There are two types of regulators used. One has a rubber diaphram sealed at perimeter with body and a piston type. Most likely you have the piston type. Remove body containing piston/ spring
mech. Examine piston lip seal. Lip will face toward body of reg. and must fit
snugly into cylinder. Make sure cylinder is smooth and is well lubed.
If seal/piston fits loose remove seal and wrap some teflon tape in groove and re-install lip seal /test for
snug fit. Notice small metal
actuator extending from center of reg. , if it is circular (about 1/8 dia) then there should be an
oring of the same size mated/fit into the piston. If this
oring is missing it will leak as you describe. Lastly, there should be a gasket or
oring sealing outer shell to body. If you have
diaphragm type look for holes, tear or shrink too small. Parts are at
www.toolpartsdirect.com or
Lowes in the plumbing department good place for
orings and silicone lube. Good luck
