Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Screen has no power sound still works
The sound still works but the screen has no power smell in the upper left side like something burned out
  • 67 Answers
Sounds like hv cicurt or tuner on older mod need more info to give replacmente parts etc info manuftre etc
Posted on Jul 25, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
IC controle module for the LCD display is out.. replace you shall be fine.
Posted on Jun 30, 2009
Need code for 7 blonks on power button
www.ask.com/
www.wikipedia.org/
www.infolinks.com/
www.info.com/panasonic_viera/plasma/tv/th42pz80u/blinks/7_times/and/black/screen/mean/
most likely failure of module in the tv, most likely fuse, capacitor, something burn up, find the air vents smell the area your smelling something burn up smell, if you have every smell electronic stuff burning up you will understand what i mean you will never forget that smell.
Oct 06, 2015 | Panasonic Viera TH-42PZ80U Plasma TV
LP3065 top arrea darker - backlight defect?
what you can do is to remove the back cover to access the inverter board. probably the cause of the smell is burned inverter board for the screen back light ( ccfl ) at the upper portion of the display.you can find the inverter board near the power supply board. usually you will replaced the inverter board since most of the part get fried as will as the pcb pattern circuit board get burnt.hope this can help good luck.
Nov 08, 2012 | Computers & Internet
No picture and burning smell from left side
Bad COF ic on buffer board. Can usually tell which one's bad. It will look overheated or a hole in top of ic. Look at upper and lower buffer boards to see which ic is bad. Can get from Encompas Parts, Recommended replace y sustain with buffer.
Nov 26, 2011 | SNK Magnavox 42MF231D 42 in. Plasma TV
I just bought a 1996 camry and the fan sounds loud and it smells like something is burning, yet the temperture is normal and no smoke comes out. Is that Normal? First Toyota, so I"m not sure if the...
Check the fan on broken blades - even a small part missing can cause unusual sounds. If parts are new / serviced - smell can be due to labels getting hot and emitting slight burning smell. Classic are exhaust pipes with partnumber labels left on there. If he smell stays, something in the interior might come from a crash car which was partly burned.
Jun 30, 2011 | 1996 Toyota Camry
I have 3 central ac units for my house. 1 for the upstairs and 1 for the west side of house and 1 for the east side of house. just had a very cold night and the east side of house vents smelled like...
To make sure that there is not a problem with your blower test it on cool. if it runs good. then start the heater on auto and it should be okay. but still supervise the operation for about 5 mins. if you still smell something burning . then call an AC Technician for help.
Albert Saavedra
AC Technician
Fort Worth/Dallas TX
773-627-8766
Dec 28, 2010 | Heating & Cooling
Burning and fan type sound
That is probably the power section about to fail. The burning smell is going to be from overheating components. You will have to take it into either an akai repair depot or a local tv repair and have it looked at. Get an estimate first. The repair cost on this could be cheap if itis obvious and the repair gys are on the ball or it can be pricey if they just replace major parts (typical). Also have a good idea of what replacement cost is so you know if it is worth fixing.
Jul 20, 2010 | Akai LCT42Z6TA 42 in. LCD Television
Microwave is ge spacemaker model # jvm1650sho5. when microwave is turned on about 4 seconds later it starts making a noise and has a burnt smell. The smell comes from the vent on upper left side and the...
this sounds like the magentron may be going. have you had any issues with it not heating? check your warranty book, some mags have a 3-5 year warranty, otherwise it's probably not worth repairing.
Nov 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag model (MTB1950GR) tripped off the power switch and smell
Hi, It sounds like the relay onyour compressor. They will smell when it goes bad. Remove the rear panel on the back of the refrigerator and see if the smell is around the compressor.
Please let me know If I can assist you further.
Vic
May 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung 42" Plasma spn-4235 Went black
SOMETHING IS LOADING DOWN THE POWER SUPPLY...COULD BE THE Y-SUS BOARD OR UPPER OR LOWER Y-DRIVE BUFFERS...TAKE THE BACK OFF SET..GIVE IT THE SMELL TEST AND EYEBALL THE FLAT I.C.`S ON THE THIN BOARDS TO THE LEFT OF Y-SUS BD. IF NO BURNING SMELL AND NO CRACKS ON THE FLAT I.C.`S ...TRY REPLACING THE Y-SUS BOARD...NUMBER ONE PRIME SUSPECT...DO NOT POWER UP SET WITH BACK OFF UNLESS YOU ARE QUALIFIED SERVICE TECH...JOE ACE
May 13, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
228 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
