Fuse
Terminal
Cable ID (fused)
Fused function
Rating in amperes (A)
F1
30
Wiper park position heater relay (K40/2kA)
F2
30
High pressure and return flow pump relay (K40/2kF)
F3
30
Steering column forward/back adjustment relay 1 (K40/2kD)
Steering column forward/back adjustment relay 2 (K40/2kE)
F4
30
Steering column height adjustment relay 1 (K40/2kI)
Steering column height adjustment relay 2 (K40/2kJ)
F5
15R
Wiper On and Off relay (K40/2kH)
F8
30
RD 0.75
Central gateway control unit (N93)
F9
30
PKWH 2.5
Left door control unit (N69/1)
F10
15
BKVT 0.75
BKVT 0.75
BKVT 0.75
Left front headlamp unit (E1)
Right front headlamp unit (E2)
Xenon headlamp control unit (E1n1, E2n2)
15
RDGN 0.75
Restraint systems control unit (N2/7)
F11
15R
BKYE 1.0
Circuit 15R/30 cutoff relay (K75)
F12
15R
Spare
F13
30
RDGN 1.5
ABC control unit (N51/2)
F14
15R
BKGN 0.75
Windshield washer fluid pump (M5/1)
F15
30
RDGN 1.0
Data link connector (X11/4)
F16
15R
PKYE 1.0
Valid for code (855) TELE AID:
D2B telephone and TELE AID transmitter/receiver (A35/17)
15R
PKYE 1.0
Valid for code (853) MB standard telephone:
D2B telephone transmitter/receiver (A35/13)
F17
15R
RDYE 0.5
Vehicle-sensitive seat belt lock sensor (A60)
F18
15R
Spare
F19
15
BKYE 1.00
Valid for engines 112.973, 113.963/992:
Fused via circuit 15 connector sleeve (Z3/29):
Cylinder 1 ignition coil (T1/1)
Cylinder 2 ignition coil (T1/2)
Cylinder 3 ignition coil (T1/3)
Cylinder 4 ignition coil (T1/4)
Cylinder 5 ignition coil (T1/5)
Cylinder 6 ignition coil (T1/6)
Cylinder 7 ignition coil (T1/7)
Cylinder 8 ignition coil (T1/8)
F20
15
BKGN 0.75
F21
15R
BKYE 0.5
Instrument cluster (A1)
F22
30
RDYE 0.5
F23
30
RDWH 1.0
RDWH 1.0
AAC [KLA] control and operating unit (N22)
Coolant circulation pump (M13)
F24
30
RDWH 0.5
Stop lamp switch (S9/1)
F25
30
RDYE 0.75
Alarm signal horn (H3)
F26
30
RDBU 0.5
Lower control panel control unit (N72)
F27
30
RDVT 2.5
Left front seat adjustment control unit with memory (N32/1)
