Question about Sharp Notevision PG-C30XU Multimedia Projector
PG-C30XU projecting criss-cross plaid image.
Whether I connect my laptop or my video camera w/rca cables or any other connection for that matter my projector projects the same plaid criss cross image. This image is very clear and my bulb cranks out good light. The Notevision display shows clearly when I first turn it on and the menu works great as well. Does anyone have any ideas? Thank you.
I suggest you do not have the projector too far away... 7ft away distance would be a Good resolution will also dimm don the square's image in the picture
Posted on Nov 27, 2011
While streaming Netflix from my laptop (via S cable) to my RCA TV, the image on the TV is black & white. Whether streaming or not, when I hook up my laptop to the TV, the desktop image on my laptop...
If the cable is damaged then one of the pins can be bent inside or if it unscrews a solder connection may be undone. see the photo showing color on the left and bw on the right. Also plug everything in turn off everything then turn on the computer and then turn on tv. also try just opposite turn on tv and reboot computer.
Go to Bing homepage Video Wikipedia SVIDEO TV BLACK AND WHITE SCREEN Graphics Cards
Nov 12, 2017 | RCA F32649 32" TV
I replaced bulb for Notevision PG-C30XU but how do i reset the lamp timer?
Do the following for reset the lamp hour
1.Plug the power cord into the AC socket of the projector.
2.While pressing down arrow, right arrow and ENTER on the projector a , then press POWER ON on the projector.
3."LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Feb 10, 2011 | Sharp Notevision PG-C30XU Multimedia...
We have a Notevision Sharp LCD projector, PG-C30XU and can't figure out how to open up the insides of the projector to replace the fuse. Or even where to get the replacement fuse.
Above is a download for your service and repair manual, this will show you everything you need to know to do with this printer.
Replacement fuses, and parts, are easy to obtain, simply Google the parts number, obtained from the manual, and you will find a number of suppliers, simply choose one you like, and get it shipped to you.
Nov 15, 2010 | Sharp Notevision PG-C30XU Multimedia...
Trying to figure out how to connect VCR to laptop ie cables etc Want to transfer tapes to DVD
This will depend on what the connections are on the laptop. All you need is a video in and two audio (left & right) in connectors. If these are 3.5mm jacks sockets on the laptop. Then all you need is convertor cables. It will be easy if the VCR has a scart socket. As you can get a scart plug that has RCA plugs on the other end for audio and video out. All you need then is 3.5mm to female RCA plug lead(s) or if you can only get them with male RCA plugs, 3 inline connectors.
You can also get a USB to RCA plugs. See image below.
images below as well: of 3.5mm cable with RCA (male) and the female version and couplers for the males, plus the scart lead (yellow RCA is video) (all cables can be get from Amazon)
Jun 04, 2010 | Emerson Televison & Video
Can i get an adapter for a notevision sharp projector that will recognize my mac
usually the OHP, will take many input formats please use the user manual above to look into this matter, There really is no reason that you shouldn't be able to?
May 21, 2010 | Sharp Notevision PG-C30XU Multimedia...
Laptop to tv
Your model laptop has S-Video out capabilities. Depending on what model TV you are connecting to, you would then need an S-Video to (whatever input connection your TV supports: S-Video, VGA, RCA, HDMI) cable. Once you have the cable connected, set your TV to the input method for the cable used, and press Fn + F4 on your laptop Keyboard to project the image over. May need tp press more than once depending if you wish to only display on one screen or both. S-Video is only a video out cable, so you will alos need to run an audio connector cable from your laptop to TV as well, or just use a pair of external laptop speakers for your sound.
Jan 12, 2010 | Computers & Internet
Mitsubitishi TV model VS50800 (1998) - sound but no picture. What could the problem be, defective 'bulb'?
There may be a switch on the back of the TV that chooses whether to output video to the component connections or the RCA/S-Video connections.
RCA cables - red, yellow, white
S-Video - single cord (usually black)
Component Video Cables - red, green, blue
Sep 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
How to show images on my TV or VCR
Hi connect rca cable to tv , rotate knob to play mode press function set and press play ,now you can view movie.
Jan 24, 2008 | Canon PowerShot A530 Digital Camera
What cable do i need to connect to tv
Any of the following 3 will work. S-Video ? Composite (Video) ? Audio (RCA) Information taken from: images of S-Video cable and Composite/RCA cables listed below.
Jul 26, 2007 | Sony Handycam CCD-TR748 Camcorder
Ripples appear in the image when photographing an object with fine plaids or stripes. How can I fix that?
When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. An example of this can be seen in the pictures below. The photo on the left shows the fine plaids pattern on the shirt. The photo on the right is a distance shot of the same shirt. In this photo, you can see a ripple that is not visible in the photo on the left. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Look at the image above. This image shows red cross-stripes and black cross-stripes overlapped slightly misaligned. When you look at the entire image, you find a ripple that differs from either of the patterns. This is the same principle that causes the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly. Reference You may find another Moire effect displayed on the LCD of the camera. As this is caused by the aligned pixels on the LCD, this effect does not necessarily appear in pictures you have taken.
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Sharp Notevision PG-C30XU Multimedia Projector Logo
165 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
