Question about Rv Motorhome Dual Co & Lp Gas Alarm Detector
Got a travel camper for free they told me everything works has ac, fridge, stove, water heater ect. but never owning one before I dont know how it works. I now theres two propane tanks on the side dont know how to work anything power ect.
  • 508 Answers
Have tanks tested and certified if need be install back on camper screw on hoses to tanks open valves spray soap and water on fittings make sure no bubles if bubbles repair leaks spray all fittings were propane fittings in system tighten to check for small leaks if no leaks proceed to lighting pilot lites on heater-hot water tank-stove(is in oven and possibly under burners)and fridge on back of fridge(everything should have instructions on it)turn knobs to pilot push in knob lite hold for a few minute till pilot stays lit then turn to on position-may haft to hold pilot for a while to get propane thru all pipes start with unit farthest from tank.(also if stove top doesnt have pilot you can get all air out by turn on burner till it lites-ac should work on 110vac may haft to remove top cover and clean fins with degreaser and hose-water system i will add a cup of bleach and ciculate thru system let sit then flush out entire water system(to prime waterpump hook up hose to side of camper turn on rack all valves turn off all valves pump should be primed)should have 12v deep cycle i use a semi truck battery same thing alot cheaper and heavy duty i buy at battery store for 30dollars instead of a hundred at walmart and last longer-keep top tarped as uv rays will dry out seams(if leaks i goto place that sells semi-trailer parts and buy vulcam one gallon $50.00 a gallon and paint on all seams on top-vents seams etc anywere it could possibly leak)always keep tarped and tarp will take uv rays and weather not roof tarps are cheap compared to leaks)make sure in fall you winterize keep battery inside house were warm drain all water out of system should be valve at low spot if not blow out system if you get all water out of entire system shouldnt need rv antifreeze stuff has terrible taste and hard to flush out!!!dont set camper on ground set on pallets or something instead of straight on ground!!!!goto library get book on rv's learn as much as you can and you will be prepared and wont ruin a good camping trip because of equipment failure!!!Best of Luck to You!!!!!amtnng@gmail.com
Posted on Jun 30, 2009
  • Mike Butler
    Mike Butler Dec 23, 2011
    "CAUTION" !!! Before running anything on propane system. Have a manometer test done on complete system before and after running all appliances. A manometer test will certify/verify, that there are no leaks in any part of the piping system, as well as appliances that could cause dangerous , if not fatal results, such as an explosion. Even if it cost $50-$100 for certified RV propane technician to test it, and certify it, what is the price you put on a life? Just because it lights and runs, doesn't mean it isn't leaking.
    President:
  • 776 Answers
I suppose you better buy the manuals and start learning.. .ya think?
Electric heater problems.
Plug in a ceramic 120 volt or oil type space heater to keep trailer warm. Most travel trailers are propane only, they do not have electric heat strips. I would bet that is why it only blows cold air.
Jan 28, 2014 | Open Range 2011 Mesa Ridge MR243F
Our 1995 30FL Leisure Star camper Dometic fridge is not working. the camper is level. the Check light goes on after a few moments of turning it on.
Give Arcticold Refrigeration a call toll free tech support 1-888-782-6665 We will require the model number so please have that available. We will require more info to help with this problem such as results on electric, ect. ArctiCold Refrigeration We keep it cold da1720cc-2c8a-48ab-b560-ebb5655e2d6c.jpg
Aug 24, 2013 | Dometic RGE400 Top Freezer Refrigerator
Recently purchased a 4400W generator to operate travel trailer primarily and on occasion my ac unit. Connected the generator to the travel trailer, then ran the a/c, everything going well, then the circuit...
What size circuit breaker is on the generator that is tripping? You'll need a 20amp for AC alone, then consider other things that are drawing current when RV plugged in like , converter, fridge etc that may be drawing current at same time. Make sure fridge is on propane, as well as water heater if you have electric element option on water heater. AC may only draw 12-15 amps when running if good and clean and wired properly, but will draw 17-18 amps when compressor kicks in. Perhaps generator not designed for that surge?
Aug 28, 2011 | Dometic Rooftop RV Air Conditioner
2003 wildwood travel trailer manual
Most travel trailer manuals are basically the same. Have you tried contacting the Manufacturer? (Forest River) The appliances are normally separate from the owners manuals, such as fridge, stove, water heater etc. Is there anything specific that you are having concern with at this time, that I may be able to assist with? Also, as far as the appliances go, most manufacturer's have a site you can go to and download manuals for them off the internet.
Jun 27, 2011 | Heating & Cooling
Just bought a used 1987 Real-Lite truck camper. The roof air unit is Dometic as well as the LP/AC refrigerator. When turned to "cool" the air conditioner really draws down, dims the lights, and eventually...
To start with, if it's plugged in to a 15 amp breaker, and extension cord, the compressor starting up may just be enough to trip the breaker. It will draw close to 15 amps on start-up of compressor, and if there is a light extension cord used to plug it in, that only makes it worse. Make sure you shut all other breakers off in panel except AC, and try it. If you have water heater on hydro, fridge on hydro, and then try to start AC compressor, you'll be way over the 15 amps, especially if it's a light extension cord.
Keep in mind, in order for fridge to work, you need 12 volts DC (Battery) power going to back of fridge. If the controls aren't lighting up at top, you've most likely got no 12 Volt DC power going to fridge. Check all fuses as well.
Jun 02, 2010 | Dometic Rooftop RV Air Conditioner
Water Heater electronic ignition to work???
Here's a link to operators manual. You can download PDF file as well and print for later use if you wish.
http://bryantrv.com/docs2/docs/operating/atwood1.pdf
Apr 21, 2010 | RTO Atwood Water Heater - 6 Gal LP
I have a dometic RM2201 3 way fridge my problem is that my fridge does not work but my freezer does why would this be?
Sorry woodchuck789 Rank: Guru. The Dometic RM2201 does not have any of these things; vent(damper), fan in the freezer, auto defrost, defrost timer, defrost heater, or a defrost thermostat.
mickamoose, Most likely the camper is not sitting level. It needs gravity to work correctly. The fins in the back of the refrigerator get cooling from the refrigerant leaving the freezer compartment. If all else fails, leave to freezer compartment door open inside the refrigerator. Parts for this unit are getting hard to find and these RM2201 refrigerators will never work as well as the one in your house. One alternative is to replace the refrigerator with a dorm or office type refrigerator. They are cheep and work well except only on 115 Volts AC.
Aug 19, 2009 | Refrigerators
Furnace won't turn on, off, with or without remote
We hotwired the thermostat wires and the furnace started. That told us that the problem was with the thermostat. We took our remote control to another camper like ours and our remote worked their furnace. That told us that the problem was in the ceiling control for the furnace/ac. But the man who owned the other camper told us that he had a problem, too, and was told to unplug all the electric including the battery, wait 2 minutes, and hook up again. This might reprogram the circuitboard, and voila! It worked.
Feb 08, 2009 | Dometic Rooftop RV Air Conditioner
Frdge freezing everything
Check to make sure the thermistor is attached to the fins on the inside of the fridge. Otherwise you may have a bad control cable assy.
Jan 12, 2009 | Dometic NDR 1062 Refrigerator
Rv Motorhome  Dual Co & Lp Gas Alarm Detector Logo
681 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
