Question about Canon PowerShot SD600 Digital Camera
When taking pictures there are lines across the pictures and sometimes the picts are really bright or discolored. What could be the cause of this?
  • Canon Master
  • 4,738 Answers
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Posted on Jul 01, 2009
Lines across picture and extremely bright
It looks like the CCD has problem. but you can try to reconnect the CCD cable first. if it doesn't help, you need to replace the CCD or lens unit.
Aug 14, 2009 | Casio Exilim EX-Z77 Digital Camera
Fine interference lines running diagonally across picture.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Mitsubishi VS70707 Has developed subtle lines in picture
If they are faint white lines, they are called re-trace lines. They are caused when the current to the CRTs is too high. One way to check is to turn the brightness down. They should go away, but if the picture is too dark, you will need to turn down the "screen" control. This will take some handy work. If you are handy enough, take the grill off the front. Inside you will see a little black box, about 5 inches wide. there are 6 knobs on it, 2 for each color. One row is for focus (each) the other for screen (brightness). It is written on the part. The trick is to turn each of them down equally or risk having a slight tint of color. Really not hard at all, but requires the TV to be on to see. You shouldn't need to turn it but a fraction. Good luck.
Feb 16, 2009 | Mitsubishi VS-70707 70" Rear Projection...
Pink discoloration and vertical lines in light areas
Possibly a form of flare caused by including the light source in the image.
Jun 25, 2017 | Olympus FE-280 Digital Camera
Camera taking wierd pictures
look for the reset to factory settings for your casio. i could also be the settings have been changed so more light is coming in the camera which explains your bright pictures. but the lines across ALL the pictures warn something of a CCD/Cmos sensor problem.
Nov 29, 2008 | Casio Exilim EX-Z77 Digital Camera
Long power up time, wavy "static" lines, and red/orange problems
part of it sounds like your coax cable is not connecting properly. pull it out and make sure the pin at both ends of the coax cable is straight if bent replace coax cable.
Dec 28, 2007 | Hitachi 32UDX10S 32" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Thin horizontal line across picture
I really dont understand the problem Could we see a picture of this please?
Jun 14, 2006 | Toshiba 35A44 35" TV
Weird picture in viewfinder
The discoloring problem is quite common, but its hard to tell from your post what?s the degree of the defect. Unfortunately the LCD screen washing out in bright sunlight is a problem on many digitals, and also streaking lines coming off bright areas. There are hoods that you can buy for the Nikons that will fix this problem. I don't have any links to them but they are not hard to find. If you think your problem is really too much to absorb, feel it can't possibly be anything normal, or have problems with the actual pictures as they transfer to a computer, I suggest you take it back to the store and say you're not satisfied with the product. Hope it turns out well.
Jan 21, 2006 | Nikon Coolpix 5700 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
99 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
