Question about Garmin Colorado 400 Carabiner Mount
Missing carabiner back, but have biner. - Garmin Colorado 400 Carabiner Mount
  • 121 Answers
Posted on Oct 21, 2009
How do I get instruction manual for Hasbro bopit carabiner edition
Use google search and you can download the PDF from the results. This was previously answered for you.
May 20, 2015 | Hasbro Bop It Mini Carabiner Edition
How do I change my ravel watch battery
use a thin pocket knife blade to gently pry the rear snap on cover off.
Oct 07, 2014 | Ravel Clip On Doctors Nurses Unisex...
How to take red key lock off as I cant get DVD to play
I don't think this is the right section but umm...
you should push the button and wiggle it around. if that doesn't work remove power and go inside and look at that button. I'm assuming this is for a remote...
May 16, 2010 | Mammut Element Key Lock Carabiner Color...
Is it safe to use a 1700 weight limit carabiner as a anchor for r
I wouldn't do this without checking with a professional climbing place. That's almost a ton! Don't listen to just anyone at a hardware place or you might get injured or killed!
Dec 02, 2008 | Omega Pacific "Doval" Carabiner
Rock Climbing Harness with Auto Belay, where to hook on?
Easiest is to hook the swivel carabiner to the belay loop.  This is a sewn loop of webbing that connects the leg loops to your waist belt.
Dec 02, 2008 | Black Diamond ATC Belay/Rappel Device Fall...
How do I take clean my Carabiners?
Typically, you'll only need to clean your carabiners by blowing any dirt or dust away from the hinge area. If any additional cleaning is necessary, then be sure to wash your carabiner in warm soapy water, and rinse it thoroughly. Once it is rinsed and dry, be sure to lubricate the gate area with a dry graphite, WD40 or other kind of lubricant. Using a dry lubricant will help to keep your carabiner clean longer, as dirty will not be readily picked up. Once the gate has been lubricated, be sure to wipe off any excess lubricant.
Dec 01, 2008 | Arc'Teryx Theta Ar Bib Women's
How should I pick my carabiners?
Depending on your style of climbing, you will want different kinds of Carabiners. There are basic types: your oval and D-shapes are your most basic Carabiners. Sometimes you'll want a locking Carabiner, especially for belay, or for anchors. Most Carabiners that you have will probably not be locking Carabiners. There are different types that are easier to clip. There's bent gates, straight gates, wire gates. It depends on your style and if you're weight conscious, or how durable you'd like them to be.
Which kind of carbiners shoul I use
The best carabiner shape for any kind of static rigging is a symmetric shape - oval is the best. Most carabiners are asymmetric "D" - which is stronger but will cause the line to shift when loaded - the oval shape is better because nothing will shift to one side of the carabiner when loaded. You could use standard aluminum carabiners or even locking ovals (Petzl and Omega make very nice locking ovals), but I would also suggest using steel carabiners - they are cheaper and stronger and since weight isn't an issue they are better.
Dec 01, 2008 | Black Diamond Equipment Primrose Climbing...
Garmin Colorado 400 Carabiner Mount Logo
41 people viewed this question
Top Garmin Tools & Hardware - Others Experts
john h
Are you a Garmin Tool and Hardware - Other Expert? Answer questions, earn points and help others
