Question about GE Energy Star WCVH6260F Front Load Washer
Metal ring fell off
Round metal ring with spring fell off my front loading washer that is only 4 months old not sure where it needs to go
  • Anonymous Mar 13, 2014
    There's a metal round spring that came out of washer not sure where it goes
  • 5,911 Answers
If you are talking about a small metal hoop with a spring on one end, it is the outer bellow retaining clamp. The bellow is the rubber door seal. The retaining ring inserts into a groove in the rubber seam around the perimeter of the door where it attaches to the door frame. To reinstall, first make sure the door boot is fitting snugly around the door frame opening. Sometimes when the retaining spring comes loose, the rubber may pull away from the door frame. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure the wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place with your thumbs. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If this is not the spring you are talking about, please post back and elaborate a bit more on what the part looks like to see if I can assist you better. (i.e., size, dimension, where you found the part, etc.)
I hope you find this information helpful.
Posted on Jun 30, 2009
How do you remove inner tub to get to the outer tub of Fisher & Paykel gwl11
You need 2 people for this.. Unscrew plastic wingnut down the centre of the agitator.(2) undo 2 phillips head screws under little rubber covers just under lid at front top edge.(3)lift top of machine like a car bonnet,get someone to hold it up for you.(4)Unclip big round plastic ring on top of the bowl,you may find its attached with a spring at the front left hand corner,just lay the plastic ring over front of machine & let it hang.The bowl should just lift straight out.Be carefull,the outside of the metal bowl is like a cheese greater trust me! PS when you put it back together & you lower the top of the machine(make sure that little white plastic lever hanging down) the right hand rear go's outside the righthand rear of the tub NOT squashed on top.Its an out of balance lever & it needs to dangle outside of the bowl/tub right rear.GOOD LUCK!
May 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
Inserting loose rubber seal on front load washer
you can try holdthe one side and use a screw driver on the other end try to put the rmetal ring in the gasket. is batter if you have to persons...
Apr 10, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
FRONT DOOR OF WASHER LEAKING
Hello. W/D here.
It's actually pretty easy to get it back on when you know the trick.
Since it has leaked on you, you may want to remove the seal off of the rim closest to the door and clean the rim and the sealing surface. The seal has a molded lip that fits on to a raised formed rim, and it gets pressed on snugly before the ring and spring are added. You can seat the seal by pressing on it all the way around with the palms of your hands.
To install the ring:
Start the ring 180 degrees from the spring, placing it in the groove behind the seal face. (You want to make sure that the seal is pressed back into place first). Work the ring on around the seal, until you get to mostly just the spring remaining. Now lever the spring over the lip and into the groove, using a small screwdriver, being careful not to damage the seal with the screwdriver.
Best regards, --W/D--
Aug 20, 2009 | Maytag EPIC MFW9700S Front Load Washer
Hello, my axxis washer gets mold build up on the rubber gasket at the door. i have ordered a new one but do not feel the need to pay $200.00 for the install. can i get instructions to install on my own. i...
Um...have fun. I have replaced two of them.
the way to keep the mold from growing in the future is to leave the door open so that you don't create that closed moist environment.
About the easist way to replace/change is to remove the front of the washer (I have completed w/o doing that but took a bit longer).
Make sure you keep an eye on how the old one comes off as some of them have drain pipes connected.
To remove:
There is a metal ring with a spring attached, simply streatch spring a bit at bottom of door and it should come right off. Do the same for the inside seal, that spring is at the top.
To install:
put the metal ring inside the grove of the gasket, then align gasket on the front. Pick an edge to start working around as you get closer to the top (I pick the lower right hand side to start working around. Make sure that your spring part of the metal ring is at the top where the one you replace was at.) once you get to a point you need to stretch the spring, this is where I use an 90 degree or more pick tool to get into the end of the spring. You need to make sure that you have the seal tight. Start pulling on the spring to stretching it so that can put the rest on. (You need to keep tension on the gasket so that the metal ring does not slide.)
Now to the front.
Just make sure that the spring part is at the bottom. When you took the otherone off, it was at the bottom. It has to go there as there is a groove. Once you get the metal part around the gasket push a bit on the spring and make sure it is in that goove.
To test, open and close your washer door a couple times. At first gently.
Hope this helps as they are a pain in the rear.
Also, here is a nice parts place for all your Bosch parts. www.repairclinic.com
The gasket was only about $75 to my door.
Aug 01, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Putting on spring loaded wire seal ring on a bosch washer
You have to make sure that the spring part is towards the bottom of the front. If you look closely at the washer at the bottom you will see a groove. That groove is where that spring will need to end up otherwise the whole thing will keep poping off.
how I install is I use a 90 degree pick tool. I work the edge of the seal with the metal ring and making sure it lines up with the groove. once there is tension on the spring I streatch it with the 90 degree pick tool and continue to work the rest of the gasket around. Once you get that completed I push down on the spring to make sure that it is in there. If it is not it takes one door opening to make it fall all apart and you have to start over.
Jun 10, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Gasket came loose and rapped around laundry-tub seems loose
if your metal ring (clamp) came off it is most likely due to you shocks or the spring at the top are worn out and need to be replaced. this will happen more often if the cycles are off balance or the washer is over loaded
Nov 26, 2008 | Whirlpool GHW9400 Front Load Washer
Kenmore HE 110.4751 front load
soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Rubber sean and wire spring came off
Hi
Spring should be a the 6 o'clock . you may need someones help have some hold the wire on at 15 and 45 ... when you pull the spring apart and slided it under the bellows. be careful as the spring can fly off. good luck and keep trying...
Apr 05, 2008 | Bosch WFR 145 Front Load Washer
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Water leaks out the bottom of door. metal ring with spring came off. put it back on and has leaked since
I have the same problem. I went to get laundry out of the machine and there is plastic piece with coded wires attached and metal tension that appears to go around the drum hanging loose. Probably have water but the machine is in the basement not too far from the drain. Mine is a duet 9100L about 4 years old
Oct 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
597 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
