run them to the negative on the amp. Let me know if you need more help. Good Luck.
-Andrew Hawkins
Jun 24, 2008 | Cadence TXA 6004 4 Channel High Power...
Low ohm light on with now RCA's or speaker wires attached? What is going on???? Sound is crap it was working fine for the last year ????????
ohms are impedance or the amount of current being blocked through the line. The lower the ohms the less resistance. Speakers run at a certain ohm (or at least are recommended to run at). Have you bridged your amp? Usually when you bridge your amp it lowers the ohms by half. You may have damaged something, especially if you bridged your amp and didn't bridge it properly.
Jan 31, 2008 | Jl Audio 450/4 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
366 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
