Question about Samsung 26.0 Cu. Ft. Side-by-Side Refrigerator, RS265LABP
Samsung RS 265. The water on the door works but the ice maker won't make ice.
Has water and ice on the door
SOURCE:
  • 883 Answers
SOURCE: Ice maker water level too high
generally, there is a screw adjustment for this. usually, turning it clockwise sends more water during fill period (makes period longer). try it and adjust clockwise or counter-clockwise as necessary. Now finding the screw...try prying (or unscrewing) off the plastic cover over what appears to be the ice-maker unit (may also be on back side of frig.
Posted on Sep 17, 2007
SOURCE: Samsung Ice Maker on Mdl RB215LASH
There is a simple solution but maybe not for the long run.
There is a black rubber button on the front of the underside of the icemaker. It is a reset switch. I was told by Samsung support that this is a common problem if the icemaker has been off for a while.
Mine wouldn't work out of the box and several resets later it is still not making ice consistently. It has been 2 weeks and it has yet to fill the bin. We haven't used ANY ice from the maker. If the best it can manage between resets is a few trays... I think its time for a return to the store.
I hope you have better luck.
Posted on Oct 13, 2007
Bgillespie
  • 89 Answers
SOURCE: Ice Maker problem
There is a water valve that "feeds" the ice maker. When the Ice maker makes ice it sends a signal to the water valve, it opens for approx. 7 seconds and fills ice tray with water. Another cause of no water in IM could be frozen water line where it feeds the IM.
Posted on Mar 21, 2008
  • 145 Answers
SOURCE: Samsung side by side RS2556BB. Ice maker is not dumping ice out.
you need to remplace your control board
is not suppling power to the ice maker heater element you will find the control boar nex to the wather valve
Posted on Jun 07, 2009
SOURCE: samsung rs2555sl ice maker trouble
how to replace the filter? the indicator light is on the front left side over dispersement h20/water
Posted on Oct 16, 2009
Dispenser not working
With the door open that motor is not supposed to operate. This coulod be sesveral things. One of them is the switch on the door and the other is the wire harness from the door to the unit itself.
Aug 25, 2013 | LG LSC27910 (265 cu ft) Side by Side...
Lg in door ice maker, water won't fill in ice tray
I had that problem and water was also leaking. I tossed the ice and kept the door open for about 20 minutes when the door open alarm started to go off. It's working again. The error code on the door was 1f
Feb 01, 2013 | LG LFX25960ST Stainless Steel French Door...
Rfg297aa won't make ice
Ice maker quit making ice. Ice tray in feeder was empty when I pulled it out. Water is working when I choose water but apparently no water is getting to freezer unit. What else can I check or do?
Oct 28, 2012 | Samsung RFG297AARS (285 cu ft) Bottom...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ice maker won't make ice
This problem is very common.The ice maker water passing line gets clogged or blocked by ice cube or gets frosted by ice or the water valve,which lets water to ice maker,tray, that valve gets faulty.
The ice maker not working.-------------
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 10, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
We have a Samsung RS2530BBP. The ice maker works ok... water stop coming out... What do I need to do to fix the problem?
My Samsung RS 2530BBP frige Ice maker stop tp make ice.
The water tray stays verticly after pushing the reset button and the water pours in the container instead in the tray. I purchased a new ice maker but it did the same. Any idea how to fix it
Aug 12, 2010 | Samsung RS2530BBP (25 cu ft) Side by Side...
Ice Maker problem
Mar 19, 2008 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
101 people viewed this question
Top Samsung Refrigerators Experts
Paul
Gerry Harvey
Gerry Harvey
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
