Question about Lexmark X83 All-In-One InkJet Printer
I changed the ink cartridges and it does not print at all. I changed them because I thought the other cartridges were dry from lack of use. I understand the printer head can become clogged. I am wondering how to clean it?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Cleaning the head is done Via driver that come with the printer. Just go to control panel and select printers and faxes. right click on your printer as it shown in the list, select properties, then printing preferences, and search there for the head clean option. Every printer has it in a different menu but that is the general case.
Posted on Jun 30, 2009
My printer only prints magenta\
A color or photo cartridge is either low, clogged or has run out of one of the basic colors it mixes together to create the colors in your images. The printer cannot print correctly if it lacks one of the basic colors, even if it still contains some of the other colors. The cartridge may also be clogged. The cartridge must be replaced
This may help
You can try to clean the printer head manually. To clean the printer head, remove the ink cartridge from the printer. Moisten a cotton swab by dipping it in hot water or isopropyl alcohol, and then gently wipe the printer head. Do this repeatedly until it softens the dried ink.
For models where the printer head is located in the printer, you can put 7 to 10 drops of isopropyl alcohol in the ink receptacle where the ink flows from the cartridge to the head. Turn the printer to self-cleaning mode. You can also leave it for a few hours or overnight before repeating the self-cleaning mode.
If the print head is located in the cartridge, soak the print head in hot water and let it soak overnight. Dry the print head part using a paper towel and switch it to self-cleaning mode.
If the hot water soak does not work, place the cartridge printer head in isopropyl alcohol and let it soak overnight. Wipe off the soaked area and dry it carefully using a damp paper towel. Turn the printer to self-cleaning mode to remove any dried ink.
For more Help Source... Can You Fix Dry Ink Cartridge eHow
Thanks,
HP Phone Number
Jun 25, 2014 | HP Officejet Pro L7680 All-In-One InkJet...
Changed black cartridge and now only colour printer will print in is blue/green
The black print head most likely is blocked with dried ink.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Nov 19, 2012 | HP Photosmart 3210 Printer
Changed ink and now the printer wont print
The old ink has probably dried, plugging the jets. Try going through the cleaning cycle (several times if necessary). If it begins to print at all then let the printer set overnight and try cleaning again.
Fred
May 09, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Havent used my printer in about a year, i have changed out all inks and used printer cleaning function for printer and ink, i have no print is my printer dried out or is there something else i can try
The problem is that the print color heads nozzles are blocked through lack of use and putting new ink cartridges will not unblock the ink nozzles. Inkjet printers needs to be use at least once a week to prevent nozzles from blocking up.
You need to replace the print-head with a new one.
NOTE print-heads are not cheap, it maybe cheaper to get a later model printer.
Mar 14, 2010 | Brother Office Equipment & Supplies
Ran out of black ink. replaced cartridge. now
If it ran dry before you replaced it then you need to do a deep clean of the head. This can be done under the maintenance tab of printer properties. If that doesn't get it working then physically remove the print head and clean it with a water moistened cotton bud (make sure you use a separate cotton bud for each ink nozzle). Running a cartridge completely dry can (and often does) damage the print head (overheats due to lack of cooling provided by the ink flow).
Oct 03, 2009 | Canon PIXMA MP530 All-In-One InkJet...
My Deskjet 3915 has gone over half a year without use and will not print. The paper is fed through and the ink cartridge moves back and forth, but no ink comes out. Any ideas?
You have committed the cardinal sin of inkjet printers, lack of use. The printer responds by letting the ink dry up in the feeder tubes and the printhead nozzels.
While it is possible to repair, time and dollars and cents (sense) say "Hey, it's time to buy a new printer!
Next time, if possible, print at least 1 page a couple of times a month. A pain, but it works.
Aug 03, 2009 | HP Deskjet 3915 InkJet Printer
Carriage cycles normally but no ink on paper.(Stylus color 880)
Turn off printer. Open Case. Move head carriage to parking position. Do suction from outlet pipe of head cleaning mechanic. It's for checking head. is there ink out? If printer not used for long time, may be ink inside head dried. Utility screen just show estimated not actually. If head clog, and do head cleaning more 5 times, screen show ink nearly out, but actually ink tank nearly full.
Jun 28, 2009 | Epson Stylus Color 760 InkJet Printer
Poor or no printing
When inkjet printers are not used much, the ink dries up in the cartridges and on the print head, causing poor printing, and, as the dried ink builds up, no printing at all. no matter how many times the cartridges are changed, the dried ink won't work out. Some people have had luck with this problem by using alcohal and a q-tip to clean the print head. If that doesn't work, you will need a new printer.
Feb 12, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Not printing
Try taking a paper towel, and spray it with Windex (with amonia).
Take the cartridge out, and wipe the bottom of the cartridge with it.
This will wipe away any dried ink on the print head.
Then if you take a dried piece of paper towel, and press down on the bottom of the cartridge by the heads for about 5 seconds, you should see a spot of ink.
If that doesnt help, then repeat the above steps and try it again.
Last resort, try a new cartridge.
Good luck.
Feb 08, 2008 | Canon BJC 2100 InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
100 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
