Question about Texas Instruments TI-30XA Calculator
I want to clear a stored number "M2". - Texas Instruments TI-30XA Calculator
  • drnelson77 Jun 30, 2009
    No, I'm using a TI-30XA. MC or MRC aren't on it.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Use MC or MRC button on your calculator
Posted on Jun 30, 2009
  • anthony6222 Jun 30, 2009
    The calculator has 3 memories. When a memory
    contains a number other than 0, M1, M2, or M3 displays.
    To clear a single memory, press 0 STO 1, 0 STO 2, or
    0 STO 3. To clear all 3 memories (solar only), press
    ON/AC
Ti 30x IIS displays memory cleared and will not do
Not sure but try
  • Press the "ON/AC" button to turn the TI-30Xa on. If the top-left corner of the display reads either "M1," "M2" or "M3," a number is stored in the corresponding memory.
  • 2 Press "0," "STO" and "1" if the number in the corner reads "M1." The upper-left corner should no longer say "M1."
  • 3 Press "0," "STO" and "2" to clear the "M2" memory. Pressing "0," "STO" and "3" clears the number stored in "M3" memory.
  • Read more : http://www.ehow.com/how_8623666_clear-memory-ti30xa.html
    Oct 14, 2014 | Office Equipment & Supplies
    How can I found out the stats on a Canon NP 6551 (ie total pages, etc...)?
    NP6560 Main Specifications
    Main Unit
    Type: Console
    Platen: Stationary
    Photoconductive material: Amorphous Silicon
    Copying system: Electrostatic transfer system
    Developing system: Toner projection system
    Fixing system: Heat roller system
    Acceptable copy stock: Paper drawer:17 to 24-lb bond (64 to 90 g/m2); plain paper
    Stack bypass:17-lb bond to 110-lb index (64 to 200 g/m2); plain paper
    (However, Keep in mind that the paper weight that can be used varies
    depending on the type of the Sorter being used.
    SADF tray : transparencies and labels
    Acceptable originals: Sheets, books, and three-dimensional objects (up to 4.4-lb or 2 kg)
    Maximum original size: 11" x 17"
    Copy sizes: Paper drawer: STMT, STMTR, LTR, LTRR, LGL, and 11" x 17"
    Stack bypass: 4 1/8" x 5 7/8" (horizontal placement) to 11" x 17"
    Non-image areas: Leading edge: 1/4" (4.5 mm)
    Left and right side: 1/16" (3 mm)
    Trailing edge: 1/16" (2 mm)
    Warm-up time: Approx. 6 minutes (at temp. of 68°F)
    First copy time: Max. 2.8 seconds
    [LTR size, direct copying, Manual Exposure Control, Drawer 1 (top
    drawer) selected 1→1-sided mode]
    Copy speed: Direct (100%) LTR 60 cpm
    65 cpm (Accelerated mode)
    LTRR 49 cpm
    11"X 17" 30 cpm
    LGL 40 cpm
    STMT 60 cpm
    STMTR 60 cpm
    Reduction 11"x 17" → STMT 56 cpm (50%)
    11"x 17" → LTR 48 cpm (64%)
    11"x 17" → LGL 40 cpm (73%)
    11"x 15" → LTR 48 cpm (73%)
    LGL → LTR 49 cpm (78%)
    Enlargement LGL → 11"x 17" 30 cpm (121%)
    LTR → 11"x 17" 30 cpm (129%)
    STMT → 11"x 17" 29 cpm (200%)
    Magnification: Direct 1:1.000
    Reduction 1:0.500 (11" x 17"→STMT)
    1:0.647 (11" x 17"→LTR)
    1:0.733 (11" x 17"→LGL/11" x 15"→LTR)
    1:0.786 (LGL→LTR)
    Enlargement 1:1.214 (LGL→11" x 17")
    1:1.294 (LTR→11" x 17")
    1:2.000 (STMT→11" x 17")
    Zoom 1:0.490-1:2.040
    7-8
    Paper feeding system: Drawer 1, 2 (1,500 sheets x 2)
    Drawer 3, 4 (550 sheets x 2)
    Stack bypass (50 sheets; stack approx. 1/4" high)
    Multiple copies: 1-999
    Power source: 120 V, 60 Hz
    Max. power consumption: Less than 2.0 kW
    Dimensions (H x W x D): 46" x 25 3/8" x 28 1/2"
    (1169 x 643 x 725 mm)
    Installation Space (W x D): 40 5/8" x 28 1/2"
    (1030 x 725 mm)
    50 3/8" x 28 1/2" (1280 x 725 mm)
    [With copy tray (option) attached and stack bypass auxiliary tray extended]
    Weight: Approx. 462 lb (210 kg)
    RDF (Standard equipment)
    Originals: STMT to 11" x 17" size (STMT-size cannot be placed horizontally.)
