Question about Maytag MAH6700AWW Neptune Front-Load Washer
MY NEPTUNE MAH4000AWW WORK WHEN IT WANT TO WORK
THE MACHINE FILLS WITH WATER THEN STOPS, HIT THE START BUTTON IT START AND STOP AGAIN. IF I ADVANCE THE TO THE NEXT SETTING AND STOP AGAIN BUT WHEN I ADVANCE IT TO THE RINCE CYCLE IT RUNS STRAIGHT THROUGH THE WHO CYCLE NON-STOP.  BUT SOME DAY IT JUST WORKS WILL NO PROBLEMS FOR ABOUT AWEEK OR TWO STRAIGHT
I have a Maytag Neptune washer model MAH4000AWW. When I put it on normal it will run for about seven minutes and then it stops. Occasionally it will run through the entire cycle, but I never know when this will be. If I put it on rinse it will go without stopping. I am so frustrated. We just replaced the timer yestereday and it still won't continuously wash without stopping.
  • 248 Answers
Check for low water pressure. Clear screens in inlet valve. Do-not remove screens. This unit will turn off if not filled in specified time.
Posted on Nov 15, 2007
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune MAH4000AWW will not finish a full cycle.
I had the same problem. I called customer support and they gave me these instructions:
Shut off the water supply to the machine, disconnect the hoses from the back of the machine. Pull out the hose and pull out the little screens and clean them with water or soak in vinegar. I was skeptical but did this and the results were amazing. Apparently if the screens get even a little "gunked" up (my screens really didn't look that bad) the machine senses the change in water pressure coming in and shuts it off. Hope this helps!
Jan 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag mah4000aww trys to spin shakes and stops
there are off balance switchs on the tub that will turn it off But if the pump sump is full it will pump slow and throw it off balance so check to see how well and fast it is pumping the water out
Nov 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front loader, model# MAH4000AWW PROBLEM: Water will not fill. First hot stopped working a few months ago, then cold also stopped. We live a long way from nearest repairman, so have put this...
It sounds like you just have a clogged or bad valve. Depending on the water source I have seen many times a load of crud on the screens where the hose meets the valve. Try taking the hoses off making sure their clear, then inspect the inlets to the valve to see if there is a clog. Unfortunately some of this dirt may have entered and fouled the valve itself, in which case it will need replacing.
Oct 22, 2008 | Maytag Washing Machines
Maytag washer shutting off on rinse cycle
If the washer is not completing the Rinse cycle there may be problem with:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Let me know if you need further assistance.
Regards
Ellin
Sep 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer Maytag Neptune
Most likely the motor control unit, the MCU controls the timer (loop circuit). Best way to check is to just pull the MCU out and visually inspect it for burned components, although it is not always visible. You may need to make some involved voltage readings to verify.
Sep 22, 2008 | Washing Machines
email me at b4829@yahoo.com also it may not be the motor matags had a promblem with a resistor burning out on the control bd on your mail put maytag motor as the topic and will reply
May 21, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Sounds like you have an intermittent problem with the board or one of the on board switches.
Oct 22, 2007 | Maytag MAH6500 Neptune Front Loading...
Neptune MAH3000AWW will start to fill when start is pressed, but stops seconds later
either a faulty pressure switch / pot or faulty controller - either way you will need to call someone in.
Jul 24, 2007 | Maytag Neptune Washer
Nf pops up on the screen & the washer stops
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
May 13, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
458 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
