Question about Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W
Would a bad thermostat cause my danby to not completely freeze?
I just bought a used Danby freezer (Model # DCF520W) today and it's been on all day and the items I put in this morning should be frozen. Some are only slightly freezing, but it's more or less keeping things cold like a refrigerator. I'm wondering what the problem could be. Would it either be the temperature control switch or the thermostat or?????Thanks for all info. Jim
  • 999 Answers
Should operate 24 hours before putting anything in that is not already frozen. Check it again after it has run for 24 hours. Anytime you adjust the thermostat go one click at a time and wait 24 hours for it to stabilize.
eric
Posted on Jun 30, 2009
The power light is faint and flickering on and off
These power lights are usually of the neon lamp type, and they typically do not last a long time, especially when they are powered on 24/7. They typically fail by flickering at first, then, eventually, they just go out. If you feel confident as a "do it yourselfer", you can often replace this lamp for only a few bucks, but it does require disassembly of the control unit. Otherwise, I'd just leave it alone. If you're concerned about food loss, I'd invest in a freezer alarm. The lamp has no bearing on the operation of the compressor unit. On, flickering or out completely, the freezer will still operate normally.
May 27, 2014 | Danby 3.6 cu. ft. / 102 liter Chest...
Danby DUF408WE Upright Freezer not working
Does the compressor feel warm to the touch. If it does, it will be proof that the thermostat is calling for cooling and is probably good. For the obvious questions: Is the freezer in an area below 80 degrees F, is the wall outlet in good shape and not hot to the touch, is the freezer plug not blistered around the prongs, is the door gasket against the face all the way around the mating surface on the chasis. If the compressor is hot, listen for a click every 2 to 5 minutes. If the click is present the starter is your last best hope. The click is the compressor trying to start. Without the proper tools you are pretty much up against a wall. One last suggestion is to check for loose wires under the compressor terminal cover. I would suggest you look up the compressor manufacturer for a visual on cover removal. Dont forget to unplug before attempting compressor cover work. I hope you havent tried to put screws through the outside walls of this freezer or damaged the shelves inside. Both are fatal for the freezer and no repair can be made. Good luck.
Jun 03, 2012 | Danby DUF408WE Upright Freezer
I want to register the Dandy Microwave I bought today at Wall-Mart located at 10/30 shopping mall in brossard, qc.
I would like to register the dandy microwave we bought at Walmart yesterday January 14, 2011
Cindy Carpenter carpentercelinna33@yahoo.com
Jan 08, 2011 | Danby 3.6 cu. ft. / 102 liter Chest...
I have a Danby DCF520W Chest freezer. the compressor runs and the contents freeze but the outside case stays hot all the time. After a couple of days the freezer shuts down and has to be unplugged before...
your freezer may be overheating due to the defrost for the freezer door, (mullan heater) is staying on. Most likely the door is not sealing properly. Also if it has a power saver switch on the side select it to that.
Dec 03, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
Temp Alarm going off and not very cold inside.
I think you should see if the circulation fan is working inside. Sometimes they need a little push and some WD 40 let me know. I might have another idea. The Raz Shack
Apr 20, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Foul fish smell emanating from the freezer
Well an old remedy is to put a box of opened arm and hammer baking soda in the freezer and fridge to keep it from having bad odors.If that doesn't work you can try some charcoal it is perfect for absorbing odor, just don't use the matchlight kind or it will smell like lighter fluid.
Apr 06, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
SETTINGS DCF520W
The best temperature for storing food is 0 degrees F. I would go to Wal-Mart, K-mart or a dollar store and find a refrigerator/freezer thermometer and set the freezer temperature with that. Best of Luck
Mar 10, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
Defrosted freezer -
Melody, It appears that possibly either the kids accidentally turned the freezer off, or something being taken out/put into the freezer, got pushed into the control knob and caused it to turn off. (Just trying to help the kids avoid taking the full blame with that one!)
The good news is that your freezer is probably fine and just got turned off somehow. You can put it back to the middle setting and adjust it from there to get the coldness you want for whatever you're keeping in it, (meats, ice cream, veggies, etc.)
The indicator lights are to let you know that you have power going to the freezer and the other one lets you know that the freezer is working and the compressor is operating. I'd keep an eye on it for the next few days though, just to make sure that everything is working the way it should, just in case. You can take an old plastic milk jug (1 gallon size) and fill it with tap water and put it in the freezer on the middle shelf. If after 3-5 days, the temperature is staying cold enough, the jug of water should be fully frozen. You can also put in a load of bread and see if that freezes nicely after a day. If the above items are properly frozen after 1 and 3 days, then your freezer is working properly and the culprit was very likely, just the control knob getting turned off, somehow.
I'd also suggest that you might want to lock the freezer, if your's has one, to help minimize any chances of the settings getting changed, etc. Of course, if you've got ice cream and kid snacks stored in there, then your children will keep looking until they find the key anyway!
You should check any of the food items you had stored in the freezer and if they got defrosted completely, you'll likely have to toss it all out, the only exception is bread, (which is typically not much good once it's been frozen anyway), but can be used to "fill-up" the freezer to keep it operating efficiently when you don't have much stored in it. I usually just mark the bags of old thrift store bread with the date I put it in the freezer and toss it after a year.
Bread is an inexpensive way to load up the freezer so it runs better and helps save you some energy costs, even when you don't have much other higher priced food in it.
I hope you find this Very Helpful and best regards!
Nov 02, 2009 | Whirlpool Freezers
Meat freezer burns
Hi,tomonbow
ngafm at your service,
You said,you are getting freezer burn in only two days, right?
Are you putting the meat in proper freezer bags and squeezing
air out as you zip lock the bag?
If you do not use proper freezer bags you will always get freezer burn on meats!
WAIT ! This will not happen in two days!
Seems to me something else has happened to your meat prior to your purchase and it probably is not the freezer at fault.
If it happens to meat that you feel was not frozen when you bought it, check with the store of purchase to see if it came into them frozen before it was put in their refrigerator case!
Most super markets receive cases of frozen meat and then put them in the walk in refrigerator, or refrigerator case to present them for sale to the customers and they defrost in the case.
Then we think we are buying meat that is fresh and never been frozen!
Fresh meat will not freezer burn in 2 days unless it has happened previously to the time you bought it.
Also when you freeze any meat you buy, repack it in proper freezer bags and not just any zip lock bag!
But I believe it happened before you bought it.
And i'll bet it all came from the same store.
that's why some people shop at a butcher shop or Costco type store where the meat is fresher and sells out faster!
Bless you.
ngafm
Please give me a good rating before you sign off.
Thank You.
Let me know the verdict. I think I'm right on target!
Do some investigating and ask the store some hard questions!
Sep 09, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Excess frost not keeping food frozen
you have a refrigeration issue. let me guess. is the frost real thick around a small area not the entire lining? if so you have a restriction or leak. cheaper to replace by the way
Apr 14, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W Logo
542 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
charles
Are you a Danby Freezer Expert? Answer questions, earn points and help others