    Original tray: LTR 15-lb to 110-lb bond (52 to 200 g/m2)
    11" x 17", LGL, LTRR, or STMT
    15-lb to 32-lb bond (52 to 128 g/m2)
    SADF tray: 11" x 17" to STMT
    11-lb to 110-lb bond (38 to 200 g/m2)
    Max. power consumption: 120 W
    Original tray capacity: Original tray: 11" x 17" or LGL
    50 sheets (20-lb bond or 80g/m2)
    LTR, LTRR, or STMT
    100 sheets (20-lb bond or 80g/m2)
    1 sheet
    Original replacement speed: 60 sheets/minute (LTR, horizontally placed)
    Power supply: 24 V (supplied from main unit)
    Dimensions (H x W x D): 6 7/8" x 25 3/8" x 21 1/4"
    (174 x 643 x 539 mm)
    Weight: Approx. 56.3 lb (25.5 kg)
    These specifications are subject to change without notice.
    8-1
    ar
    Energy Saver
    Stop
    Guide
    Additional Functions
    Start
    Display Contrast
    ii
    Enter a ID number with the Number ( 1 - 0 )
    keys.
    MEMO: ? If you make a mistake entering an ID number, press
    the C
    Clear
    key. Then, enter the ID number again.
    ? You cannot enter two identical ID numbers.
    ? If you enter and store "000000" in place of a current
    ID number, that ID number is canceled.
    ? You can store up to 1,000 ID numbers.
    Press the [OK] key.
    If you want to store another ID number, repeat
    steps 3 to 5.
    5
    After entering all the ID numbers to be stored,
    press the ID key. The display returns to the ID
    entry screen.
    6
    Canceling the ID Mode: Clearing All ID Numbers
    If you clear all the ID numbers then you can make copies without having to enter an ID
    number.
    Press the Additional Functions , ID , Stop , and Additional Functions keys in that
    1 order.
    Clear
    Guide
    Interrupt
    Reset
    Clear
    Energy Saver
    Stop
    Guide
    Start
    Display Contrast
    iii
    Press the [OK] key.
    MEMO: ? If you want to stop all the ID#s from being cleared,
    press the [C] key.
    Press the [CLEAR ALL ID#s] key.
    Press the [STORE USER ID#] key, then press
    the [OK] key.
    All the ID#s are cleared.
    If you press the [OK] key, you will return to the
    Standard mode.
    MEMO: ? Storing all the ID#s under "000000" will also clear all
    the ID#s.
    iv
    In the ID mode, the copier keeps track of the copy quantity made under each ID number (up to
    999,999). You can view the copy total for each ID number in the touch panel display.
    1 order.
    After pressing the [COPY TOTALS] key, press
    2 the [OK] key.
    Press the [?] or [?] key to check the copy totals
    for a department. The copy totals can also be
    displayed by entering the department number.
    Press the Number keys ( 1 - 0 ) for a four digit
    department number and it appears at the top of
    the display. When you finish checking the copy
    totals, press the [OK] key.
    Copy Totals (Check Totals)
    The following procedure describes how to clear the copy totals for all ID numbers to zero.
    Copy Totals (Clear All Totals)
    1 order.
    Reset
    Clear
    Energy Saver
    Stop
    Guide
    Start
    Display Contrast
    Reset
    Clear
    Energy Saver
    Stop
    Guide
    Start
    Display Contrast
    v
    2 the [OK] key.
    Press the [CLEAR ALL TOTALS] key. 3
    Press the [OK] key.
    MEMO: ? To cancel clearing all totals, press the [C] key. 4
    The copy totals for all ID numbers are cleared to
    zero. If you press the [OK] key the display
    requesting the entry of an ID number appears.
    MEMO: ? You cannot clear the copy totals for ID numbers
    individually.
