Question about 2wire (1000-000057-000) Modem
How do i connect my wii to the internet?
I'd like to connect my wii to the internet, i have a 2701hgv-w 2wire router/modem.While not wireless it has wireless capabilities.I have the main computer in my lounge room connected to it and i use my laptop in my bedroom with a netgear wireless usb adapter, what do i need to be able to connect my wii? Any help will be very much appreciated as i have no idea what i'm doing!!!
  • 864 Answers
Try following this wireless troubleshooting guide This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Posted on Aug 27, 2010
How to get my 2wire ip number
There is a problem: you are connected on LAN side of the modem, so your IP is privat and are not visible in the Internet. It?s like 192.168.x.x .On the WAN side you have another IP that's could be public: 5.35.85.x .To see the public IP use a specific web site like: http://pingme.info/
Jan 01, 2015 | Gateway At&t 2701hgv-b 2wire Hi Speed...
there is two ways to get the wii connected to internet
You will need the Wii LAN adapter or a Wireless Router already in function
then on Wii options Wii Seettings go to Internet Conection Settings select Connection 1 (or any not used)
Select Wired or Wireless connection and follow the steps for the connection
For a detailed instructions see the followin linkg http://us.wii.com/connect/
Mar 28, 2011 | 2wire (1000-000057-000) Modem
2701HGV-E Power Broadband & Internet led in
Check for the user name and the password for the connectivity. Internet light red only means either the user name or the password is incorrect. Try entering the password and try again it should help.
Jun 21, 2010 | 2wire (1000-000057-000) Modem
Connecting Netgear USB adaptor to 2wire modem
Install the Adapter using the CD, After installing if its windows XP it will ask you to choose XP utility or Netgear utility, choose windows and scan for the network.
If its windows vista , go to start-Connect to - u will see the network name here , try connecting to it
Nov 14, 2009 | 2wire HomePortal® 1800HW Router...
I have a bigpond supplied 2wire wireless internet modem (2701HGV-W) which works seemlessly with my laptop running XP-sp2 for internet and email. Recently I purchased a Brother MFC 6890-CDW which offers...
Check if it's recognised on the local area network etc,make sure driver is installed and you may need to reset all pc,router etc to get connection.Now remember you need a router for this to work,with only a modem it will not function.You also need to restart all instruments etc before it's picked up by the router and the network..Google a bit and it will solve this.Make sure it uses wifi and not bluetooth as then it will need the right bluetooth connection to your pc..
Jul 27, 2009 | 2wire (1000-000057-000) Modem
Online gaming drop outs with wifi 2wire modem connection
i got the same problem, quick solution for now is to set the wireless to 802.11b <----, slower local network but shouldnt notice to much on ur internet
still not sure why 54Mbits drops the internet on that modem might need a firm ware upgrade
good luck with that
Mar 25, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
2wire gateway signal range problems
1. Put the router in the highest location possible in the house.
2. Make sure the gateway is installed in the center of the house rather than in a corner of house, so it will cover area on all sides.
3. Make Sure you dont have any devices that may interfere with the signal eg. cordless phone , close to the gateway.
4. Use channel 3 or 7.
Mar 23, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
How to monitor all traffic from PCs on ADSL wifi 2701hgv-w modem
to monitor all traffic from all computers your computer would have to run the internet connection(modem) and you would have to connect your router to that. that way all traffic would pass through your monitoring computer with watever software you use to do this. Pritty sure this is the case.
Feb 25, 2009 | 2wire (1000-000057-000) Modem
CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
Adding another computer to network
You can have 4 PCs connecting to your 2 wire 2701hgv or 2700hgv wired or wirelessly. Make sure the DSL light and the internet light is green and lighted up
For wired connection, just plug in the RJ45 cable to the ethernet 1,2,3, or 4 and the other end of the RJ45 cable on your laptop LAN card or network adaptor
For wireless connectivity, SSID is 2wire followed by the last 3 digits of the SN(or serial number) and the WEP key is located at the bottom of the 2wire modem in between 2 bar codes in square brackets. If the WEP key and the SSID was changed before in the modem page, go to the modem page and see what is the latest SSID and WEP key using RJ45 cable connected
From Andy Thoo Wai Kiat, Singtel
Jul 19, 2008 | 2wire (1000-000057-000) Modem
2wire (1000-000057-000) Modem Logo
572 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
