Question about Samsung SlimFit TX-S2783 TV
Power Shutdown automatically after using more than 30mins. Even we did not set the sleep. Why it happened?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Try resetting your TV to original specs(Use menu reset as instructed by your TV manual) If doesn't work, try using a stablilizer, if it doesn't work then try another wall socket, If not then you have a loose soldering issue with your power IC socket induced by rough handling of your power cables.
Posted on Jun 30, 2009
Gateway MT6707 shutdown problem
Open the Control Panel, select Power Options, select High Performance, select Change Plan Settings, Under Plugged In, set time to Turn Off Display, set Put the Computer to Sleep to Never, select Change Advanced Power Settings, scroll through the settings , click on the + at Power buttons and Lid, set to shut down, Sleep and Hibernate to Never, adjust the rest to your preference. When you are not using the Laptop ALWAYS shut down and unplug to prevent damage due to power surges.
Apr 03, 2013 | Gateway Computers & Internet
Shut down and show power saver
Open Control Panel, Power Options, Advanced Power settings, Change Sleep to Never, Hibernate to Never. Adjust to your preference.OR right click on a open space on the desktop, depending on the OS you are using, select Properties or Personalize, Select ScreenSaver, set time. It's a good idea to shut down your machine when not in use, even if you have a UPS, Your computer will last longer and a reboot every day resets the computer.
Jan 11, 2013 | Dell OptiPlex Computers & Internet
I am happy with my N150 but is there a single button to switch off the computer other than going to "start" and "shut down" which may last several minutes in the process and more if...
The default action for the Power button on the start menu in Windows 7 is shutdown, and in Vista is Sleep, which isn't necessarily useful for everybody, so we'll explain how to change it here.
Change Windows 7 Shutdown Button
clicking on the start menu and choosing Properties.All you need to do is change the drop-down for Power Button Action to whatever you would prefer.
Change Windows Vista Power Buttons
You can configure this setting easily by using the advanced power settings panel, which is a little tricky to get to normally, but we'll take the shortcut.
Open a command prompt (type cmd into the start menu search bar), and then type in the following:powercfg.cpl,1You could also take the long route (Control Panel \ Power Options \ Change Plan Settings \ Change Advanced Power Settings)
Mar 14, 2011 | Samsung N150 Netbook
Whenever I step away from my Macbook Air (running 10.5.8) and it goes to sleep, when I come back it says that it tried to shut down Firefox but could not. Then I have to go through several steps to cancel...
I would check the energy saver settings under system preferences and see if it is set to go to sleep after a period of time. Also check the schedule button under energy settings to see if there is a scheduled sleep setup. Hope this helps
Mar 24, 2010 | Apple MacBook Air
Acer aspire 2920z is automatically shutdown only message appear warning critical battery low and then shutdown
Sounds like your battery is faulty and not charging. Try replacing the battery or just use the mains lead with the battery removed. If this keeps happening replace the system board
Feb 23, 2010 | Acer Aspire 5610-4648 Notebook
Toshiba A15-S157. I cannot adjust power settings in Toshiba console. Icon is there but it will not respond. My goal is to disable all timeouts when computer is operating on A-C power. Cannot find recovery...
To change your computer power saving plan, automatic shutdown, or to check power settings, go to, (Control Panel), click on Change Power Settings. From here, choose when the Computer Sleep, when not in use, how long the display stay on, and when the computer should shutdown etc. I hope this Fix it, paul7of9
Jan 23, 2010 | Toshiba Satellite A15-S157 Notebook
My computer will come on but will only go to monitor is asleep
There is a possibility that your computer power saving plan, or automatic shutdown settings were somehow changed. To check power settings, go to, (Control Panel), click on Change Power Settings. From here, choose when the Computer Sleep, when not in use, how long the display stay on, and when the computer should shutdown etc. I hope this Fix it,
Jan 22, 2010 | Microsoft Windows XP Media Center Edition...
I have a Toshiba Satellite SA40-271 model. When you want to start by pressing the START power LED yellow flashing on and does not start.
To change your computer power saving plan, automatic shutdown, or to check power settings, go to, (Control Panel), click on Change Power Settings. From here, choose when the Computer Sleep, when not in use, how long the display stay on, and when the computer should shutdown etc. I hope this Fix it.
Jan 17, 2010 | Computers & Internet
How to shut down dell inspiron 530 computer - the button only takes computer to sleep mode
I assume you use Windows Vista.....
In vista the default action of the power button is configured to sleep mode..
So to shutdown the PC you can press "Start - right arrow - right arrow - right arrow - Enter", or you can navigate to the same using the mouse & selecting shutdown from the list besides the lock icon.
You can also change the power button configuration this way goto " Start-Control Panel-System and Maintenance-Power options-change plan settings (under the current plan you are using) - change advanced power settings - Power buttons and lid - Start menu power button" click on settings and select shutdown, apply & save the settings and close this window.
Now you can just click the power button to shutdown your computer.
Jul 05, 2009 | Dell Inspiron 530 Desktop Computer
Samsung SlimFit TX-S2783 TV Logo
190 people viewed this question
Henry  Thomas
Henry Thomas
