Cycle the key from off to run three times & leave it in the run position. the Check engine will start to flash. the sequence will tell you the code. for instance 000 0000 00000 000 0000 00000 000 0000 00000 0000 00 00000 0000 00 00000 0000 00 00000 000 0000 00000 ... would show you code #345 three times then code #425 three times then starts over again with the first code if there are only two codes
With player off, press Display after Top Menu , after Clear and last On.
Imediatelly your player appear Options : Choose number 2) Drive Manual Operation; and after press 4) Tray Aging Mode.
Put the CODE 24570 and confirm , go to second line and put 00000.
Try 3 or 4 times , and when the 2 lines fix the numbers 00000, will be Ok , your player to use.
I hope to help.
Tony
