Question about Polaroid FLM-3201 Television
I have a 32" polaroid lcd tv the picture blacked out but the sound still works. what is the problem?
  • 94 Answers
May be the Display IC is gone or Problem from the Liquid, I hope that this advise will helpful to you.
Posted on Jun 30, 2009
After i power my polaroid tv on the screen shows for about 3 seconds then goes black what causes that
Its a Lcd so if it stays on turn off all the lights (we want a dark room) and with flashlight look carefully at the screen to see if you see a faint image of a picture there or not.
Dec 06, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
Tv has sound but no picture
I had similar problem with my Polaroid 42 inch. The screen would be fine for 10 minutes or so then go black. I found a work around that solved my problem and maybe you can to. What I did was remove the back panel of the TV. Make sure it is unplugged first. You should be able to see the electical board. Somewhere on the board may be a switch that says "Burn" or something with "Burn" in it. I set the switch to the "Burn" setting and the TV has worked fine ever since. Good Luck.
Sep 29, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
Polaroid TDX 01530B 15inch Black screen, no picture except POLAROID is visible briefly as TV fires up. Sound works.
The tv have a long board that call the LCD inverter board it is dead.This long LCD inverter board only job are to provided a backlight for the tv LCD screen panel to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
May 13, 2011 | Polaroid TDX-01530B 15.4 in. LCD HDTV
I have a polaroid 15.4" LCD TV. The blue light
i think this can repaired, change the lcd tv screen it will work, your lcd was broken at all
Jan 22, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
No picture have sound stopped while watching
Ur tv the LCD inverter board is dead.Replaced the LCD inverter board u will get ur picture back.Tries websites like Shopjimmy.com,Ebay.com to buy an refurbish LCD inverter board for the replacement.It a long board in shape.
May 31, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
No picture on 32" Polaroid
Your inverter boards need to be tested and serviced, these are circuits designed to control the light behind the LCD glass panel. It could also be the power supply not feeding 24volts too the inverter circuits. In that case the power board would need servicing.
Take it back if its under warranty if not get it serviced at your local repair center..
Nov 08, 2009 | Polaroid TDX-03211C LCD TV
Looking to buy a Polaroid TDA-03211C the needs repair
I have a 3 year old TV with the same problem as shema_ross.
Aug 16, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
Jun 20, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
The Polaroid Flat Screen TV just died.
Sounds like a bad capacitor on the power circuit board. best place to look
Mar 30, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Customer Service Assistance
well first that new, wal mart should just replace it no questions asked, but the 8oo number for polariod is 1-866-289-5168 that should be customer service.
Nov 26, 2007 | Polaroid FLM-3225 32 in. LCD Television
Polaroid FLM-3201 Television Logo
169 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
