The error read Turn the main power switch off and on to Resume F248 I have done this 4 times.
SOURCE: s9000 canon printer ink tank full
Hi
Try this see if work for you.
may work
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
SOURCE: i'm having an error on
this is
Controller system error
swith of and swith on the printer it will work .If this error occurs again even after the
power switch is turned off and then on
again, please replace
PWB
SOURCE: Hi my printer has te E2/E7 error code on it and i
This is the procedure but not each time waiting for the carriage to return to original place.Just press resume button 4 times consistently.Then press the Power button and the printer should turn off, if not, press the Power button once more.Your printer should respond as normal.
SOURCE: Error Code C 7460 On Kyocera Taskalfa 8000i
Developer shutter locked - open front cover and slide the developer shutter to open/unlock, restart the machine. The shutter is locked to prevent developer spilling when transporting the machine.
