Question about Remington 16" Electric Chain Saw
I borrowed a Remington 111174-01 and I've lost the nib that threads on the adjusting knob to tighten the chain.Where can I buy a new one.
  • 188 Answers
I suggest you call Master Parts at 800-446-1446. You also can find them online at www.masterparts.net. They may have the part you are looking for.
Posted on Jun 30, 2009
How to tighten chain on 4620avx poulan pro
First, RTFM- read the manual. Lost it? No problem, download it from Poulan PRO website page for PP4620avx. Pick a version you like, save and read it. Google is your friend.
Chain Adjustment Part cut and pasted as follows:
Adjusting the tension:
Chain tension is very important. Chain stretches during use. This is especially true during the first few times you use your saw. Always check chain tension each time you use and refuel your saw.
1. Lift lever on bar knob and turn counter-clockwise 1.5-2 turns to loosen clutch cover.
2. Turn adjusting wheel (downward direction) to tension chain until chain solidly contacts bottom of guide bar rail. Lift tip of guide bar while adjusting tension. Tighten chain Adjusting Wheel
3. Use a screwdriver to move chain around guide bar to ensure all links are in bar groove.
4. While lifting tip of guide bar, tighten bar knob securely (clockwise).
Hand tighten only.
Be careful not to destroy the adjustment mechanism. When it breaks, go for a clutch cover with the simple adjuster that needs a "scrench". Longer term, learn how to search this info. Saves time. Now you can work on sharpening chains- very important.
Manual page:
http://www.poulanpro.com/ddoc/PPOO/PPOO2006_USen/PPOO2006_USen_PP4620AVX_952802146.pdf
Jul 21, 2014 | Poulan Pro Chain Saw 46cc 20"
Loose chain
Hello David; good luck to you.
I went here and input model 107624-01, followed the directions and when possible selected the IPL. I found pn 108640-01, item 32, NLA @ Remington Power:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
Part Number 108640-01 is available here $13.99 - the picture is a complete assembly (cover, bar nuts, spacers and tensioner assembly).
PartsFor.com
http://www.partsfor.com/
If me I would use the phone number provided, ensure it includes all illustrated parts, order with a credit card (recover your investment much easier), get the name of the service person helping me and the name of her/his supervisor.
Please re-accomplish my steps to ensure I made no mistake, I do err occasionally (I swear on a stack of UCMJs covers have been NLA for quite a while).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 25, 2010 | Remington 16" Electric Chain Saw
No chain tesion adjustmen older (yellow) Remington EL.1 chain saw
just undo the singe nut slightly the pull so chain tightens then re tension the nut....about all you can do on those old models.
Jul 24, 2010 | Remington Garden
How do I tighten the chain on my Remington 14 in. 2 hp electric chain saw? Have used tightening screw, does do anything. Loosened the blade bolts trying to move the blade out slightly. Doesn't work...
Mitch if you attempted what is in the manual, and it is not working we would have to see and touch the saw to determine what has failed. If you loosened the bar bolts before trying the adjuster and it did not work, I suggest a trip to a local saw shop.
Chain adjustment pages 1, 8 and 9.
This is from a Remington OM
http://shoppingcart.msservicecompany.com/msservice_net/product_files/107624%2001/107624-01-EL-8-OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 03, 2010 | Remington Electric Chain Saw
I was using my Remington 14'' limb N' trim chain saw and the chain slipped off. How do I put it back ??
First, inspect the chain for bent links or other damage. If ok, loosen the bar mounting nut(s) and turn the tension adjust screw CCW until the chain can be passed over the sprocket, then threaded over the far end of the bar. Make sure the chain cuts toward you on the bottom. Turn the adjusting screw CW until the chain begins to tighten. Proper adjustment is when the lower run of chain doesn't droop from the bar, yet allow easy movement of the chain by hand. Tighten the mounting nut(s) and recheck the chain adjustment. Pay attention to chain droop and readjust as needed during use of the saw. Make sure it is being properly oiled by running the saw in front of a piece of cardboard for several moments--it should throw off a thin line of oil. Hope this helps!
Mar 21, 2010 | Remington Electric Chain Saw
Unable to find place to buy chain adjuster.
Lou
I have a Remington 16" (107625-01)
The nib broke off of the block adjustment and it was bent anyway.
Where did you find item 26 and 27 above?
Thanks Daryl
Jan 29, 2010 | Remington Electric Chain Saw
I AM FEMALE,HUSBAND DECEASED.I CLEANED MY REMINGTON POLE SAW AND WHEN I PUT THE CHAIN ON ,I MAKE ONE CUT AND THE CHAIN COMES OFF,HELP EMAIL ADDRESS -JIMANDJO@BELLSOUTH.NET THANKS
after reinstalling the chain,make sure the two guide bar bolts are loose, Using a screwdriver,turn adjustment screw to tighten chain to bar. Re-tighten guide bar bolts
Sep 28, 2009 | Remington Polesaw Wizard
Replacing Remington Electric chain saw blade
Where the bar meets the body of the saw there is an adjustment lug that will either push the bar outward tightening the chain or may be retracted allowing slack in the chain. When backed off (loosened) sufficiently, the chain may be removed for replacement. In order to use this feature, however, there are two bolts that secure the bar to the body that must be loosened prior to any adjustment and tightened bach up after making adjustments to the chain. The above will be enough to remove and replae the chain. If you are taking off the bar (that the chain runs on), you will need to remove the two bolts that were just loosened for the chain adjustment (above).
Regards! --WoobieDog--
Jul 07, 2009 | Remington 16" Electric Chain Saw Assembled...
The chain on my Remington electric saw keeps jumping the sprocket. Solution? Thanks.
Depending to what model you have, the Sprocket cover tab (located on the round part of the sprocket cover) isn’t inserted into the saw body tab slot. Or your cahin is not tensioned properly. According to the manufacturer... "The adjusting block on the adjusting screw isn’t inserted into the adjusting hole on the guide bar. Reinstall and align the sprocket cover by first removing the sprocket cover from the saw. Turn tensioning screw on the sprocket cover counter-clockwise until it stops. Pull guide bar away from saw body to remove slack from chain. Insert sprocket cover tab into saw body tab slot and lower sprocket cover into guide bar bolt. Finger tighten guide bar nut onto guide bar bolt. Slowly push guide bar toward saw body until adjusting block on the adjusting screw drops into round adjusting hole on the guide bar. Securely tighten guide bar nut after properly tensioning saw chain." If these tips do not work, you may need a new chain. You can order an new chain on-line at www.masterparts.net. I hope this helps you!
Jul 01, 2009 | Remington Electric Chain Saw
Remington 16" Electric Chain Saw Logo
143 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