    Dec 21, 2010 | Canon NP 6551 Black and White Copier
    Should the M2 be displayed on the screen calculator?
    The M2 is simply telling you that there's a nonzero value stored in memory register 2. If you want to clear it, store a zero in register 2 by pressing 0 STO 2. You can clear all three memory registers by pressing ON/AC.
    Oct 26, 2010 | Texas Instruments TI-30XA Calculator
    Looking for conair cm200wcs manual
    To store numbers into the phone's memory:
    Lift receiver - you should hear dial tone. Then, press 'STORE', press key M1, M2 or M3.* Enter the number you wish to store. Then, press the 'STORE' key again. Now, press the memory position you chose above, (M1, M2 or M3).** Replace receiver back on cradle.
    To use - lift receiver and press the memory key that was optioned, (M1, M2 or M3). If a numeric key, (1-9), was chosen - press the 'MEMORY'' key then the chosen number.
    * To store in numeric 1 - 9, just press the 'MEMORY' key for this step.
    ** When storing in numeric 1-9, Press the 'MEMORY' key and then the number you wish to store in this step.
    Tip: For a phone card, use M1 for the 800 number and M2 for the PIN.
    Jun 30, 2010 | Conair TAD920 Corded Phone
    Clearing display
    The M1 in the display remind you that the M1 memory contains a number that is not equal to 0. So, to get rid of M1, M2, or M3, you shoild store the value 0 in them.
    0 [STO] 1 stores 0 in M1, and thus erases its contents: M1 disappears
    0 [STO] 2 stores 0 in M2, and thus erases its contents:M2 disappears
    0 [STO] 3 stores 0 in M3, and thus erases its contents:M3 disappears.
    Feb 18, 2010 | Texas Instruments TI-30XA Calculator
    How do I reset the calculator after installing new
    [OFF] ON/C] clears display, errors, all pending operations, constant calculations K, and STAT, but not M1, M2,and M3. Sets DEG angle units, floating-decimal format.
    To clear memory M1 : Store 0 in 1
    0 [STO] 1 clears M1
    0[STO] 2 clears m2
    0 [STO] 3 clears M2
    Feb 03, 2010 | Texas Instruments TI-30XA Calculator
    How to clear the memory key on Texas instrument scientific calculator TI 30XA or use the memory key
    Your calculator has 3 memories (M1, M2,M3)
    To store the number 170 in M1 use 170[STO]1
    To recall a number from M1 use [RCL]1
    To add a number to the content of M1 [2nd][SUM]1 (adds displayed value to contents of M1).
    [2nd][EXC] 2 exchanges the value already displayed with the contents of M2:
    To erase (clear) a memory register, just store 0 in it.
    Hope it helps.
    Oct 22, 2009 | Texas Instruments TI-30XA Calculator
    How do I earase the M2 button that is always on my screen?
    Clear the display so that zero shows, then press STO M2 to store zero in the M2 registry. Any time there is a non-zero number stored in M1, M2 or M3, you will see those memories in the display to remind you there's something stored. There is no "clear memory" function on the TI-30XA, you have to store zero in the memory to clear M1, M2 or M3 from the display.
    David
    Dec 17, 2008 | Texas Instruments TI-30XA Calculator
    Uniden Model EXP7900 How do I program button m1
    One-Touch Dialing
    Your phone is equipped with three .One-Touch Priority. keys for
    instant dialing (m1, m2, and m3). You cannot store phone
    numbers directly into m1, m2, andm3. They are only used
    to dial phone numbers stored into memory locations 1, 2, and 3
    on the keypad.
    1. To instantly dial phone numbers stored in memory locations
    1, 2, or 3, simply press m1, m2, or m3. (There is no need to
    press talk, the phone will automatically dial.)
    2. If no phone number was stored in memory locations 1, 2, or 3
    on the keypad, pressing m1, m2, or m3 will do nothing.
    I hope this helps.
    Rollin CBs
    Dean
    Nov 04, 2008 | Uniden Cordless Phone
    How to clear all information from screen
    screen has (m3)and (m1) in upper left corner, have not been able to totally clear screen.
    Apr 10, 2007 | Texas Instruments TI-30XA Calculator
    Texas Instruments TI-30XA Calculator Logo
    191 people viewed this question
    Top Texas Instruments Office Equipment & Supplies Experts
    k24674
    Stevan Milanovic
    Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
