Xerox 5314 throwing a U8 code
I know the U8 code is showing the the optics sensor isn't reading enough light at the main board even though the exposure lamp comes on. I have cleaned the platten and 5 mirrors. In diagnostic mode I can turn on the exposure lamp, and erase lamp. But it still does a U8 code whenever I try to copy. Is it the exposure sensor, and if so where is it located? Or is it possibly the main board? I don't want to throw a lotr of money at it but would like to fix it if possible. Thanks, Dan
    President:
  • 1,447 Answers
It is the problem your copier heater unite conector is life out change it and solve your problem
Posted on Jun 30, 2009
Getting error code u8-3
Exposure lamp blown, lamp terminals contact or regulator
Cek Kabel Optic.
Aug 22, 2011 | Xerox WorkCentre Pro 428 Copier
I am using xerox work center pro428 .now it is not working error message showing code U8-3
Hi, I can't find that specific error code in the documentation on that model of machine, however, in general in Xerox machines U8-3 means that your exposure lamp is blown or has a problem
Aug 19, 2011 | Xerox WorkCentre Pro 428 Copier
I need to know what the code for a 1993 honda accord it flashed 4 slow then three short fast flashes, my car has been lagging really bad and i dont know exactly what i need to do to fix it i was told it is...
Found this for you on the web. Good luck.
c/p;
What is code 43?
Code 43 is "fuel supply system."
This code will trip when the ECU and the readings from the o2 sensor don't get along(in layman's term or easy enough for Si Speed to understand biggrin.gif) read the above two threads).
How to diagnose and fix?
First things first, when was the last time you changed your O2 sensor? Start by replacing that first because most likely, that's the main culprit. Now, you may wonder why doesn't the CEL indicate code 41(heated o2 sensor)? Usually when the o2 sensor is completely dead, that code will trip. Also, even though the o2 sensor is working, the voltage or ground isn't 100% Because of that, it will correlate with code 43.
If replacing the o2 sensor did not help code 43 to disappear, next thing is to replace your fuel filter. A clogged fuel filter will also trip code 43.
Next up, did you install an aftermarket Fuel Pressure Regulator? I have a few friends with 3rd gen Preludes and both of them installed aftermarket FPR's and they too, trip code 43. Him and a lot of people who install aftermarket FPR's mess with the PSI and that will cause code 43 to appear(on a stock ECU mind you). Bring it back to stock PSI to help fight code 43.
Those are the 3 main culprits that will cause code 43 from my experiences. Injectors, spark plugs & wires, most likely anything "fuel' related that isn't working properly will also cause code 43.
May 03, 2011 | 1993 Honda Accord
The oil sensor light continues to show
Its a good idea to have the oil pump's pressure output tested.
These cars are know for bad oil pumps.
Jul 21, 2010 | 2000 Audi A4
Xerox 5855copier showing 03-326
Try cleaning the optics even if they seem to be clean
Apr 08, 2010 | Xerox 5855C Copier
Have a xerox 5314. I get a u1 code when trying to
Hello sir; U-1 means main drive unit have problem such as main motor, gears, belt etc.
May 13, 2009 | Xerox Office Equipment & Supplies
Xerox 5314 copier giving error code of u2
A U2 means the machine did not see the lamp scan. The lamp did not leave the right side of the machine. May be hung up on something, may have broken a cable the scan motor may be bad, I would first of all remove the glass and see if there is anything binding the lamp and keeping it from scanning. If you think it feels tight to move, that is normal on a 5314. What I am looking for is the lamp stopping not being able to move.
Mar 14, 2009 | Xerox Office Equipment & Supplies
XEROX 6110 coloer printers
Xerox 6110 Code Description A1-1 to A1-32 All indicate a paper path problem, etc. in the ADF A2 ADF exit problems A3 Irregular size documents A5 ADF interlock A6 ADF single sheet document reset A7 Platen interlock A8 ADF exit interlock C1 Tray 1 jam C2 Tray 2 jam C3 Tray 3 jam C6-1, C6-2 Jams related to duplex C6-3 Registration sensor, re tray 1 C7-1, C7-2 HCF feed problems C7-3 Tray 1 feed problem C8 Paper stays in tray or duplex or HCF C9 Bypass feed problem E1-10 to E1-25 Internal jam E1-6 Paper on registration sensor E2 Reset signal happened. Might read E-2 something else E3-30 to E4-14 Exit jam E3-6 Exit jam E4-10 to E4-14 Inverter sensor not actuated E4-15 Inverter sensor E4-40 to E4-45 Duplex entry sensor E4-6 Inverter sensor E5 Front door interlock E6-1 Tray 1 interlock E6-2 2 tray or duplex interlock E6-3 HCF interlock E7-2, E7-3 Duplex interlock E8-6 to E8-15 Duplex entry sensor F1-1 Sorter entry sensor F1-6 Sorter exit sensor F3 Paper size not available for sort/stack F5 Sorter interlock J1 Add toner J3 Replace copy cartridge J7 Replace copy cartridge J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM L6 Auditron or other counter problem L8 Platen glass temperature is too high L9 Communication problem between interimage erase/edge lamps and main board U1-1 Main motor drive problem U2-1 to U2-4 Scan home sensor U3-1 Lens sensor U4-1 Open fuser thermistor U4-2 Fuser did not warm up properly U4-3 Fuser temperature too high U4-4 Fuser problem. Staying on too long U4-6 High fuser temperature U5-1 Sorter bin home switch not activated U5-2 Sorter bin home switch stayed actuated U5-3, U5-4 Sorter bin home switch U6-1 ROM problem U6-2 RAM problem U6-3 Low battery U6-4 Incorrect value in NVM. Reinitialize main board with code 20-96 U8-1 to U8-6 Problem with exposure lamp, lamp sensor, lamp board
Jan 03, 2009 | Office Equipment & Supplies
Xerox 5614
The book says problem with wall outlet.
are your hot and neutral wires swapped? Ground ok?
you can obtain a simple tester at home depot
let me know if further assistance is needed
never had one throw this code before.
Apr 25, 2008 | Office Equipment & Supplies
Error code U8-6 on Xerox 5320 copier
dear sir please check the exposure lamp unit may be it is dusty so clean it or check exposure lamp circuit fuse etc....
Oct 07, 2007 | Office Equipment & Supplies
136 people viewed this question
k24674
jasbo
jasbo
